Question about Hitachi 50GX30B 50". Rear Projection Television
Digital Aray is off. We are seeing 3 or 4 of each image. Each one a different color.
  • 905 Answers
Your convergence is very "way off."
You should be able to adjust it by going through the menus until you find the one option for adjusting convergence.
Note that this allows a finite amount of adjustment. If the television was dropped or roughly handled, a mechanical alignment may be in order. Preferably by a tech that makes house calls to minimize the amount of movement and reducing chances of reoccurring.
Posted on Jul 14, 2010
Seeing to colors (red green) at top of tv
Posted on Jul 19, 2010
Where can I get a readable user manual?
Digital Cameras beginner guide
Digital Cameras - A beginner's guide by Bob Atkins, 2003
Digital Camera Basics - A primer Digital cameras are confusing to a lot of new users. In this basic guide to digital camera technology we hope to try to give digital beginners at least some basis to use in deciding which digital camera is appropriate for them. When shopping for a digital camera it's at least good to know what the basic terms like white balance, pixel, ppi and dpi mean and how they affect image and print quality. It's also important to know the difference between things like optical zoom and digital zoom as well as the advantages and disadvantages between storage formats such as Compact Flash (CF), Microdrives, Sony Memory Stick, Secure Digital (SD), Multimedia and camera interface technologies such as USB 1.1, USB 2.0 and Firewire IEEE 1394.
Pixels A pixel is a contraction if the term PIcture ELement. Digital images are made up of small squares, just like a tile mosaic on your kitchen or bathroom wall. Though a digital photograph looks smooth and continuous just like a regular photograph, it's actually composed of millions of tiny squares as shown below.
Each pixel in the image has a numerical value of between 0 and 255 and is made up of three color channels. So for example a pixel could be 37-red, 76-green and 125-blue and it would then look like this . If it was 162-red, 27-green and 12-blue, it would look like this . There are over 16 million possible combinations using this scheme and each one represents a different color. Computer savvy readers will note that each color in this scheme can be represented by an 8-bit number (byte), so the color of each pixel is defined by three color bytes. This scheme can be expanded, for example to use 16-bits (two 8-bit bytes) for each color. images using three 8-bit values are sometimes called 24-bit color images. images using three 12-bit values for color definition are called 36-bit color images, and those using three 16-bit values are called 48-bit color images.
Pixel Count One of the main ways that manufacturers categorize their digital cameras is in terms of pixel count. What this is is the number of individual pixels that go into making each image. Today this number varies between 1 million (1 Megapixel) to around 14 million (14 Megapixels). A million pixels is abbreviated to MP, so a 1MP camera has 1 million pixels and a 3MP camera has 3 million pixels. Currently most popular consumer digital cameras have between 2MP and 5MP. A 3MP camera can make excellent 4"x6" prints and very good 5"x7" prints. If you intend to make lots of 8"x10" prints, then perhaps a 4MP or 5MP camera would be a better choice. Sometimes two numbers are given, total pixels and effective pixels. Total pixels count every pixel on the sensor surface. Usually the very edge pixels aren't used in the final image. Effective pixels are the number of pixels actually used in the image after the edge pixels have been dropped.
Aspect Ratio The aspect ratio of a camera is the ratio of the length of the sides of the images. For example, a traditional 35mm film frame is approximately 36mm wide and 24mm HIGH. This has an aspect ratio of 36:24, which can equally well be expressed as 3:2. Some digicams use the same aspect ratio for their digital images. For example most digital SLR (single lens reflex) cameras have a 3:2 aspect ratio. However, video monitors typically use a 4:3 aspect ratio. For example a monitor with a 800x600 display has a 4:3 aspect ratio. With this in mind, most consumer level digicams use a 4:3 aspect ratio for their images.
Sensor Size The size of the digital sensor element (which is equivalent to the size of the negative for film cameras) is pretty small in all consumer digicams - typically around the size of a fingernail (and a small fingernail at that!). As I said above, a 35mm film frame is 24mm high by 36mm wide but most digital cameras use sensors very much smaller than this. Here are some typical digicam sensor sizes. The "name" of the sensor is based on specification for old TV tubes used in the 1950s. Nobody is quite sure why it's being used for modern digital sensors since the "sizes" don't really relate in any consistent way to the actual physical size of the sensor. However these names are widely used, so it's best to know what they are. They are often listed in digital camera spec sheets.
for more info click on link above.
Jun 23, 2015 | Cameras
Fix 3way switch
Feb 2013
1) Copy following link for 3-way switch wiring
http://waterheatertimer.org/How-to-wire-switches.html#3-way
http://waterheatertimer.org/images/Switch-quick-connect-400.jpg
2) Usually a bad switch is replaced.
Buy another 3-way switch.
New switch will have 3 screws (plus green ground screw which is not discussed further).
On new switch, 1 screw will be different color from other two screws.
Same thing with old switch: 1 screw will be different color.
Take wire on different color screw and connect to different color screw on new switch.
Other two wires can connect to either screw.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 02, 2013 | Electrical Supplies
Outside the image in 1080 looks fine. Inside the sensitivity is horrible and color balance is off. ANy settings that I can adjust?
Sorry. That's the way that the GoPro is. It's designed for outside use and the color balance is daylight only. It needs lots of light. If you need to be able to change color balance or work in more limited light conditions then you'll have to get a different camera and housing.
Apr 16, 2011 | GoPro Digital Hero 3 Digital Camera
I shoot RAW/basic jpg. I review them there is a contrast differen
This is normal. Bear in mind that the JPEG file has all the image processing done, while the RAW is just the raw data. Depending on your image settings (contrast, saturation, sharpening, etc) you may see some differences.
Nov 24, 2009 | Nikon D200 Digital Camera with Nikkor AF-S...
Imags have colur disfiguration
If the pictures look normal when viewing them on the camera but have this color distortion afer downloading them to the computer it sounds like they are getting corrupted during the transfer. Try a different USB cable if you can or try downloading them to a different computer to see if the problem persists and if the same images are displaying the same problems.
Best regards,
Bob
May 28, 2009 | Canon PowerShot A590 IS Digital Camera
Hdtv function only out of focus
Most have HDTV Converter Box with component, Going to RGB Cmp1 or 2 a composite output cable box will not work.
Oct 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Fun! Flash 640 camera specifications
Optics ? 7.0mm, F 3.0 (40mm: 35mm equivalent) lens ? Focal range 20" - infinity ? CMOS image sensor ? Automatic exposure system ? 1.8" color LCD display monitor ? 1/8 - 1/1000 second exposure control ? Flash range: 3-6' images ? Color: 24-bit (millions of colors) True Color ? JPEG compression ? 2 image resolution modes: 640 x 480; 320 x 240 Storage, Interfaces, and Power ? 2 MB internal memory ? Typical image storage capacity: 15 images (640 x 480); 50 images (320 x 240) ? Serial interface: RS-232 ? 4 AA-type alkaline batteries User Controls and Other Features ? Automatic self-timer ? Tripod mountable ? Automatic power saving mode Physical ? Dimension: 4.25"(l) x 1.63" (w) x 3.13" (h) ? Weight: 8 oz. (approximate without batteries)
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
What is the Digital Effects Control (DEC)?
With this function, you can adjust exposure, contrast, and saturation through the viewfinder itself, prior to image capture. You can check how your adjustments will look using either the viewfinder or the LCD monitor. This feature makes it easy to get the unique images you want in many different shooting situations. DiMAGE 7i is capable of setting contrast, color saturation and filter in the following increments. Contrast: In seven levels from -3 to +3 Color Saturation: In seven levels from -3 to +3 Filter: In seven levels ranging from warm (reddish) to cool (bluish) colors.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Hitachi 50GX30B 50". Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
