Question about Kitchen Ranges
My ge PLT059-2 double oven does not heat properly. The temperature is about 80 degrees lower than what you set it at. The broiler is fine. What is the problem? thanks
WhIzAtIt
  • 136 Answers
SOURCE: GE Spectra XL Oven does not maintain oven temperature
The most logical solution for your problem would be a faulty thermostat, but yet at the same time i dont understand how it would heat to the temp desired then not come on at all. I would definately change the thermostat to start off with. Let us know :-D
Posted on Sep 14, 2007
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Posted on Sep 18, 2007
SOURCE: Oven does not heat to proper temperature
get a new oven
Posted on Nov 23, 2007
  • 15 Answers
SOURCE: GE Profile Gas Range, serial at235522p, model JGBP79WEW1WW
If this is a newer range, the instructions to recalibrate should be in the manual that came with the stove
Posted on Oct 07, 2008
SOURCE: GE JBP30 oven bottom element not working after being replaced
I would be looking at the bake relay on teh coven control board. Using a voltage meter test the output voltage when energizing the bake feature. Be sure to remove the bake element wire coming from the bake element to the control. Test this terminal without the bake element wire attached. From the terminal with one meter probe to the neutral on the terminal block (where your cord attaches to), you should read 110 volts when energized and 0 voltge when shut off. What are you reading? If I can help further, I am here.....
Waiting to hear from you,
Eric Campion
Posted on Feb 15, 2009
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Bake does not work
you need to call a repair service we do not recommend DIY with gas appliances.Safety reasons
Nov 02, 2017 | GE JGSP23 Gas Kitchen Range
Bosch double electric convection oven: top oven will heat and display code E1 15 once it gets to 350 degrees, will continue to heat with no response to temperature choosen. Set oven to 350 degrees and...
replace the oven temp sensor, it looks like a metal rod sticking out from the inside back wall inside the oven. part here....
http://www.repairclinic.com/PartDetail/Oven-Sensor/650101/1557889
Jan 23, 2018 | Bosch HBL3420UC Electric Single Oven
Replace or fix a 10 year old JTP56 GE Profile double oven
The heating element is easy to replace and you can buy it online...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 20, 2010 | GE Profile JTP56 Electric Double Oven
Broiler works, oven settings - no flame, no heat.
Hi, it sounds like the oven ignitor might be bad. Remove the floor panel inside the oven and you will see the ignitor attached to the burner assembly. Turn the oven on and see if it glows. You can test the connection for the ignitor and see if it gets 120V to it. The most common problem with the gas oven is the ignitor. Most of the time, the ignitor glows but is not strong enough to open the gas valve.
Please let me know if this was helpfull or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | GE JGBP33 Gas Kitchen Range
Oven does not Bake, Heat Up
Replace the oven glow bar igniter. If you post an exact model number (located on sticker behind lower drawer) I can give you a part number.
Sep 02, 2008 | GE JGRP17 Gas Single Oven
GE RANGE MODEL #JGBP35BEA2BB
Sounds like that ignitor is weak.  When the ignitor glows it builds up resistance to the gas valve for gas to come in.  If it sometimes takes 10 min then the proper resistance isn't there and this will give you that gas smell.  Replace the ignitor and this should solve your problem.  Can expect to pay $80 - $100 for the part.
Oct 14, 2007 | Kitchen Ranges
GE Double Oven JKP45BA, lower oven wont heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
heatman101
Jul 30, 2007 | GE JTP48 Electric Double Oven
Kitchen Ranges Logo
140 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
