Question about Dryers
Clothes dryer has chipped paint on the inside which can stain clothes. Is there a paint product that can be used to fix this problem?
  • ardys749 Jul 14, 2010
    OK, thanks!
  • 6,784 Answers
HI. Due to the extreme heat levels that can occur in this type of unit: There isn't much that can be done to prevent this , overtime. The best actions are to remove the entire drum and strip the existing paint that is chipping and re apply a new and more resilient spray paint product. There are many heat resistant spray paint products on the market. With that said, i would use a clear coat finish on top of a flat gray or white. This will protect the underlay and prevent chipping for some time.
Posted on Jul 14, 2010
My GE Adora dryer is ripping clothes
look inside the drum with a flashlight and look for broken or loose tumbler rib, can be fixed with epoxy, sand smooth surfaces first, let cure and use appliance paint to paint it
Jun 09, 2012 | GE Adora Super Capacity Dryer
Brown stains on clothes after taking out of drier (removable on hot wash)
Could be rust, is your laundry kinda damp?
Has someone dried a pair if brown or black shoes?
Check the conditions inside the drum.
Use a solvent to remove any dark marks.
Sand away any rust and paint over with high temp paint.
Sep 16, 2011 | Dryers
Pen ink stains on dryer drum, help!
use liquid solvent...thinners or maybe even some petrol from the lawn mower.... a little on a rag should do the trick,maybe some metho or even turps.
Jul 20, 2010 | Kenmore Elite HE4 Electric Dryer
We have a Maytag Electric Dryer, Model LDE512 , which leaves black marks on clothes while drying them. The dryer is about 18 yrs. old and has been working great except for this one problem. We have...
HI The drum is mostly stainless steel; The end that contacts the drum guide is just painted steel. After years of rubbing, some rust can form after the paint wears away,thus, causing the stain. Painting the bare metal (after removing all rust) and replacing the tumbler bearings,roller and roller shafts, will correct this issue and prevent it form happening in the future. You should also replace the tumbler seal while the unit is disassembled. Part numbers are below:
Tumbler bearings/Glides(You need two)- 306508
Roller - 12001541
Roller shaft - 6-3129480
Tumbler seal - 314820
Roller Shaft washer - 312535
Retaining Ring(shaft)- 410233
Jul 16, 2010 | Dryers
Brown stains in the drum of my whirlpool dryer
Apparently a common problem with 4-5 year old Kenmore and Whirlpool dryers. The paint is rubbed off the back panel by the felt seal attached to the rotating drum. The bare metal gets rusty from the damp clothes. The rust is rubbed off by the felt seal. The entire felt seal will turn brown. The stains are transfered to the clothes. The rust stains can generally be removed by additional cleaning.
I'm going to replace the felt seal on the drum, clean the rust off the back panel and see how long it lasts. Seal w/ adhesive is $30-40.
Some have suggested painting the back panel, but i don't think fresh paint is going to last long. The original paint was probably electrostatically applied and maybe baked on.
Nov 05, 2009 | Dryers
Help getting crayon out of dryer.
If they are globs you can freeze them by rubbing with an ice cube and scrape them off. If the residue is thin like a coat of paint use denatured alcohol or paint thinner to rub them off. Make sure you leave the dryer door open several hours after using solvent inside to air it out. Do not use the dryer immediately after using solvent or there could be a fire hazard.
If the crayon residue is on the clothes, you can put piece of absorbent paper (like a paper grocery bag) over the stain and iron it. The heat will melt the crayon wax and the paper will absorb it. You may have to do it several times to get it all out. Denatured alcohol or paint thinner might be needed to get the final stain out.
Jun 29, 2009 | Dryers
When the dryer is running it smells like charcol ligher fluid
Sometime recently there has been a petroleum product used in the house. Possibly an oil based paint, stain, varnish, adhesive or some form of cleaning product.
Anyone of these products or many others like them, contain a distillate of liquid. Check around the house.
Until that oil based product dries or cures, the odor and vapors will remain and so will the dryer smell.
At the end of the drying cycle, use the air fluff cycle to purge out the smell. Besure to return the selector on the dryer back to it's prior postition.
Jun 11, 2009 | Kenmore 62882 Electric Dryer
Inside of drum has been chipped off in two places
There is a ceramic white touch up you can buy.I have bought one myself a couple of years ago.When a worked as a appliance repairman.Cheak with a hardware or appliance parts depot the part #430120 .Hope i helped:)
May 20, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer gives off a strong odor which make my clothes smell.
if you have been painting or staining recentley the chemicals in these products are mixing with the mercaptin in the gas to cause the odour. The problem will correct itself when the fumes are gone.
Nov 11, 2008 | Maytag MDG2706A Gas Dryer
Rust stains and bleach spots.
I'm sorry but the white spots will be due to bleach. It may be that there was undissolved bleach in the washer after the first load. Maybe some of it came out with the whites and lay in wait in the basket.
I doubt the makers would guarantee anything for 7 years, so no free basket or installation is likely. Seems there is a chip in the enamel and dampness / water from the previous wash days before sits there collecting iron as rust particles.
For the time being you could try rinsing the machine out before the first load. That might prevent the rust marks or reduce them.
May 01, 2008 | Kenmore 22422 Top Load Washer
Dryers Logo
144 people viewed this question
Top Dryers Experts
