Question about Panasonic AG-7350 VHS/S-VHS playback VCR
I was wondering how many frames per second the Panasonic AG 7350 counts. When I count the number of frames (or jumps on the screen), I count 60 in one second, but I was told it is only possible to count 30 frames per second on any machine. Do you know what exactly I am quantifying then?
  • cetaceancraz Jul 14, 2010
    Thank you for the solution, it was really helpful.
  • Panasonic Master
  • 11,800 Answers
You are  counting half frames - in the interlaced mode the image is split in two half images/frames. You can find a much more extensive description here
http://en.wikipedia.org/wiki/Interlace
Posted on Jul 14, 2010
What is the minimum amount a coin counter can count?
It really doesn't say what is the minimum but i'm not sure there is one. you just put in one coin and it counts it. The speed is what matters in counters. there are fast counters that can count around 150 coins per minute.
Apr 29, 2013 | Retail Supplies
Reset Fujifilm finepix digital camera 5.1
There is a factory reset function in the menu. If you want to reset the frame count, ie, frame number full then you need to format your memory card, switch the frame count in the menu from "cont " to " renew " use the format function then take a pic. Review the pic and note the frame count in top right of screen(100 0001) frame count is reset. Switch back to " cont" in menu. Happy snapping.
May 15, 2012 | Fuji Cameras
I'm using d-link dwl-3200 ap ( three) Received Frame FCS Error Counts indicate a problem? ___________________________________________ WLAN 802.11G Traffic Statistics Throughput Transmit...
Transmitted Error Count 4734440
Ack Rcv failure Count 15269951
  • As per the above there are error on Transmitting the packet and also for receiving the acknowledge packet.
  • Please check whether any disturbance in the link
  • Each PPP packet has a checksum attached to ensure that the data being received is the data being sent. If the FCS of an incoming packet is incorrect, the packet is dropped and the HDLC FCS count is increased.
  • Another reason for seeing too many FCS errors may be that the remote end has stopped talking PPP.
Feb 27, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
Panasonic DP-8020P Machine Maintenance count reached.
yep. as long as the print quality is good and stable, and the toner consumption is good (8K to 10K of pages per bottle) you can just reset the maintennace count at f7-03 on service mode. probably your machine count reached at 120k. :)
Nov 02, 2009 | Panasonic DP-8020E Black and White Copier
What is subfield ? panasonic says subfiels what is subfield ?
Does this help
A standard video signal is actually a series of still images, flashed on screen so quickly that we believe we are watching a moving image. The typical frame rate used in North America is 60 frames per second (60Hz) meaning that a TV would display 60 individual still images every second. Sub-field drive is the method used to flash the individual image elements (dots) on a plasma panel. For each frame displayed on the TV the Sub-field drive flashes the dots 8 times or more, meaning that the dots are flashing 480 times per second (480Hz) or more. (Example: 60 frames per second x 8 sub-fields = 480 flashes per second). subfielddrive_en.jpg
Jul 10, 2009 | Panasonic Televison & Video
Panasonic 7350 VCR Keep ejecting tapes just seconds after loading
This happens when he strings are worn out or broken. It will not hurt to replace the strings of the VCR after some while.
Jan 29, 2009 | Panasonic AG-7350 VHS/S-VHS playback VCR
Dryer timer counts off to fast
The only thing that I can think of is that you are using a dryer intended for Europe in the US. While they both run on 220V, the timer motor will be specific for the frequency of the country. The US uses 60 Hz. Europe uses 50 Hz.
To keep the explanation simplistic, your timer motor expect 50 electric (frequency) "beats" per second but instead is getting 60 beats per second. Your clock is turning an extra 12 seconds every minute.
Sep 22, 2008 | Kenmore 63942 Dryer
Panasonic Plasma TH-42PV500H goes blank on power up
RKUMAR-ALL BLINKING LEDS ARE DIAGNOSTIC CODES WHICH NEED TO BE COUNTED PER SEQUENCE AND REFERRENCED TO A PANASONIC CODE CHART,COUNT THE BLINK SEQUENC AND LET US KNOW.JOE TV
Jan 08, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Panasonic AG-7350 VHS/S-VHS playback VCR Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
