Air conditioner fan runs, but compressor does not kick on - stopped cooling
    Problem Solver:
  • 5 Answers
You will need to check compr winding for a short with a meter
Posted on Jul 14, 2010
Outside fan not running, inside unit running fine. Compressor was running this morning, but no longer. Replaced fan motor, turned power back on, now fan or compressor not running. What else can be checked?
There may be a manual reset high limit... look for a red button on a round part hooked to the small copper line and push it in hard...
Also the compressor may have kicked the overload and needs a few hours to cool and it reset, that is interanl insdie the compressor.
Contactor may also have went bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 25, 2010 | Goodman Heating & Cooling
Goodman heat pump stopped cooling
yes, but I would try a "hard-start" kit before replacing the compressor itself
Jul 10, 2010 | Goodman CPLE24-1 Air Conditioner
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
LG 24000btu not blowing cold air. Fan runs but i do not hear the compressor kick on. temps upstairs hit 104 and temp is set at 80. unit is only in use for 2 months. none stop though on cool.
please check the temperature sensor this will make the compressor for running and stopping and also check the compressor if its in warranty period please call the service technician to check these and replace if necessary.
Sep 04, 2009 | LG Electronic Window Air Conditioner
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Interkool 900 stopped cooling - what to check before calling for service? The unit has worked fine for 4 years. The fan runs, but the unit does not cool the wineroom anymore.
t seems like there is a problem with the thermosat, or the compressor. Its not sensing the temperature being to warm to kick the compressor on and cool it down. OR the compressor itself id dead. Hope I could help.
Wayne
Jun 26, 2009 | Vintage Keeper Interkool 900 Air...
DuoTherm compressor starts but will not continue to run
check condenser fan if running. it will make compressor comes on and off if broken
May 31, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner is not blowing cool air, but fan still blows
check the compressor with the ac running and make sure the compressor is kicking in and out in not the compressor might be bad or te clutch on te front of te compressor, sometimes u can get to much freon in them to i did it ounce
May 30, 2009 | 1998 Cadillac Eldorado
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Compressor not kicking on
What type of thermostat are you using? When was the last time it worked ? Do you just get fan on cool mode, or does fan only run on fan mode?
Aug 08, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
138 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
