Question about Brother DCP-7020 All-In-One Laser Printer
I am getting error drum change soon even I change drum and toner
    President:
  • 405 Answers
You will need to reset the drum counter now. With the front cover open (where the cartridge is installed) press the options button (or clear button if applicable) the press the up arrow for yes when it asks "replace drum?".
Posted on Jul 15, 2010
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
Printer says "drum end soon". I don't even know
The drum is the part of the printer that the image of what you want to print is stored on by a laser drawing on that drum. That drum is then charged with an electrostatic shock that will draw up toner particles from your toner tray that will eventually be transferred to a piece of paper that will be heated to fuse the ink particles on the paper. That drum is photo sensitive and eventually looses its ability to be charged. You will then have to replace that drum.
Feb 09, 2011 | Brother MFC 7840W Printer
We've tried 2 new toners in the Brother 7820n and still get the same error...Change Drum Soon. We've turned it off, slid the blue arrow to clean the drum wires, etc....it still won't work...please advise....
Open front cover where drum/toner goes in
Press "Options" key on control panel
LCD will display "Replace Drum 1. Yes 2. No"
Press 1 to reset drum
Close front cover
Nov 09, 2010 | Brother MFC-7820N All-In-One Laser Printer
CHANGED DRUMAND THE CHANGE DRUM SOON ERROR IS
you need to open the front cover (where drum and toner is installed) and press the options button, it will ask replace drum? Press 1 for yes and close the front cover.
Apr 15, 2010 | Brother IntelliFax-2820 Laser Fax
The toner tray will not pull out from the machine
Replacing the Toner Cartridge
The MFC can print up to 6,000 pages using a high yield toner cartridge. When
the toner cartridge is running low, the LCD shows TONER LOW. The MFC is
supplied with a standard toner cartridge that must be replaced after
approximately 3,000 pages. Actual page count will vary depending on your
average document type (i.e., standard letter, detailed graphics).
Discard the used toner cartridge according to local regulations. If you are not
sure of them, your local Sanitation Department. Be sure to seal the toner
cartridge tightly so toner powder does not spill out of the cartridge. When
discarding used toner cartridges, keep them separate from domestic garbage.
We recommend that you clean the MFC when you replace the toner cartridge.
1 Open the front cover and pull out the drum unit.
Place the drum unit on a drop cloth or large piece of disposable paper to avoid
spilling and scattering the toner.
2 Hold down the lock lever on the right and pull the toner cartridge out of the drum
unit assembly.
Caution
Handle the toner cartridge carefully. If toner scatters on your hands or clothes,
immediately wipe it off or wash it with cold water.
3 Unpack the new toner cartridge. Place the used toner cartridge into the
aluminum bag and discard it according to local regulations.
 Wait to unpack the toner cartridge until immediately before you install it in the
MFC. If a toner cartridge is left unpacked for a long period of time, the toner life
is shortened.
 You can use only a genuine Brother toner cartridge (TN-430 or TN-460), which
is specially formulated to ensure top print quality. Using another brand of toner
cartridge may void your MFC’s warranty. Warranty coverage does not apply to
problems caused by the use of 3rd party Toner, 3rd party Toner Cartridge or 3rd
party Drum unit.
4 Gently rock the toner cartidge from side
to side five or six times to distribute the
toner evenly inside the cartridge.
5 Remove the protective cover.
6 Insert the new toner cartridge in the
drum unit until it clicks into place.
7 Clean the primary corona
wire inside the drum unit by
gently sliding the blue tab
from right to left several
times. Return the blue tab to
the Home position ( )
before reinstalling the drum
unit assembly.
Reinstall the drum unit and close the
front cover.
Replacing the Drum Unit
The MFC uses a drum unit to create print images on paper. If the LCD shows
CHANGE DRUM SOON, the drum unit is near the end of its life and it is time
to purchase a new one.
Even if the LCD shows CHANGE DRUM SOON, you may be able to continue
printing without having to replace the drum unit for a while. However, if there
is a noticeable deterioration in the output print quality (even before CHANGE
DRUM SOON appears), then the drum unit should be replaced. You should
clean the MFC when you replace the drum unit. (See page 21-18.)
Caution
When removing the drum unit, handle it carefully because it contains toner. If
toner scatters and your hands or clothes get dirty, immediately wipe or wash
with cold water.
WARNING
Just after you have used the MFC, some
internal parts of the MFC are extremely
HOT! So please be careful.
The drum unit is a consumable item, and it is necessary to replace it periodically.
There are many factors that determine the actual drum life, such as temperature,
humidity, type of paper and how much toner you use for the number of pages per print
job. The estimated drum life is up to 20,000 pages. The actual number of pages your
drum will print may be significantly less than these estimates. Because we have no
control over the many factors that determine the actual drum life, we cannot
guarantee a minimum number of pages that will be printed by your drum.
Oct 02, 2009 | Brother MFC-9840CDW Laser Printer
How to turn off "toner Low"
THE PROBLEM IS IT IS DUE SOME SERVICE REQUIREMENT, THE CORRONA WIRES MAY NEED TO BE CLEANED, THE TONER USED CONTAINER MAY NEED SOME SERVICE, THE ROLLERS AND MACHINE MAY NEED DRUM CLEANED OUT, PRINT GET SERVICED AND THE SERVICE PERSON RESETS THE COPIERS DATA SO THE COPIER WILL NOT HAVE FUNCTION ERRORS AND BROKE DOWN MORE OFTEM DUE TO NOT BEING SERVICED ON A MONTHLY SERVICE, TONER CONTAINER MAY A FORIEGN MATTTER IN THE TONER TANK AND CAUSING THE SYSTEM THE TONER CARTAGE IS MALFACTION ERRORS.
IT HAS BEEN AWHILE SINCE I SERVICED A COPY MACHINE, SINCE 1980.
ROD
Feb 02, 2009 | Office Equipment & Supplies
How to resolve 'Dust on Drum' error on Brother DCP 7020?
"Drum error" is because there is dust or any thing like ink on the drum.
After I filled the toner with a other brand dry ink, I got this message.
I carefully checked the drum, I found there was some ink on the drum. So took off the toner part, washed the drum kit with the tap water. wait it dry. There is a rubber roller inside, it will take time to dry.
after the drum kit dry, I rolled the drum, there still something on the drum, I use a tissue paper cleared it.
put the toner back, insert it back to the printer. It is fixed.
Nov 25, 2008 | Brother DCP-7020 All-In-One Laser Printer
CHANGE DRUM SOON
You need to change the drum on your printer. Part # DR-350.
Thanks and please take a moment to rate as fixya.
Nov 06, 2008 | Brother MFC-7220 All-In-One Laser Printer
IntelliFAX 4750 Toner Empty
Hi, have you changed the drum anytime soon? If so did you clear the message before installing the new drum? The only other option would be to try a diffrent toner. There is not toner reset counter like there is for the drum! So I would reset the drum counter and see what happens. Good Luck
Nov 08, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother DCP-7020 All-In-One Laser Printer Logo
739 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
