Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2000 roadking driving along fine and all of a sudden it looses power (everything} coast over and play with the controls a little and starts right back up. connection problem? where is the brain on this one?
  • 47 Answers
If it's an flh model, I believe there was circuit breaker recall from '99 to '00.
Posted on May 05, 2012
    Scholar:
  • 150 Answers
Brain is right under your seat. I always thought the proximity to the hind quarters was rather amusing but thats were she be. all the connections are suspect so chase em all down and don't crack open a coldy before you start.
Posted on Apr 20, 2008
My 2000 roadking will not get electrical power to start the bike. Running lamps come on but thats it. I replaced the ignition switch that I was told was bad, but still no elictrical power.
Hi Jeff, 1992 and later Touring Models, fuel pump fuses and relays will be behind the right side panel, starter and ignition relays will be under the seat behind the battery, everything else will be behind the left side panel to access fuses pull back on the front two locking tabs and slide the cover up. Good luck and have nice day.
Jul 24, 2012 | 2000 Harley Davidson FLHR-FLHRI Road king
My Intrepid will intermently just stop running. I
Possible cause would be the fuel pump or a faulty fuel filter on car. Also check for a loose connection on the battery (ground connection). Or a loose wire to the fuel pump. Try this and if nothing found to cause the problem send a message again and explain a little more in detail. Hope this will help.
Jun 01, 2010 | 1999 Dodge Intrepid
I have a 1999 GMC Safari. Van will drive fine for
see when you say you step on it, and the vehicle stalls, it sounds as if it bein starved of fuel...you step on it, and therefore the demand is there, but not the supply. to prevent itself from over heating, the fuel pump shuts off...after a moment of cooling off, it fires right back up...get it checked at your mechanic...do the strainer on the bottom of the pump, and fuel filter as well...is it time for a tune up yet?
Nov 18, 2009 | 1999 GMC Safari
2000 Sebring Convertible Electrical Problem
have your BCM(body control module) checked,this is a problem that happens a lot on certain chrysler models and vans,also have the abs system scsnned for TC'S(trouble codes
Sep 08, 2009 | 2000 Chrysler Sebring
2000 nissan xterra hesitating when engine is warm
We are having the same problem. We are right now changing the crankshaft position sensor along with the intake and manifold gaskets.
May 09, 2009 | 2000 Nissan Xterra
Power steering went out suddenly
check the belt first if thats ok check for a locked up pully
Mar 20, 2009 | 1998 Oldsmobile Regency
My power steering suddenly went out on '98 Olds Regency
your power steering and alt. belt come off.. the same belt runs both of this things.. check to see if the belt is there.. good luck keith..
Mar 20, 2009 | 1999 Oldsmobile 88
Stalling, 'reduced power' light, and OBD code P1125 Manufacturer control air metering...
My name is Juan Heredia and I'm an ASE certified technician. I have seen this code and this driveability issues before, I will need a little more information about your car to tell you exactly what your problem is, Honda has two different types of throttle bodies for this especific vehicle, drive by wire and cable operated, if your vehicle uses the drive by wire type I would highly recommend to replace the throttle body actuator, if it uses the cable operated one it will be necesary to do a little more testing, let me know if this helps
Jul 31, 2008 | 2000 Honda Passport
Systenm kicks off right at power-up
faulty power supply/auto protect kicking in when power is applied
Jan 13, 2007 | ASUS A8N-SLI Motherboard
Lands Phones Logo
215 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
