Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Door weight or spring no longer works
I have had this Jetclean dishwasher for over 16 years. Just recently the door has begun to feel different. It feels very heavy and drops hart. Are there springs or weights of some kind that can be replaced?
  • 1,998 Answers
Yes tere are springs and a small pulley system located on both sides on the bottom you can order the parts and have the sent to you directly by looking up marcone appliance when u order the parts order both springs and also order the pulleys as a kit whcih also comes with the corded returns new also if you dont order them as a kit r ask for the kit you end paying more for just the pulleys alone and you might find one of those returns are broken good idea to have allthe parts replaced the first time when you do the job shut off the power diesconnect the screws that hold your dishwasher in place and pull the entire unit outward make sure u have shut off the water supply and that your hose to the water inlet vavle is long enough to be pulled outward. when you pull the unit out you willbe able to see both bottom sides and will most likely find a broken pulley or return hope this helps
Posted on Jul 14, 2010
Testimonial: "thanks - this was great information. "
Dishwasher door no longer spring loaded. If standing too close, it if hurt your legs. it will stay closed, but no spring to load the weight of the door when opening.
In most cases, there are 2 springs inside the door, one right and one left.
Either a spring has broken, or the metal; holder that holds the end of the spring has.
That spring should be available from "searspartsdirect" if you will type your model number into their web-site.
God bless your efforts.
Mar 19, 2018 | Dishwashers
Miele dishwasher door not working properly
Try contacting Miele with the model & serial number of your appliance they will send you out a new spring.
they are in scoresby from memory fern tree gully rd.
Mar 29, 2014 | Miele Dishwashers
I've just installed a Miele 5500SCU Dishwasher and the springs that support the door cant be adjusted far enough to take the weight of the door, does anyone have any suggestions?
If the dishwasher is brand new, then there is an issue with the configuration of the springs, i.e not mounted correctly. A factory dishwasher door should not need to be adjusted. However if it is older, it is possible that the springs came off, in which case they can be seen from the underside of the dishwasher and by a panel that unscrews on the bottom of the door. Make sure the springs are there.
Dec 30, 2012 | Miele Dishwashers
I have a 13 year old Maytag that works great. But recently the flipper door that dispences the dry detergent doesn't open during the wash cycle. I've tried cleaning it thoroughly, but that hasn't made a...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 17, 2010 | Maytag 24 in. MDB6600A Jetclean II...
Cannot open the door of the dishwasher.
  • The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
  • If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
  • Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
May 04, 2010 | Maytag 24" Tall Tub Built-In Dishwasher -...
My built in dishwasher door will no longer stay part way open it went klunk when I left it barely open and now feels like it weights a ton. All the controls are on the to edge and it has a huge handle that...
hi there......you havent stated which tye or model your appliance is...however it sounds like your door spring /suspension cords or cable have broken....on some appliances their replacement is quite simple..however be warned other tyes are quite involved
regards Sir Galahad
Aug 13, 2009 | Kenmore Dishwashers
38 year old kitchenaid KDI-16 imperial dishwasher
yep you can just get springs from lowes or home dept or your local hardware store; they're often in with the hardware (i.e., screws) and not plumbing. remember that the springs need to stretch out a bit, too; so you may end up buying springs that look shorter than they should, but they eventually habituate.
Jul 07, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Maytag dishwasher heavy door (broken door spring(s))?
Hi thanks for the question. to repair . bottom kick plate must be removed ,to get to the door springs .4 screws . remove them. springs on each side . replace them thanks the appliance doc.
Oct 06, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Mdb7601aws dishwasher door drops down
hi there,
go to www.whirlpoolparts.ca to get the exploded view for your model #. it will be the located under Repair Parts.
May 31, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
171 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
