Question about Dell 924 All-in-One InkJet Printer
Photo 924 printer paper jame
I have the same problem. paper jam but either no paper in printer or at least no paper jam. i don't understand that strange symbol or what # ? 9
you're talking about. is it on the printer some where? or on the computer?
is that f9 on the computer? unpluged the printer and repluged the printer
to no avail.
thanks,
mark
  • angiivy May 07, 2008
    I have the same problem, paper jam and there is no paper jammed. I have pushed the start button and to no avail it does not do anything. Continues to tell me there is a paper jam. I have taken this thing apart trying to fix. Help.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When printer does not have visible paper jam and printer is showing error paper jam
Check if the Encoder Strip is Broken or Missing
1.Power down the printer and unplug the power.
2.Slide the cartridge carrier inside the printer a couple of inches to the left.
3.Locate the encoder strip (Figure 1) on the right-side of the cartridge carrier encoder strip
Note:
The encoder strip is a plastic strip with small markings over its entire length. The strip may appear to be translucent.
Reposition the Encoder Strip
1. Remove the power cord from the printer.
2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
3. Gently slide the ink cartridge carrier to the middle of the printer.
4. Gently move the top part of the printer belt to the right.
5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the scanner lid.
9. Re-connect the power cord to the printer.
Ensure the Paper Tray is Not Overfilled
Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray.
Adjust the Printer Paper Guides
Adjust the paper guides to fit the size paper being used .The guides should be close (1/16" or less) to the paper without touching, so that the paper stays properly aligned without continually rubbing the guides.
Locate and Remove Any Obstructions Inside the Printer and Input Tray
1. Open the front cover and make sure the kickstand (if there is one) is engaged.
2. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects.
3. Close the cover.
4. Remove all paper from the input tray.
5. Inspect the input tray for any obstructions.\
6. Remove any visible obstructions.
7. Reinsert the paper.
Posted on Nov 07, 2008
  • Damanpreet Chand
    Damanpreet Chand Nov 07, 2008
    Clean the
    paper feed roller on the printer.
    1. Power down the printer and disconnect the
    power cord.
    2. Remove all paper from the input tray.
    3. Wipe the roller gently with a damp cloth.
    Reseat
    the Dell Printer Power Adapter.
    If your
    printer has a momentary loss of communication with your computer, it may be
    necessary to reset the printer to re-establish communication. You can reset a
    printer by unplugging the printer power cord from the electrical outlet and
    from the back of the printer for 10 seconds then reattaching the cord at both
    ends.
    If yes
    then get it replaced.....or else get a new printer
    Check
    with manufacturer if printer is still covered under warranty...
SOURCE:
It says my printer has a paper jam but i dont see no paper jamed and i refill it and it says say thing like it would let it go like its going to print then says jamed paper
Try and see if you can locate a small piece of paper that might be causing your printer to jam. Turn the rollers and see if you can see any small pieces of paper stuck in between the rollers.
Mar 02, 2011 | Canon Pixma iP2600 Photo InkJet Printer
My dell All-in-one keeps syaing it is jamed but there is no paper in. I have done everything that the web cite tells me too and it is still saying it is jamed.
Printers are a pain. Having said that, if there is a sensor claiming to have a paper jam, then it is one of 2 things: a piece of paper or debris that you dont see, or, a failed sensor. If you cannot clear the jam, you likely have a failed sensor. If you have a failed sensor, your easiest option is replace that printer. If you replace it with an identical model, you wont need to buy anything extra, you can use the same carts and plugs and discs as before. Check ebay or such places for your model. Someone may have one for you.
Oct 26, 2009 | Dell 924 All-in-One InkJet Printer
Paper jams when printing
just add some more paper to the tray..and arrange it properly..
i think the paper pick mechanism failed to pick the paper.or there is a long time delay before the paper reach the printing area..
thanks for using FIXYA!
pls let me know if it solve the problem..
May 21, 2009 | Dell 924 All-in-One InkJet Printer
Paper is stuck and i can't get to it
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
May 19, 2009 | Dell 924 All-in-One InkJet Printer
What is a Carrier Jam?
You might have lost a little spring. Can you possibly return it to the store where you got it?
May 16, 2009 | Dell 924 All-in-One InkJet Printer
PAPER JAM !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Since when the printer not picking up paper from tray or sheet feeder.
Check if the Cover are firmly closed, also look out for any piece of paper jammed the printer.
If it is ok, then check to move the carriage of cartridge/roller and clean it out if you can.
The spring of tray attached on both side may be need to check.
Let me know if I can assist you further.
Oct 01, 2008 | Dell 924 All-in-One InkJet Printer
Photo paper jam
u need to bye photo paper from the hp store the other paper come thik that y there the jamed so u need to go hp store to bue photo paper for hp u use other paper the your printer has been damged
Sep 03, 2008 | HP PSC 1350v All-In-One InkJet Printer
below the opening part to take a copy you open it, the cartridges will move to a side automatically. There you will be able to see the paper.
May 03, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
238 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
