Question about HP Computers & Internet
Horinzontal line at centre of HP monitor 5502
I have resoldered the vertical IC TDA4386 A ; also I changed the IC and checked but the problem is the same . Also checked for the voltages on the IC which seemed to be ok . Which are the points required to be checked .
Kindly help for the same.
  • 2,005 Answers
Get the schematic for you tv then read all ofthe circuit values; chances are your horizontal output transistor is bad.
Posted on Jul 14, 2010
  • Jim Goldsmith
    Jim Goldsmith Jul 14, 2010
    sorry I meant Vertical output transistor circuit!
    the horizontal line indicates that the picture is good horizontaly but, is not opening vertically.
My compaq monitor just start blinking and now only haft past of the screen is visible. the rest just went black with on bright shining line on the middle of the screen
hi,
Your monitor have problem with vertical deflection section. Can caused by the faulty vertical driver IC and faulty electrolytic capacitor it the vertical section or dry soldering in the pins of the vertical driver IC. When vertical section fails horizontal lines come on the screen. For testing the same you have to open the monitor and remove the main board. you can easily find out the vertical ic. just follow the four wire running from the deflection yoke ( coil on the crt neck) of which two will go to the horizontal section (normally red and blue wire) and two will go to the vertical section ( Normally yellow and green wire). Follow the yellow and green wire which will be connected to one of the socket in the main board. Follow the circuit track in the main board which will lead you to the vertical deflection section. There you can see one ic is fitted on a aluminium heat sink.Take a close watch in soldering of its leads. Dry soldiering can happen in its leads because its a component which will got to a temperature about 75 degree above at its normal working condition. if found any dry-soldering or not just resolder all the pins of that ic. then check the monitor. If problem remains then you have to relapse the ic.While replacing the ic try to relapse all the capacitors in that section. It will prevent from any further damage to the new vertical ic. if you need any more assistance feel free to contact me through fixya
Jun 09, 2011 | Compaq P 1220 22" CRT Monitor
My tv has a line through the centewith half o the picture at the bottom!
It is vertical stage problem .check supply voltage,and output voltage of ver ic,If it is upnormal find reason,and also resold the ver.ic .and change vert stage electrolytic filters.finaly replace vertical ic.
Aug 11, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Black screen with bright horizontal line through center
Your vertical IC may need resolder. You may have a bad capacitor or two that created an extra warm IC and create bad grounds. So resolder and check those caps near and around your vertical IC. If you continue to see this horizontal line you may have to replace the vertical IC. And you may as well check all grounds as well. Good Luck and be careful!
Jun 18, 2010 | Broksonic TV
Retress line with vertical foldover
Vertical suddenly fold over? Vertical IC loosing connection with board. Best solution is to reflux or resolder it. If not damage vertical IC, replace it. That should fix the problem.
Apr 13, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Vertical line off centre of monitor
Likely a crack in your cable - try a new cable if possible (or borrow one) - other than that its likely a fault in your monitor.
Apr 10, 2009 | HP w19 19" LCD Monitor
CRT Monitor Displays only a thin bright horizontal line
Vertical IC loose connection. Best is to reflux it or resolder. It is in internal circuitry inside the monitor commonly an upside single line IC.
And its a minor repair only. But I recommend it to be serviced by a qualified technician. Inside it are plenty of nasty voltages. It might caught you.
Apr 10, 2009 | Computers & Internet
Tv has a line going thru the centre of the screen when i turn it on its like the whole picture has gone into a thin line
This is a problem with the vertical circuit and can be either bad connections at the vertical IC or a defective IC. This is a common problem and is easily repaired. The vertical IC is a small flat IC attached to a heatsink with about 11 pins or so. It might be marked LA7837 or something similar. If you can solder, try resoldering the pins on that IC first. If that fails to resolve the problem, replace the IC. Expect the IC to cost about $15-$25 depending upon the exact one. It is possible that some of the capacitors in the same circuit are defective as well. Once the IC is replaced/resoldered, report back here with the results and we can go further if necesary.
Dan
Jun 13, 2008 | Televison & Video
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
Intermittent problem
Could be dry solder near vertical Ic and horizontal Output Transistor.Resolder components mounted on heatsinks.
Samir.
Mar 09, 2008 | LaCie Electron 19" CRT Monitor
56 V - faint horizontal lines across the display
u can search problem in vertical section may be sum IC component was dry resold them .
Aug 02, 2006 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
107 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
