Hotpoint washer - errotr message saying 'door' on display but door is properly closed have opened and closed it and turned off the machine to see if message will re-set but washer wont start you hear a click like it's switching on the cycle then nothing and 5 mins down the line 'door' appears in the display window!!!
  • 1,998 Answers
If your model is a top load washer replace the lid switch likewise the same for a front loader you can find the lid switch and have it directly sent to you by looking up marcone appliance hope this helps if you are unable to make electrical and mechanical fixes plz call a technician although they usually charge between 125 and 189 for this simple install of a 30 dollar part
Posted on Jul 14, 2010
Hotpoint ultima extra washing machine, door open sign flashing on lacd display even though the door is closed properly
first check all connections on circuit board are tight if ok change interlock,if problem still persists you have a circuit board fault which could have been caused by blown interlock
Sep 08, 2011 | Hotpoint Washing Machines
Cleaning a front load washer for mold and mmildew
What's the question?
Use a mild bleach
heres the solution from washing machine manuals, dont know why fuses and powerre included in this...
odor in washer
• Water supply taps are not
open fully.
• Water line hoses are kinked,
pinched, or bent.
• Water inlet filters are clogged.
• Water pressure to tap or
house is too low.
• Power cord is not properly
plugged in.
• House fuse is blown, circuit
breaker has tripped, or power
outage has occurred.
• The door is not closed
properly.
• Incorrect or too much
detergent has been used.
• Inside of tub not cleaned
properly.
• Make sure that the water taps are open fully.
• Make sure the hoses are not kinked or pinched. Be
careful when moving the washer.
• Clean the inlet filters. See the Care and Cleaning
section.
• Check another faucet in the house to make sure that
household water pressure is adequate.
• Make sure that the plug is plugged securely into a
grounded, 3-prong, 120-VAC, 60-Hz. outlet.
• Reset circuit breaker or replace fuse. Do not increase
fuse capacity. If the problem is a circuit overload,
have it corrected by a qualified electrician.
• Make sure that the door is closed properly and press
the START/PAUSE button. After starting a cycle, it
may take a few moments before the drum begins to
turn or spin. The washer will not spin unless the door
is locked (DOOR LOCK will appear in the display).
• If the door is closed and locked and the open door
error message is displayed, call for service.
• Use only HE (High-Efficiency) detergent in accordance with the
manufacturer’s instructions.
• Run the TUB CLEAN cycle regularly. Be sure to wipe around and
under the door seal frequently.
• Clean around door seal/glass to prevent odor or mildew:
1. wipe dry the door seal/glass and the door opening area
2. wipe around the inner drum/door seal and the lower door seal
Aug 20, 2009 | Samsung Washing Machines
Close door error on display when door is closed on WDM73
Th eswitch that teel it that door is open is out of position or bad.
Jun 19, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Hotpoint
F08 is - Static heater relay with contact welded closed.
The door might had been opened with the dryer not cooled.This leads to a heat relay.
Dec 13, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Light for door keeps flashing when shut hotpoint aquarius
When you say new door clip fitted, I assume you mean door handle, if this is the case then it could be you have not got it back together properly, if you have, then it could faulty door interlock
Dec 05, 2008 | Indesit W 123 Front Load Washer
Washing machine wont start - close door message
Hi.
Most likely faulty door lock or door catch.
To access it, remove the clamp from drum front seal, and remove the seal from the front of the cabinet, undo the 2 screws that secure the door lock, and remove.
To test wether the lock is faulty or not, put a link wire across the (L) and (C)
connections on the lock, the m/c should now work, if it does not, then you have
a more serious problem.
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Odd messages appearing on lcd screen and not collecting water
What make and model is your washer?
Cannot help without further details
Nov 19, 2008 | Hotpoint Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
