Question about Kenmore 24032\24036 Top Load Washer
-the kill switch is broken.
How do you replace it? The top of the washing machine is screwed down to the bottom.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Jul 14, 2010
Kenmore washing machine not spinning
If this is a top loading machine; then the "Lid Switch " is broken. To get to the switch, UNPLUG THE POWER CORD, standing in front of the machine, there are trim strips on each end (left and right) of the "dash". To remove the strips pop them off starting at the top and pulling towards yourself. Once the trim strips are off you'll see a screw at the bottom of each corner. Remove the screws-KEEP THEM-. Now the dash will lift up and fold back out of the way. Now you should see a curved metal piece at each corner. Use a screw driver tip and remove them. Now you can lift the metal piece that is the top of the washer. Underneath and on the right side you will see the lid switch, unplug the wires and replace the switch. Plug the wires into the new switch and put it all back together.
Aug 29, 2014 | Kenmore Washing Machines
Machine fills up with water, goes through the agitate cycle then stops and wont go into next cycle
Your Lid latch switch is most likely broken, you will need to replace it, you can not bi pass this switch. you can order it from your closest appliance distributor.
Unplug or turn off breaker to washer.
Replace by removing front panel, should be 2 screws at the bottom of washer.
Slide and depress lid latch down to release.
unhook wires and reinstall the same.
May 07, 2011 | Kenmore 22422 Top Load Washer
Need help in replacing a broken belt
First unplug the washing machine to avoid injury while working inside. Remove the bottom access panel by removing the two screws located at the bottom. Pull the panel down and out. This will give you access to where the belt is.
If this helps you out, please vote or leave a comment
Nov 28, 2010 | Maytag SAV4655A Top Load Washer
How to fix my kenmore washing machine top off.
I found a nice video and added to my page with manual and other good stuff: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 05, 2010 | Kenmore Washing Machines
How remove wash machine top
On these machines there are no screws holding the top down, get under it and pop it up using a tool that won't scratch the finish.
First I would try removing the front panel to see if it could be done through the front. Its only held by two screws in the bottom.
Good Luck
Quentin
Sep 29, 2009 | Frigidaire FEX831CS Top Load Stacked...
Lid switch replacement
Some washing machines have the bolts that hold the top down situated behind the front panel but you have to remove the panel to gain access.
There may be 3-4 screws at the bottom of the front panel, remove the screws and the panel should come out.
Hope this has helped
Jun 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool washing machine agitator removal
my whirlpool washing machine's agitator bottom is working but the top is not. How can I fix this myself?
Thank you,
Ann
Nov 24, 2008 | Estate TAWX700JQ Top Load Washer
Kenmore kill switch
it's under the top panel, you must remove the two screws on the control panel (one on each side in the front lower corner of control panel), then roll the entire panel up and over the top on it's hinges. then there are two gold clips (one on each side) that loosen the back from the entire cabinet, stick a flat blade screwdriver in them and they will pop out. theres one plug with three wires in it going to the top re,ove it, then open the lid and grab the top panel and tilt to you about 30 degrees up and slide the whole cabinet away from the base and guts of the machine.
now you can access the lid switch to replace it.
Apr 01, 2008 | Washing Machines
Lid switch problem
malibu Insert a flat screwdriver or a putty knife between the top panel and the front panel and push the fron panel down, then pull it out. Gendos...post back
Mar 03, 2007 | Westinghouse WWS833ES Super Capacity Top...
Kenmore 24032\24036 Top Load Washer Logo
63 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
