Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool side by side 2005...make to much noice
My side by side 2005 whirlpool make to much noice, when compressor work. Do I need to check freon, or is something diferent? Thank you...
    Genius:
  • 1,073 Answers
Freon does not make a noise a compressor can if this noise is a knock then it is coming from the compressor and to solve it the compressor has to be changed
Posted on Apr 22, 2008
Compressor runs constant. whirl etomsrxtloo
Maybe low in Freon, inefficient compressor or partially restricted.
1.) Check the Freon level and add Freon if needed.,
2.) Check for leak and repair if any
3.) Change the dryer filter, pull a deep vacuum then charge the unit according to the manufacturer's recommendation. See the name plate for more info.
Note: skip all the above if compressor found inefficient.
Oct 31, 2013 | Whirlpool Refrigerators
Much freon c unit
There should be a sticker under the hood with the specs. If it does not have rear ac it should hold 3 or 4 cans if empty. You would use a gauge on the high side to check.
If you put too much in the high side pressure switch should cut power to the compressor clutch, but you could still damage the compressor.
Jul 04, 2013 | Ford Freestar Cars & Trucks
Compressor is running but not cooling.
A few things to check are is thier frost build up in the freezer?
or is the compressor not to hot,if it is hot it should be working ok
oddly enough if it isnt too hot its because all the refrigerant is leaked out and it doesnt have to work hard to pump it so its kinda cool,a compressor that is pumping the refrigerant (freon) its working hard and hot
Gene
Aug 11, 2011 | Whirlpool GS6NBEXR Side by Side...
Whirlpool model ed5fhgxkq03 side by side. Lights
check your temp controll to make sure it isnt broken or open circuit also your defrost timer could be stuck in defrost! next check your compressor for running and see if it is hot!! or just warm? if it is just warm and cycling /running then your low on freon due to a internal leak
Jan 14, 2010 | Whirlpool ED2FHEXN Side by Side...
Whirlpool refrigerator not cooling freezer seems to be working
my icemaker makes ice and water but the ice doesn't come out when pushing the button what is the problem?
Aug 30, 2009 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
I cand find out where to charge my 2000 e320
i had the same problem,,, it was from the compressor, u start with checking the gas pressure first, then u can replace the filter(black metal piece), if not solving the problem ,,,compressor has to be changed.
Jul 14, 2009 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Whirpool GS6SHAXLB03 Refrigerator or freezer do not cool.
This sounds like it's out of freon. Not just low but out. That clicking noise is a thermal overload shutting down the compressor. If you continue let it just click away it will burn this overload out and the compressor will have to be replaced. If the refrigerator just started doing this suddenly it could be that the compressor is locked up. If it has external capacitors either the start or run capacitor could be bad. If the capacitors are good then you could try a hard start kit to try to unlock the compressor.
Jun 30, 2009 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
I have side by side whirlpool,It quit working not
no it probably doesnt need freon. the noise your hearing is the compressor trying to start  due to either a bad start relay or a stuck compressor. on whirlpool refrigs the most common problem is bad relays this is a very easy part to replace and the part is in expensive. less than 70 dollars. the part number is 8201786 and the kit has very good instructions for doing it your self. if you have any questions please ask thanks Peyton
Mar 10, 2009 | Refrigerators
Whirlpool side-by-side melted relay.
Maytag (owned by Whirlpool since 2005) has issued a recall on the compressor relay due to fires. Whirlpool brands are not listed in the recall but it looks like they should be. The problem goes back to Jan 01 according to the Consumer Product Safety Comission.
Feb 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator admiral
Frost on the low side line means the system is overcharged (too much freon).  Look on the tag insided the fridge and it will tell you how much freon it holds.  Usually 4.25-5.50 ounces on average.  The loud noise sounds like you have air in the system.  I would evacuate, from the high side while running, and let it run empty for 5-10 minutes.  Then while running put the valve core back in the high side.  Then unplug the fridge and charge with proper amount of freon thru the high side.  Wait about 5-10 minutes and plug back in.  Normal low side pressure should be 0-3 psi.  This is a good indicator of the proper amount of freon in a good working system.
Oct 14, 2007 | Refrigerators
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
132 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
