Hi, I have a newly purchased LG BD 370 from the US and it has a region code of 1, i am in India and what to make this player region free, i tried out all the options in the forums, but nothing worked. Can this player be made region free. Thanks, Amit
  • AMIT SHARMA Jul 14, 2010
    The below solution did not work from some other expert so i need assistance.
    "Hi Amit,
    Thanks for using FixYa. LG BD370 player can be made region free my applying some mods and tweaks on it. To make it region free you'll need to download a firmware and install that on your player and after that you can make it region free. The firmware can be downloaded from this link---
    LG BD370 region free firmware
    After downloading it, unzip the file and you'll see a RMTM0000 file (not the text file but the other file). Now use a CD/DVD burner program that can make .ISO files(CD/DVD Image files). You can download this kind of software from this link---
    ISO burning Software
    After downloading this, install the software and burn the folder 'RMTM0000' to a CD-R making sure that the directories stay in order Insert the disk into your player, you will then be presented with a region change menu. Select desired region (0 for all regions). Please do accept the solution if the issue is resolved or post a comment for further assistance."
  • 4,806 Answers
Yes the player can be made region free.
To set DVD Region to “any”, download file “6000.zip” (often also called “LG6000.zip”) from this link:
http://www.multi-region.net/_media/6000.zip
Save the file and then unzip and extract it to your hard drive. Now burn the subdirectory RMTM0000 and its contents (not the text file) onto a blank CD-ROM (ISO format, “closed” CD-ROM). Unplug any ethernet cables and insert CD-ROM into the LG BD 370 P player, and when the Region Management System screen is displayed, set the Region Code to “0” using your remote. Once done, press “PAUSE” on you remote to save, and you’re done!
NOTE: You must close the session on the disc. These are ESSENTIAL points if you want this region code to work!!! I recommend Nero burning suit for this as it allows the sessions to be closed. You can download a free demo version of the software from Nero.com
If you have the latest firmware on the unit you may have to downgrade the firmware first to apply the region free code. Download an older firmware from the link below and try the CD again.
http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=BD370&initialTab=drivers
If this does not work please post back for an alternative.
Good luck and thanks for choosing FixYa
Posted on Jul 14, 2010
  • 19 more comments
    I had tried to downgrade the software. Downloaded from LG site and have put it in the USB drive and tried to downgrade but it does not alllow me to downgrade.
    Did did the CD-ROM with closed session and .ISO format, the CD-ROM is not recognized and the LG Blu-Ray throws it out saying "Check Disc!".
    Rgds,]
    Amit
  • Lee Hodgson
    Lee Hodgson Jul 14, 2010
    Hi again,
    Download the file Special_firmware(V3[1].886.01)_for_V3.886.00.zip from LG's site.
    Turn off the DVD unit. Copy the File : LG_BD_370M.ROM (size 26.809.552 Byte) to a simple blank USB
    Stick.
    Power on the BD370 and Plug the Stick to USB Port
    Upgrade" Screen appears. - > Do the Downgrade to V3......
    Unit will Reboot - Power manually on again.
    Now pop the correctly burned disk into the drive and try the region hack again.
    Let me know if you have anymore problems.
  • Lee Hodgson
    Just a quick note: If it downgrades the firmware this time and after you have changed the region code you should upgrade to V7... again via Lan or USB. There should be no probs to the changed
    region code as it seems to be stored elsewhere in the machine´s memory.
    Good luck!!!!
    After i inserted the USB stick no "Upgrade Screen" appeared.
    Thanks,
    Amit
  • Lee Hodgson
    Lets try this again.
    I take it the file you have downloaded is Special_firmware_for_V3.886.00.zip and the file inside once extracted is LG_BD_370M.ROM yes?
    If so reformat a memory pen and just copy the LG_BD_370M.ROM to it.
    Turn on the player, wait until menu shows up, then insert USB stick and downgrade
    the firmware to V3.
    Let me know how you get on.
    I reformatted the USB and copied the LG_BD_370M.ROM to it. Started my Blu-Ray player and waited for the menu to appear, and then inserted the USB it detected the USB but nothing appeared on the screen for Version downgrading.
    Thanks
    Amit
  • Lee Hodgson
    Is there an option to upgrade? If so choose that because it won't say downgrade.
    It will ask for a upgrade if i plug in the ethernet cable and unfortunately i do not have that arrangement right now so i cannot upgrade also.
    Thanks,
    Amit
  • Lee Hodgson
    You don't want the ethernet cable in anway at this point. We need to get the player to downgrade before you can upgrade it.
    Try it this way >>>>> turn off the unit, plug in the USB, then turn it on again.
    I tried that also, and the USB is not recognized, the USB is only recognized when after the menu appears and the USB is plugged in.
    Thanks,
    Amit
  • Lee Hodgson
    Hi Amit.
    Try it again that way then. If its ask's to be upgraded then choose that option.
    I just have to take my dogs for their business, i'll be around 20 mins or so.
    Good luck, i hope it succeeds this time round.
  • AMIT SHARMA Jul 15, 2010
    If i change the file name from LG_BD_370M.ROM to LG_BD_370VBB.ROM the update screen appears but the S/W Version shows junk characters and when i press update button it says "Update Failed" and switches off the DVD.
    Rgds,
    Amit
  • Lee Hodgson
    Lee Hodgson Jul 15, 2010
    Try the Canadian version instead seeing as Canada is North America. Reformat the disk and copy the file to it don't rename the file >>>>>>
    http://www.lg.com/ca_en/support/product/...
    Remember its the special update.
    To see the system config Go to Setup -> TV Aspect ->
    Select 16:9 (original) -> 1 3 9 7 1 3 9 -> Enter
    and see if there is a letter after the model number and post back with it
    If this doesn't work let me know and i'll look into this further as this hack should work
    Following are the details
    Model Name: BD 370V
    Driver Version: H51000
    SW Version: BD 7.0.8.016.B
    Rgds,
    Amit
  • Lee Hodgson
    Hi Amit,
    I need some time to trouble shoot this problem, probably later on today if thats ok? Try the canadian versions as i posted before because some players are sold as american when they're really canadian.
    I tried the Canadian also, but it did not recognizethe .ROM file in the USB.
    Rgds,
    Amit
  • Lee Hodgson
    Hi again Amit,
    The V at the end of the model number stands for the states, possibly North America so i've been told.
    After trawling the internet and talking with friends i have found the USA support website for this player.
    Download both the files and try the special one first using the methods described, you might have to change the file name again.
    Also in the latest update there 2 files. One of those may revert to an older version of software allowing you to use the special downgrade.
    If it allows the downgrade from the American site the use the CD to unlock the player.
    Link here >>>
    http://www.lg.com/us/support/product/sup...
    Again Amit, very good luck.
    One file will update to 8.08 and the other will upgrade to 8.16, none will downgrade. My s/w currently is 7.08. So what shld i do now.
    Thanks
    Amit
  • Lee Hodgson
    Hi Amit,
    I wouldn't use the any of the newer S/W just yet.
    Have you tried the special firmware from the American site yet?
    If you have and it didn't work try renaming the ROM file like you did before.
    Yes i tried that same thing happened some junk characters where displayed in the S/W version and it failed to update.
    Rgds,
    Amit
  • Lee Hodgson
    Hi Amit,
    This has me flabbergasted!! I don't understand why this is not working. The hack should work on on player because of the software version.
    I can only think of one thing to try now.
    Click on the link and download the 6000.zip file extract the files and place the kpjc19_1.dvd file on your empty flash drive and place it in the player. See if the Region Management System screen is
    press “PAUSE” on you remote to save it.
    http://www.multi-region.net/_media/6000....
    If it doesn't burn a CD off using Write mode: ISO Level 1, Mode 1, ISO
    9660 to finalize it.
    You can get the CDburnerXP software from this link>>>>
    http://cdburnerxp.se/download.php
    If this still does not work then its a possibility that your software version won't allow a region change or downgrade.
    Brigadier General:
  • 8,619 Answers
Hi Amit,
Thanks
Rylee
    I had burned the CD @8x speed close session was checked. My LG player did not recognize the disc it said Check Disc! and the disc came out.
    The solution did not work do u have something else.
    Rgds
    Amit
How do you unlock region code on Samsung BD-H6500 smart blue- ray player
The hack for this 3D Blu Ray player is the same as for previous models.
1. Make sure NO disc or usb stick is inserted into the player.
2. Turn on your your blu ray player.
3. When the main menu appears, press the REPEAT button followed by the region code your player is currently locked to - depending on which country
you are in (eg: in Australia press "REPEAT 7 6 8 8 4".
4. In the top right corner you will see your region code flash (eg: 4 for Australia).
5. Press 9.
6. Turn off and on and your BD-E6500 is now region free.
How this differs from the opening post is no need to open and close the disc tray.
So, after pressing REPEAT please enter one of the following codes the matches your current region lock:
1 - 2 9 3 3 4 (US)
2 - 5 7 5 3 8 (Europe)
3 - 5 6 7 3 2 (South East Asia)
4 - 7 6 8 8 4 (Australia / South America)
5 - 5 3 8 1 4 (India, Ukraine, Belarus, Russia, Africa)
6 - 2 4 4 6 2 (China)
9 - Region Free
Then press '9' and your player is region free.
Jan 12, 2016 | Samsung Televison & Video
MAKING A SAMSUNG HT-F6500W REGION-FREE
1) Switch Player off then On (this is to clean-boot firmware).
2) Wait until main menu appears
3) Open Disc Tray and Close Disc Tray (May not be necessary)
4) As soon as "No Disc" is displayed quickly press REPEAT on
remote quickly use the following code for your current
region:
Region 1: Press - 2,9,3,3,4
Region 2: Press - 5,7,5,3,8
Region 3: Press - 5,6,7,3,2
Region 4: Press - 7,6,8,8,4
Region 5: Press - 5,3,8,1,4
Region 6: Press - 2,4,4,6,2
5) Your current Region will appear in the top-right corner
6) Quickly Press "9" before it disappears (It should replace
the code with a "9" in the corner)
7) Switch Player Off and then On again.
Note that REPEAT is part of the code so one smooth press of
6 keys is required.
There isn`t currently a region hack for Blue-Ray Disks
Dec 27, 2013 | Samsung HT-F6500W/ZA Home Theater System -...
How to make player region free
You can not. You need a multi region player or by the specific region player
May 14, 2013 | Televison & Video
I just bought an LG BD-550 and I want to make it region free. How?
Hi.
Try the solution below:
"To set DVD Region to "any", download file "6000.zip" (often also called "LG6000.zip") from this link:
Save the file and then unzip and extract it to your hard drive. Now burn the subdirectory RMTM0000 and its contents (not the text file) onto a CD-ROM (ISO format, "closed" CD-ROM). Insert CD-ROM into the LG BD 370 P player, and when the Region Management System screen is displayed, set the Region Code to "0" using your remote. Once done, press "PAUSE" on you remote to save, and you're done!"
From : http://www.videohelp.com/dvdhacks/lg-bd370/10016
Feb 17, 2011 | LG BD370 BLU RAY PLAYER
Multi region hack for lg bd560 dvd player U K region 2
Hello LG Blu-Ray users!
We are pleased to announce that setup data was just uploaded.
It changes your LG player to multi-region / region free in 1 minute!
BD-350: http://www.megaupload.com/?d=WPF0MXI4
BD-370: http://www.megaupload.com/?d=Y6VOQIPQ
BD-560, 570: http://www.megaupload.com/?d=9C2I286N
HB-954: http://www.megaupload.com/?d=4H157815
HB-500 series: http://www.megaupload.com/?d=GVM41PIV
It is very simple to use.
1. Download data
2. Unzip it (password needed)
3. Burn them on blank CD (or DVD)
4. Insert the disc to your player.
5. Start updating.
Now your player can play any region DVD disc!
If you want to unzip & try them, please send me email.
My email address: multiregion@worldsportsclub.org
We will reply to your email within 24 hours.
Sep 04, 2010 | LG BD370 BLU RAY PLAYER
Region codes required for DVD's from England.
Hi its better to make your DVD region free,please follow these steps:The internet has made it easier to purchase obscure foreign movies on DVD that aren't sold in this country. DVD's have region codes so they will only play on certain DVD players. For instance, US DVD's are region 1 while Europe and Japan are region 2. The only way you can play a foreign DVD then is to purchase a region free DVD player or make your DVD player region free.
  • Get a DVD player. If you purchases a DVD player, make sure you purchase a DVD player that people have had success in converting to region free. If you already own a player, you will need to note down the make and model of your player.Step 2
  • Look up the DVD hack for your player. There are several sites that feature DVD hacks. Two popular sites are DVD Exploder and Video Help. Simply look up the make and model of your DVD player and check to see if there is a hack.
  • Jul 26, 2010 | Video Game Consoles & Games
    "A" regio coded Blu-Ray disc - playing on BD 370, EU version
    Go to the sub menu find out if u have a NTSC/PAL.If there auto pick that.
    Aug 12, 2009 | LG BD370 BLU RAY PLAYER
    LG BD300 dvd palyer region free code
    To set DVD Region to “0”, download file “6000.zip” (often also called “LG6000.zip”) from here:
    Now burn the subdirectory RMTM0000 and its contents (not the text file) onto a CD-ROM (ISO format, “closed” CD-ROM).
    Insert CD-ROM into the LG BD 370 P player, and when the Region Management System screen is displayed, set the Region Code to “0” using your remote. Once done, press “PAUSE” on you remote to save, and you’re done!
    Mar 03, 2009 | LG Super Blu BH200 Blu-ray and HD-DVD...
    Televison & Video Logo
    250 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
