Question about Intel D945GCCR Motherboard
Ram problem i thnk so
Every time i start the pc na a blurd screen appears after 2-3 mins...wer i pc gets hanged nd screen becomed sm doted like thng....nd whn i move the ram to rght side na little with a force it appears normal nd thn hve to restart the computer..it appears every time whn i start the comp..nd sm msg come sm times ki if this is ur 1st time like this restart it nd al..so can i knw the solution fr it plzz...
  • Intel Master
  • 11,800 Answers
A program that is required for Windows to run is corrupted and the best way of fixing that is to reinstall.
Posted on Jul 14, 2010
My phone micromax canvas elanza 2 A121 getting hanged, screen goes off,power button dosnt work if we required to reboot.The only solution is remove back cover nd the battery ,again fit the battery nd then...
better to do factory reset to the mobile.....
before u do...please take a backup of ur contacts,messages,picures, videos etc etc.....nd do
Oct 25, 2014 | Cell Phones
Why my acer laptop is always hang and not responding and if you click again it becomes a blurd what can i do?thanks
better you format your laptop once and re install the windows. it will work fine.
if satisfied with the answer please rate it .
Jul 18, 2011 | Acer Computers & Internet
My laptop is Wipro brand. I have been using it for last 2.5 years. Since a couple of months I am facing a problem of being hanged up. Anytime the screen gets sparked and colors of the screen starts...
Definitely overheating, and I would say especially if its a gaming laptop of the video chip, try taking a vacuum cleaner (pipe type) to the vents as they have probably built up a lot of dust and fluff over the years, if that does not sort it out, I would take it to a repairer, its a simple job of cleaning the insides, but taking a laptop to bits is thwart with danger as there are thin ribbon cables and connectors that break easily when you are trying to separate some of the click in parts, without experience.
May 09, 2011 | Computers & Internet
This is definetely not a software issue. You are facing either:
A) Bad LCD screen or inverter board
These can be replaced quite easily as they are both held in by a number of small screws.
B) GPU Hardware fault
Normally caused by excessive heat. This melts the solder around or in the GPU chip and causes it to malfunction as you described. This can be fixed by painstakingly removing your motherboard and resoldering the GPU chip. It is not garaunteed and getting a new laptop is much easier.
C) (unlikely) Driver issues.
Download the latest drivers for your screen/GPU from the manufacturer.
Hi, i hv wipro notebook, Model no. 7B1630 now a days i m having some strange problem with my notebook. the problem are: it's hard to start.i hv press the key 1-2 min. if it start then after few...
Your random access memory (RAM) is faulty or badly connected. Unscrew and open the cover at the bottom of the laptop, pull two latches to the side and the ram module will tilt upwards. Remove it from the connector, wipe the connecting plates of the ram with rubber to get them shine and install back. If the problem persist, use hiren boot cd, start the GoldMem program to test the ram. If faulty, replce it. If the probem persist again then motherboard is faulty and needs replacement.
Aug 07, 2010 | Computers & Internet
No display on lcd screen
check for lcd invertor if its ok its problem of vga chip
2 ways to solve
1) go to nearby service center which they just replace the motherboard
2) more risky bt work dissamble the whole laptop nd all accries from the motherboard including the cpu ram wifi card nd also black sheet from the main board then place the board in microvave where the vga chip is on the top nd microvave for 6 min at temp of 350 -390 f
now try the run the board
Jun 29, 2010 | IBM ThinkPad T42 Notebook
Hard drive light flashes 10 time, but screen does not power on
man jst remove ur ram nd use a eraser rub the ram then insert the ram properly nd also check ur cmos battery.......ur work is done....
Aug 30, 2009 | E-Machines eMachines Desktop PC
Trying to Install Windows
Refix your RAM memory .
Aslo reconnect harddisk power cable and ide or sata cable.
I also face same problem in my pc i saort oout with Refix RAM memory.
Jul 29, 2009 | Computers & Internet
Screen flickers
ram problem once clean the ram and insert it again if the problem occurs again the change ur ram it will rectifye ur problem
Jan 22, 2009 | HP Pavilion MX70 17" CRT Monitor
Laptop screen blurred, doted lines
HOW TO SOLVE THE PROBLEM OF LAPTOP SCREEN IS BLURD?
Dec 28, 2008 | Computers & Internet
Intel D945GCCR Motherboard Logo
49 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
