My friend gave me a new air conditioner Model Zenith ZW5010 as a gift. Unfortunately my window has sliding windows and it does not fit in. I wonder if I can turn this air conditioner sideway so it can slide through one of the sliding windows. If impossible what can I do? Remove all windows and then buy plexiglas but how can it support the conditioner in the window?? Thanks sl
    Problem Solver:
  • 5 Answers
Do not turn on its side the water needs to run out if not you will casuse damage to the unit
Posted on Jul 14, 2010
How can I get the water out of my 253.70121 window air conditioner outside case. The fan blades hit the water.
When I was a Maintenance Superintendent for a Senior Citizen Apartment Complex, we had two window air conditioners with the similar problem. This is what WE did, and it worked for us:
1. We ensured the window air conditioner casing was, in fact, tilted slightly for proper drainage. Water continued to accumulate.
2. We drilled two holes from the drain pan, through the casing and added an additional PVC fitting and PVC piping to accommodate the new drain and make it more appealing to the wondering eye.
Good luck.
Aug 26, 2014 | Heating & Cooling
Zenith customer service
you must search in the internet use, google, yahoo, altavista. and get it.
God bless you
Jul 21, 2013 | Zenith ZW5000 5,000 BTU WINDOW AIR...
E1 error code came on it was working fine till this morning.got it as a gift from my friend she bought it last summer. the remote stopped working we replaced the batteries still the remote won't work...
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Jul 10, 2011 | Haier hwr10xc6 Air Conditioner
Window kit dimentions i have a window 18 inch wide
The portable AC units generally have a customizable, exhaust hose window, termination kit that comes with the unit.. In other words it can be cut to fit. The one that comes with the unit will fit casement windows, as well as sash windows.
To further assist you, I have included a link to the Owner's/Installation Manual for the model you referenced. You may download and print it if you like.
http://www.air-conditioner-home.com/manuals/ac-12000.pdf
Hope this helped you. Please let me know. Thanks.
Jun 13, 2011 | NewAir AC-12000E Portable Air Conditioner
I don't know how to uninstall my ac
have some one steady the unit while you raise the window a bit.carefull,it may want to fall out.pull the bottom of the unit in a bit.if that dosen't change the angle,like if it's sitting on a storm window frame too,place a wood plank between edge of sill & storm window frame to raise the inside bottom of unit a bit above the sill.it only requires a few degrees of tilt.
Sep 22, 2009 | Heating & Cooling
Removal of old A/C
It depends on how YOU have it installed. It will slide out of the case and the new one MIGHT fit into the same case. This is trial & error. If not, slide the guts out, remove the case, install the new case & slide the new unit into place.
If it's a window unit, just remove the whole thing and replace it.
May 30, 2009 | Goldstar R7003 Air Conditioner
Window Air conditioner installation
I use sheets of styrofoam on the inside of the window. Cut it to fit the width and height you need to seal around the ac casing to inside window frame.
May 17, 2009 | Frigidaire FAC124 wall/Window Air...
Can a window air conditioner fit in an exhisting wall mount?
I bought window AC (5000 btu) that fit 17 in. at home depot. made by Zenith. Keep in mind of your room size.
Good luck.
Jun 10, 2008 | Frigidaire FAC124 wall/Window Air...
Through the wall vs. window installation
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
228 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
