Toshiba RAV-SM802KRT-E heat pump/air conditioner split system, works fine for a day or two then turns its self off, go to restart it and all you get is two audible beeps from indoor unit and no go.
    President:
  • 1,515 Answers
Hi, what you need to do first is to go to the indoor unit and remove the panels where the beeps you are hearing are located. If the power shuts off when you remove the panel, you will have a panel switch located around the perimeter you may have to tape down to restore power while you check it out. You may have a chart on the panel glued to the inside or somewhere that may tell you what is going on according to how many beeps or led light flashes. The condenser coil outside may be shutting off on high head pressure due to it being dirty. You can use a water hose and cut power, and wash the coil out good. Be careful not to use to much pressure or you could bend the aluminum coil. If you are getting two beeps from the indoor unit, and it will not start, it should say on a chart what this means. Make sure your filter is clean. This unit is shutting down on a safety due to something going on, this is why you need to service it, clean coil, make sure filter is clean, Make sure your high voltage connections at all breaker boxes and fuse box at the outdoor unit are good and tight. They may be loose causing the unit to draw to much amperage. Start from the basics and see what happens. It doesn' sound like a internal problem, but I won't rule this out. Do the things as i have asked and we will go from there. Keep me posted.
Sincerely,
Shastalaker7
A/C, Heating, and Refrigeration Contractor.
Posted on Jul 14, 2010
  • mikrowe Jul 14, 2010
    Thanks so much, i will do all of what you said and will let you know. Cheers Mik
  • Robert Horton
    Robert Horton Jul 15, 2010
    Thanks for the awesome rating. Contact me if you continue to have this problem and we will get it solved.
    Shastalaker7
Heat pump is not kicking in no heat at 42 degree outdoor temp
check the wirings.the coils and also the heating element.also check the heating temprature.
also check the power outlet.
connect some where else.
and try to restart it again after five minites.after you unplug the device from the electric outlet.
Oct 10, 2008 | Amana PTH123B35AE Air Conditioner
Is a split a/c alc and a heating or heat pump?
a split system can be gas or can be a heatpump. a split system is when the condenser coil compressor and outdoor fan is outside. the other half is in the house close to your air filter .that well be your air handler. eletric heater. or gas burner .and indoor fan motor would be. i hope that helps you.
Apr 15, 2010 | Cfm Daikin R410a Split System Air...
My ac works fine but when i turn to heat no hot air
take contuity tester to test heat protecters and inline fuse in coil area /could be that you might have to change main board
Nov 25, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Remote Problems
do you have any CFL's in the room try turning these lights off as I have seen these effect some remote control systems
Feb 27, 2007 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
431 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
