Question about Dell Inspiron Mini 10 Notebook
Got a 4400:0011A error code on my dell inspiron mini lap top. What does it mean?
5 Suggested Answers
JackHeath
  • 1049 Answers
SOURCE: how to replace bad cooling fan on dell inspiron 1521 laptop
Replacing the fan is easy, once you remove the drives, the panels from the bottom, etc. Remove the keyboard and unscrew the frame. then the laptop clicks apart. The fan can be removed replaced.
While you can replace the fan fairly easily, they are expensive if you have to buy one from DELL. You might be able to substitute one from another laptop however.
The problem on the Dell Inspiron though is not the fan, but the design. It does not dissipate heat well, cycling heat poorly throughout the casing and ultimately over the drive before exiting from a primary vent on the side which needs to be higher to get good air flow. The air gets so hot and dirty that it eventually clogs up the fan and over heats the drive.
As a matter of fact, even when the fan is running normally the drive often fails anyway right around the two year mark. My last two companies have bought these and you can almost set your watch by the drive failures.
The solution, is a $5 cooling tray like cooks use for cookies. The metal grill will lift the laptop about 1.5 inches off the surface your working on and allow air to move freely in and out of the vent on the side.
Posted on Mar 08, 2010
  • 857 Answers
SOURCE: Does anyone know what code 0146 means?
This error code is related with the hard drive problem. There is a possibility of hard drive failure.
Posted on Mar 12, 2010
PCTechOnline
  • 532 Answers
SOURCE: loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
Posted on Jun 10, 2010
  • 188 Answers
SOURCE: cause of error code 4400:011A on Dell Inspiron
The reason for the errors and the solutions for the error codes are available on the follwoing link
http://findtechhelp12.blogspot.com/2010/12/how-to-run-dell-diagnostics.html
If you find its not a hardware issue then reinstall the computer to the factory settings
http://findtechhelp12.blogspot.com/2010/11/how-to-reinstall-os-in-dell-computer.html
Posted on Dec 08, 2010
Why is my lap top just intermittently beeping with a black screen
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 07, 2012 | Dell Inspiron M5030 Laptop
Problem with Dell inspiron Mini 1012 notebook
Hard drive passwords are very difficult to remove.
This WEB site may help.
BIOS PASSWORD AND LOCKED HARD DISK RECOVERY
http://www.pwcrack.com/bios.shtml
Sep 09, 2012 | Dell Inspiron Mini 1012 Netbook...
I am try to repair my lap top "start up repair"
Hi. Try to do a system restore. Please click on the link below for step by step instructions on how to do system restore for your Dell laptop.
http://support.dell.com/support/topics/global.aspx/support/kcs/document?docid=125982#Issue9
Try the next oldest restore point until the issue is resolved. Any software installed after the selected restore point needs to be reinstalled.
If system restore still doesn't work, run the "Pre-Boot System Assessment (PSA) Diagnostics and Error Codes For Dell Computers", you may click the link below to go directly to the support site, it contains instructions in running PSA Diagnostics and Error Code List with possible fixes.http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=dhs&docid=266787#Issue2
Sep 18, 2011 | Dell Inspiron 1525 Laptop
Mar 12, 2010 | Dell Inspiron 13 Notebook
Trying to reformat mini dell with no cd rom drive tried to boot from usb but comes up with No bootable partition in table what does this mean
Recovery discs have certain run procedures, flash drives dont. I would suggest you obtail or lend and external USB writer
Feb 21, 2010 | Dell Inspiron Mini 10 Notebook
Hi I have a Dell inspiron 5100 lap top. I have
  1. Right click my computer
  2. go to properties
  3. device manager
  4. you will see network adapter and under that will be wireless adapter
  5. click on wireless adapter
  6. go to properties
  7. See if device is working properl
Dec 02, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
I have a dell inspiron 6000 lap top I cannot
Press and hold the "Ctrl" and "F11" keys simultaneously when the Dell splash screen appears. The "Dell PC Restore by Symantec" window will appear. Click "Restore."
Just make sure you have saved all your data before doing that.
Oct 29, 2009 | Dell Inspiron 6000 Notebook
Dell Support Center program continually is not loaded
I would recommend you uninstall the Dell Support Software regardless of
version. It's not much more than a resources drain on your system imo.
just go to c panel ..add remove programs ...and uninstall it ...
Apr 07, 2009 | Dell Inspiron 8600 Notebook
My lap top has this blue error scerrn that comes up
you need to start in safe mode and do a system restore.
either that or put your restore disc in the drive and recover your system
Jan 16, 2009 | Dell Inspiron 2200 Notebook
Dell Inspiron Mini 10 Notebook Logo
292 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
