Question about Sony Cyber-shot DSC-H9 Digital Camera
Camera switches on its own while looking at photos
    Scholar:
  • 41 Answers
You may try Initializing the Camera to check whether the issue is resolved.
The steps to Initialize the Camera:
Press the HOME button.
Select the "Settings" option.
Select "Main Settings"
Select "Main Settings1"
Select "Initialize".
Now select OK.
This should resolve the issue.
Posted on Jul 14, 2010
Camera mode takes blank photos
Is the lens cover open? (Make sure battery is fully charged) go into the menu and reset the camera make sure it's switched to auto and try again. I assume you have looked at the photos on a monitor? If they are absolutely black with no noise it's the processor.
Apr 04, 2014 | Nikon Coolpix S560 Digital Camera
Blurred photos
You should check to ensure the camera is set on Auto Focus. Might be a switch on the body.
Jan 05, 2014 | Samsung ST600 Digital Camera
There is a line appearing from the center of the view finder till the end. This comes on only when the camera is switched on
if the line came in photos when you seen them from PC then its a Camera CCD fault, Or If the photo clear in PC view then its a LCD fault.
Aug 04, 2012 | Nikon D70S Digital Camera with AF 28-80mm...
Cyber shot camera dscw350 cannot take pics read only memory card
Look at your memory card or stick.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. Memory sticks have a slide switch just below the contacts. Slide the switch away from the "LOCK" position to unlock the memory stick.
May 17, 2012 | Sony Cybershot DSCW350 Digital Camera
Can't view photos on camera screen
Hello Celia.
Try going to the menu and look for the "storage" setting. Check to see if it is set on memory card or internal. Switch the setting to see if you can access the photos.
If this doesn't work your 30 photos may be in a folder "type" your Canon cant access. Try moving them to a "Canon" folder that your camera created.
Hopr this helps. Dale
Dec 21, 2011 | Canon IXUS 960 IS Digital Camera
Hi, My canon PowerShot A540 camera gives an error " Card locked" Memory card error. I tried switching off the lock, but it didn't help. The card does not get recognized while inserting it in...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
You also mention recovering photos saved on the card. If you actually did take pictures with this card (assuming it's a 2GB or less standard SD card, as 4GB SDHC was not designed for your camera), you may be able to recover the photos using recovery software. See this other link.
Jun 10, 2011 | Canon PowerShot A540 Digital Camera
Communication Error when uploading photos
You may have switched USB mode to Pictbridge by mistake.
Press Menu/OK, select Setup, choose USB mode (on 3rd page) switch from Pictbridge to DSC, press OK.
Oct 05, 2009 | Fuji FinePix S1000FD Digital Camera
I turn the camera on and the screen shows blue with a no image sign. Is it stuck in some mode where its looking for photos? The card is clean and empty. I cannot take any photos. I also use a...
Check the mode selection switch. It should be adjusted in the mode you desire to work. Also click the shot button and keep it pressed for about 2 seconds. If still not working properly then switch off the Camera and remove the battery and replace it after about 2 to 3 minutes and then try again.
Jan 23, 2009 | Fuji FinePix S5000 Digital Camera
I receive a 'write error' message after I take a photo
There should be a little switch on your memory card when you pull it out. Slide the switch the opposite direction. The switch is very small and usually on one of the edges/sides. This is similar to how floppy disks had a write protection on them.
Jan 12, 2009 | Fuji Rod Repair Kit
DOWNLOADING PICTURES
Photo transfer problems are as likely to be related to software as to hardware. If you use photo-editing software other than what came with your camera, check the software's documentation and Web site to see if the manufacturer supports your camera. Download and install any software updates, as well.
If your photo-editing software can't detect your camera, make sure your camera is attached, turned on, and, if necessary, switched to transfer mode. Double-click the My Computer icon and look for an icon that corresponds to your camera. If you see an icon for your camera, you know that Windows detects your camera and that the problem is related to your photo-editing software.
Feb 27, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony Cyber-shot  DSC-H9 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
