Question about Home
Toilet flushes so slowly that the water is barely moving and the handle has to be held down nearly the whole time.
  • ardys749 Jul 14, 2010
    I'll try it, thanks.
  • 1,284 Answers
Hi, assuming that the capacity of the tank holds sufficient water to properly flush the toilet, it sounds like there is a partial obstruction in the soil pipe. Toilet flushing is toilet, nothing more than gravity pushing the water from the tank through the bowl and out the drain, carrying everything else in the bowl with it. If the pipe is clogged or partially clogged, it will result in a slow flow and will cause the problem you are describing. You make be able to use a plumber's snake to clear the obstruction yourself, but if it is too far down the pipe, you may need to enlist the aid of a plumber. I would invest in the snake first, before you spend the money on a plumber. A plumber's snake is readily available at any hardware store.
Take care
Posted on Jul 14, 2010
Why do I have to hold the handle down to get a complete flush? The pipes are all new from toilet to sewer. The toilet is 1 year old
The flapper has to be held wide open to allow sufficient volume of water to flush thoroughly.
May 11, 2017 | Home
Jacuzzi toilet
After flush the system must close the hole which lets water into the toilet. If it does not close after flush, it is continuously letting the water thru. Check if it closes after flush and allows tank to fill.
Jul 10, 2013 | Home
When flushingtoilet water backs up inshower
You can try this, get a bottle of liquid plumber industrial or pro, and pour the entire bottle into the pipe in the toilet, when you remove the toilet cover you see a pipe that has a water line in it from the fill valve, if you can't pour the liquid into this pipe, then turn off the water to the toilet, flush it and hold the handle until all the water has emptied out.
Now while holding the handle, pour the bottle into the hole where the stopper is open, the hole where the water goes down.
Wait a hour, then take a bucket of hot water and fill the toilet water tank, flush it, do this again.
Now turn the water back on and flush. If the shower still over flows, you will need a plumber to come and snake the main line from the toilet down until the clog is cleared.
Unless he finds a close access near the toilet if this is on the first floor and he can do it from the basement.
Apr 13, 2013 | Motorcycles
Flapper valve closes too quickly
Fill the breather hole (1/8" hole) inside the flapper.This is designed to let air out so the flapper will sink. Now it floats longer letting in more water. 25%percent more in my case.
Apr 22, 2012 | Home
Our Kohler K3402 suddenly stopped flushing. When you pull the handle and the flapper comes up, all that happens is the tank begins draining into the bowl and the bowl level rises, almost to the rim. The...
If there is a shower in the same bath is it also draining slowly?
If so check that drain systems air vent, (on the roof).
Find the pipe coming out of the roof nearest the bathroom with the problem and when a second person flushes the toilet you should be able to feel
air moving in and out of the pipe with your hand covering the end. If not the vent could be blocked by leaves or animals etc., this vent has to be clear in order for water to drain properly.
May 20, 2010 | Home
My dual flush toilet fills up slowly how do i fix
Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
Hope this helps!
Nov 08, 2009 | Home
WHEN TOILET IS FLUSHED PROPERLY NO PROBLEM,WHEN HANDLE IS HELD TO LONG IT LEAKS IN THE CEILING ,NO SIGN OF WATER ON THE FLOOR
The wax seal between Bowl and closet flange is bad. Disconnect water supply line, remove two hold down bolts, remove toilet (place toilet in bathtub, try to keep straight while moving, two people required) clean all old wax from bottom of bowl and closet flange (pipe) install new wax ring use one with a collar, reverse procedure for install.
Oct 07, 2009 | Home
I have a Eljer 150-403 and the toliet will not flush, although the handle is able to be moved down
Remove the tank lid and set it aside. Inside, you should see where tha handle passes into the tank. There should be an arm running along the inside of the tank that raises when the handle is pushed down. Attached to the end of the arm is a chain that goes down into the water and attaches to the flapper valve. Now that you have identified all of these parts, push down on the toilet flush valve, and you should be able to identify where the toilet is broken. It is most likely he flapper or the chain.
Shut the water off behind the toilet, at the wall. Slowly stick your hand into the tank, and raise the flapper. (Don't worry, this is clean water).
Let the water drain through the toilet, and make your repair. All oarts necessary are available at any hardware store. Take your old part with you.
Best regards, --W/D--
Aug 11, 2009 | Home
Toilet flushing
you either have the wrong flapper or it is not adjusted right try moving the chain to shorter or longer lenght the other thing to check is that your handle is not loose if you have to tighten handle be careful it is a reversed thread also check water level in tank
Apr 07, 2009 | American Standard Cadet 3 Right Height...
Home Logo
134 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
