Question about Philips Televison & Video
I need a blue tube for a philips 55PP954 - any ideas where i can source it?
  • Philips Master
  • 8,457 Answers
Try website like Tvrepairworld.com,Ebay.com to buy reburbishes CRT Tubes.
Posted on Jul 14, 2010
Testimonial: "Thanks - will give it a go. Was hoping for an official Philips service centre but I guess these parts are no longer made, even though the tv is only 5 years old! "
  • Chi Chu Jul 15, 2010
    5 years old,that almost a life time in the eclectronics industries.U lucky, if they produced the same products two years in a row.
Sony KP-57WS5610 Blue light will not converge the blue is offset from everything else on the screen so its like a blue shadow Any ideas on whats wrong
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then yourconvergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit fromTvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Feb 20, 2012 | Sony KP-57HW40 57" Rear Projection...
My philips 55pw9363 has yellow tint I took off the back the blue bulb has no pic in it like the other two but light is bright
It means you have Bad Coolant Fuild in the Blue Tube,most of the time it will be the green and blue tubes and it needs to be changed and New Coolant Fuild put in it. Philips is the worlds worst having bad coolant fuild in tubes.
Mats Electronics has coolant fuild 1-800-628-1118
Jun 22, 2011 | Philips 55PW9363 55" Rear Projection...
Looking for blue picture tube 7"liquid cooled tube
You need to change the coolant Fuild in Blue Tube Mats has it 1-800-628-1118
Jul 01, 2010 | Philips 50PP9202 50" Rear Projection...
BLUE TINT ON MY SCREEN
Philips tv's have always had this problem. Between the picture tube and focus lens there is a layer of coolant fluid. The coolant fluid, over time, will break down and turn a brownish cloudy color and it usually starts with the blue. Something to do with the color frequency. Have a good repair shop check it out and if the fluid is the problem have them change all the fluid in all 3 picture tubes (there is a red, green and blue tube). Don't feel bad, like I said all the philips projo's had this problem. Thanks
Oct 29, 2009 | Televison & Video
No color hues
Have you tried more than 1 source? If this only happens with 1 source- if you're using component cables (green, blue, red) then make sure there is nothing wrong with it. Another thing that can cause this, is a component (RGB) device being plugged into a composite a/v input (yellow white and red).
If this fails, or if the problem is with all sources, the TV is the problem and probably won't be easy to diagnose or repair yourself.. I'd call the manufacturer if this is the case.
Jun 21, 2009 | Philips 43P8341 43" Rear Projection...
55 inch with blue ghost like glow on white or blue colors
Inside of your TV their is a fluid that keeps the tubes cool. Over the years this fluid will turn cloudy and cuase the screen to look dull, bright white, have halos, etc. You can get the fluid over the internet from various sources or your can get a complete kit including repair instructions from www.TvRepairKits.com.
May 08, 2009 | Philips 55PW9363 55" Rear Projection...
Philips 60 in big screen
Sounds like the picture tube coolant needs replacing.. usually the blue tube..sometimes green or both
Dec 22, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 51in. Rear projection DPTV345
That is quite an undertaking to replace all three crts in a conventional PTV - I've been in electronics more than 20 years and I've never done that... One because it's far too expensive, two because it's unusual that all three crts would be bad and if they were I'd REALLY suspect problems somewhere else and three because of how labor intensive it would be to remove, install and align three new cans.
That said, you should be able to get them through Vance Baldwin or Tritronics Inc.
Bill
Mar 13, 2008 | Philips 51PW9303 51" Rear Projection...
PHILIPS 50P8341A COLOR PROBLEM
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Philips 50P8341 50" Rear Projection...
Red picture cannot adust with convergence
You have bad CRT Fluid, the green and Blue tube need the fluid changed. This is a messy and possibly dangerous to the tv proposition, you will want to call someone to change the fluid, you will probably spend $450+ for the repair, but it should look pretty good when done, possibly better than it has looked in years.
May 27, 2007 | Philips 9P5034C 50" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
