Question about Icon Image 17.5 S Treadmill
My display went out, and now the belt won't move
  • 6,826 Answers
TROUBLESHOOTING
Most treadmill problems can be solved by following the steps below. Find the symptom that applies, and
follow the steps listed. If further assistance is needed, please see the front cover of this manual.
PROBLEM: The power does not turn on
SOLUTION:
a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet (see page 12). Use only a single-outlet surge suppressor
that meets all of the specifications described on page 12. Important: The treadmill is not compatible
with GFCI-equipped outlets.
b. After the power cord has been plugged in, make sure that the key is inserted into the console.
c. Check the reset/off circuit breaker located on the
treadmill frame near the power cord. If the switch
protrudes as shown, the circuit breaker has tripped.
To reset the circuit breaker, wait for five minutes
and then press the switch back in.
PROBLEM: The power turns off during use
SOLUTION:
a. Check the circuit breaker located on the treadmill frame near the power cord (see the drawing
above). If the circuit breaker has tripped, wait for five minutes and then press the switch back in.
b. Make sure that the power cord is plugged in. If the power cord is plugged in, unplug it, wait for
five minutes, and then plug it back in.
c. Remove the key from the console. Reinsert the key into the console.
d. If the treadmill still will not run, please see the front cover of this manual.
PROBLEM: The displays of the console do not function properly
SOLUTION:
a. Remove the key from the console and UNPLUG THE
POWER CORD.
Remove the two Foot Rail Screws
(4) and the two 3/4” Hood Screws (2) and carefully remove
the Hood (1).
Locate the Reed Switch (63) and the Magnet (67) on
the left side of the Pulley (64). Turn the Pulley until
the Magnet is aligned with the Reed Switch. Make
sure that the gap between the Magnet and the
Reed Switch is about 1/8".
If necessary, loosen the
Screw (11), move the Reed Switch slightly, and then
retighten the Screw. Reattach the Hood (not shown),
and run the treadmill for a few minutes to check for a
correct speed reading.
Tripped Reset
c
a
63 67
11
Top
View
1/8" 64
22
PROBLEM: The walking belt slows when walked on
SOLUTION:
a. Use only a single-outlet surge suppressor that meets all of the specifications described on page 12.
b. If the walking belt is overtightened, treadmill performance
may decrease and the walking belt may become
damaged. Remove the key and UNPLUG THE
POWER CORD
. Using the hex key, turn both rear
roller bolts counterclockwise, 1/4 of a turn. When the
walking belt is properly tightened, you should be able
to lift each edge of the walking belt 2 to 3 inches off
the walking platform. Be careful to keep the walking
belt centered. Then, plug in the power cord, insert the
key, and run the treadmill for a few minutes. Repeat
until the walking belt is properly tightened.
c. If the walking belt still slows when walked on, please see the front cover of this manual.
PROBLEM: The walking belt is off-center or slips when walked on
SOLUTION:
a. If the walking belt is off-center, first remove the key
and UNPLUG THE POWER CORD. If the walking
belt has shifted to the left,
use the hex key to turn
the left rear roller bolt clockwise 1/2 of a turn; if the
walking belt has shifted to the right,
turn the left
bolt counterclockwise 1/2 of a turn. Be careful not to
overtighten the walking belt. Then, plug in the power
cord, insert the key, and run the treadmill for a few
minutes. Repeat until the walking belt is centered.
b. If the walking belt slips when walked on, first remove
the key and UNPLUG THE POWER CORD. Using
the hex key, turn both rear roller bolts clockwise, 1/4
of a turn. When the walking belt is correctly tightened,
you should be able to lift each edge of the walking
belt 2 to 3 inches off the walking platform. Be careful
to keep the walking belt centered. Then, plug in the
power cord, insert the key, and carefully walk on the
treadmill for a few minutes. Repeat until the walking
PROBLEM: No exercise information appears in the console display when the power is turned on and the
key is inserted in the console.
SOLUTION:
a. Remove the key from the console. Press the Stop button while reinserting the key into the console.
Then, press the Calorie Goal Programs button. Exercise information should now appear in
the console display.
b. If there is still no text in the console display, please see the front cover of this manual
Posted on Jul 14, 2010
I have a Spirit of St. Louis turntable that won't turn.
This model of turntable automatically stops when the needle reaches the center(the end) of the record. The motor should turn back on if you move the arm to the far right of the player, past its resting spot.
May 02, 2013 | RCA Spirit Of St. Louis Radio/Cassette/CD...
My Reebok v6.80 treadmill turns and lights up but won't go.
1) LUBE the deck belt,you have a WORN deck belt, this happen because you didnot lube according with the schedule maintenance
29 LUBE the rollers bearing too
3) Test the drive belt motor, for worn or crack, or adjust if is possible
4) Test the input voltage motor, if there are the motor need repair
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 28, 2012 | New Balance 1400 Treadmill
Makes grinding noise and belt won't move
If it sounds like metal rotating on metal then it could be a a(roller bearings or b( motor bearings. LUBE INMEDIATELY. + DECK BELT LUBE VERY URGENTE, MAYBE YOU HAVE A WORN DECK TIME TO CHANGE THE BELT.
God bless you
Oct 01, 2012 | Proform 380 Treadmill Walking Belt
Whirlpool washer problem spinning
If it makes noise but moves, it's your motor - it it doesn't move at all, it's the belt. Noise and won't move, get a new washer. Check the BELT first - that usually is the problem.
Jul 22, 2012 | Washing Machines
My treadmill will light up an make a beeping nose when a button is pushed. The treadmill is pluged up and the red cord magnet is on when the buttons are pushed. However it just does the same beep for...
If the screen is lit and the screen shows that the belt is moving then it’s the motor controller. If the screen does not show that the belt is moving then it’s the console.
Oct 20, 2017 | Horizon Fitness T82 Treadmill
Scanner won't scan. the light is on but the scanner part won't move. makes a lot of noise. the belt is not brokern
depending on the scanner the belt may not be broken, however the gear that it rides on may not be moving, or the belt is slipping. Some scanners the glass can be removed for you to visially see the gear and evaluate from there
Jul 15, 2011 | Office Equipment & Supplies
I have an early-2000s Troy Bilt Bronco, 42 inch deck, 18hp Briggs Inotek engine, hydrostatic drive. It broke or threw a drive belt (not for the mower deck, but a transmission belt). How to you go about...
While mowing the yard, the mower went dead. I tried to recrank it and it won't crank. The gas pedal goes straight to the floor and doesn't work to crank the mower. I do not know anything about mowers and don't know where the problem could be. Can someone help?
Jun 14, 2010 | Troy Garden
My washer turn on but won,t spin
tub bearings may be frozen up. Can you move tub by hand?
Jul 20, 2009 | GE WPGT9360EPL Top Load Washer
My HP Deskjet 400 won`t properly print a straight vertical line
check the print head belt.......belt that moves the cartridge from left to rite
check to see if all the teething grooves on the belt is intact...and that its all there..if this belt slips a teeth it wont print in a straight line....
Nov 09, 2008 | HP Office Equipment & Supplies
Icon Image 17.5 S Treadmill Logo
Top Icon Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Alienware X51
Alienware X51
Level 1 Expert
Are you an Icon Exercise and Fitnes Expert? Answer questions, earn points and help others
