Question about Refrigerators
Fridge only runs when the thermostat control is "tapped"once it cuts off it does not switch on automatically untill tapped again
  • Refrigerators Master
  • 8,220 Answers
Change the control. The contacts within are burred from arcing OR take the control apart and sand down the points. Note: Success rate of filing down contacts in cold controls: not too good LOL
Posted on Jul 14, 2010
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
Hi, I have a Fisher and Paykel E402B Fridge/Freezer. It has not been working properly for a couple of months.. It does not cool/freeze properly. Through investigation I discovered that the coils and fan...
the defrost heater or thermostat located on the evaporator coil thats icing up isnt defrosting due to a bad heater or thermostat,or it can be the defrost timer that powers these other 2 parts
Jun 21, 2011 | Fisher and Paykel Refrigerators
The fidge is freeziing everything
Has the temp control not been set too low by accident. If not it sounds like the thermostat contacts are stuck together or the sensor bulb has leaked. Unplug the fridge and try tapping the thermostat switch on the compressor lightly and see if that will make the fridge stop running. If that does not help, the thermostat will have to be replaced.
Feb 06, 2011 | Samsung Refrigerators
FREEZING UP IN REFIGERATOR SECTION- WATER IN JUG IN DOOR IS FROZEN
Feb 06, 2011 | Fisher Refrigerators
Our whirlpool fridge/freezer has stopped working today for no obvious reason. There is still power being supplied to the unit, as the light is still turning on once the door is opened, but it is no longer...
You will need to check the following parts:
  1. Compressor start relay
  2. Cold control thermostat
  3. Compressor
  1. With the fridge unplugged, and an Ohm-Meter in hand, remove the Compressor start relay after marking where each wire goes. The wires must be removed before testing the start relay.
  2. Use your ohm meter to test the white(overload) wire, with one meter probe on the terminal where the White wire went, and the other meter probe on the other terminals, 1 at a time, should read 0-1 ohm.
  3. For the brown relay, just put both meter probes in each hole, should read 0-1 ohm.
  1. Put the Compressor start relay back in place and hook the wires back up to it.
  2. Find the cold control thermostat, it is the Switch with a knob that controls the Temperature. Tap under the console and on the knob in your refrigerator section and see if it comes on.
  3. If the contacts inside that cold control thermostat go bad, then when you tap the console or knob the refrigerator comes back on again.
Jan 23, 2011 | Whirlpool Refrigerators
It runs all the time
Switch the fridge off for some time till the frost clears off. make sure the compressor has cooled off before you start the fridge once again.Switch on and checck if there is any ICE formation in about 1-2 hours. If so your compressor, gas and performance is good.
Now we need to check to see if the thermostat is cutting off. Having kept the thermostat in normal mode , the compressor must cut off in less than 3-4 hours. If not the thermostat is faulty. Also if you look on if the fridge does not shut offf in baout 8-9 hours of running then your thermostat, timer can be suspects.
However if there is no cooling reached in the first place then it is possible that the compressor or the gas pressure is down.
Check for leak if the fridge is old before you waste money on filling and losing .
Sep 01, 2010 | Refrigerators
Hi my fridge freezes every thing even at it's
your thermostat is bad, what it does it sense the temperature set buy the control setting, once it goes bad it does not recognize the temperature hot or coold and the unit keep running and freezes everything. thermostat work like the therometer switch, when it reach certain temperature it cut off.
Jul 16, 2009 | Dometic Refrigerators
Fridge won't cut back on after it shuts off until its [powered off and on.
Hi, It sounds like the cold control is going bad. When it shuts of again, give it lettle bit and the tap on the control instead of turning it. If it kicks on, then you know it's the temperature control. Please let me know if this is what you find and if I can assist you with part# or how to order it.
Thanks
Vic
May 20, 2009 | Samsung RB1955 Bottom Freezer Refrigerator
Compressor problems
it varies with door oppenings stuff like that sounds like you may have a faulty cold control the cold control has two settings a cut on setting and a cut out setting you cut in setting may be bad id replace the cold control
Mar 15, 2008 | Refrigerators
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
