Question about Water Tech Pool Buster Pool Cleaner
Blue diamond pool cleaner goes to deep end of pool and just keeps going back and forth for the whole cycle
I have a jandy ray vac pool cleaner that just goes in circles in the deep end of the pool.
look at instruction manual there is a setting you probably have to set
Jun 01, 2014 | Pool & Spa
Automatic cleaner won't do the whole pool? Keeps skipping big patches?
use the diagnostic system in accordign with the inst.manual or download free www. retrevo.com or www.fitness.manualsonline.com
God bless you
Jun 19, 2012 | Dirt Devil Rampage Robotic Pool Cleaner...
New navigator stays in deep end 99% of time, comes to shallow end, turns around & goes back to deep end
If your filter is placed toward the deep end of your pool, it could be that the pool cleaners hose is too short to reach the shallow end. You might want to test it and add more hose if necessary. It could also be a steering failure. There are a couple things to check if this is happening. Check and clean the rear screen. Make sure that your cone gear is free and rotates smoothly. You might also need to clean, repair, or replace your gearbox.
Jul 18, 2011 | Hayward Navigator Pool Cleaner
My kreepy keeps coiling at the deep end of pool and stays there what do i need to do so that it cleans the whole pool?
There are a couple of things that you can try to get your pool cleaner to cover both ends of the pool. First, use an eyeball diverter to make sure that your water flow is correct to make the pool cleaner function in the proper pattern. Your return lines could be pushing the cleaner only toward your deep end. Secondly, if your hose is connected to your filter at the deep end of the pool, it could be that your hose is not long enough to cover the entire pool. You might need to add hose lengths. You will also want to adjust your hose weights.
Jul 16, 2011 | Universal Kreepy Krauly In-Ground Pool...
Vac gets stuck in deep end and can't get to shallow end
What type of pool do you have? These specific pool cleaners are made for flat bottomed above ground pools. They are not made to move from deep end to shallow end. If you are using this on an in ground pool that has both shallow and deep or a dished above ground pool, you are not going to get accurate cleaning.
Mar 06, 2011 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
My barracuda stays in the deep end and will not move to the shallow end of the pool
You probably just need to redirect the returns in the pool. If they are angled right (or wrong) they will get a current moving in the pool and cause the cleaner to go to one spot and keep it in just that area of the pool.
Oct 30, 2010 | Zodiac Baracuda Zippy Pool Cleaner
Kreepy cleans the deep end great. It cleans the walls and bottom but will not venture up the slant to the shallow end
There are several things that could cause these automatic pool cleaners to have this problem. First, check the return line water flor and redirect it if necessary. Also, make sure that the hose is long enough to cover the entire pool without difficulty. Also, check the hose balance to make sure that it is correct.
Jun 22, 2010 | Universal Kreepy Krauly In-Ground Pool...
Does not clean the whole pool
may need to re-weight it or add helpers.
I had to add a rope system to my pool to get the creepy crawly to all the spots.
Not the best fix - but keeps the pool clean.
Apr 10, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac baracuda wont go to shallow end of pool
If you can, adjust your intake valves so more of the suction is coming from your vacuum and less from your skimmers. This will allow the the vacuum to climb out of the deep end.
Mar 22, 2009 | Zodiac Baracuda G3 Automatic In Ground...
Water Tech Pool Buster Pool Cleaner Logo
48 people viewed this question
Top Water Tech Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Water Tech Pool and Spa Expert? Answer questions, earn points and help others
