Question about Dishwashers
I have a Whirlpool Dishwasher model gu1200xtlq1 and the issue we are having is that the water pressure while the washer is on is very low? We were wondering what the problem could be.
5 Suggested Answers
SOURCE: Miele Dishwasher G2170 scvi type hg03 dishwasher problem
Remove and check the "non-return valve" and make sure it's clean. It snaps out and in easily. See page 47 of the manual for this dishwasher.
Posted on Feb 23, 2009
SOURCE: Whirlpool 6600 24 inch dishwasher: low pressure,arms not spinning
Your water pump is blocked. You will need to either call a repair person or disassemble the top of the pump (inside the dishwasher, bottom) and check the water input duct. It just might be some food, etc.. that is blocking the input. But if you don't see anything then it will be further inside and will need to be removed and cleaned. BIG pain...
Best of luck. BTW, I've had the exact same problem but mine was further inside so I had to remove the whole dang pump, arggggggg.
Rick
Posted on Apr 27, 2009
  • 10865 Answers
SOURCE: Water Pressure Too Low in Washer -- Pump going bad?
Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Posted on Jun 13, 2009
  • 127 Answers
SOURCE: I have a whirlpool gold dishwasher model Quiet Par...
if it is just affecting the upper rack i doubt it is just a plugged spray arm (though i could be wrong). more likely than not you have a blockage on the intake of your spray pump motor. a series of bones, toothpicks, foreign material, etc could be blocking the entrance of the pump causing it to starve for water so to speak.
you will more than likely need to remove the lower rack and spray arm to be able to disassemble the strainer and gain access to the sump.
a complete model number would help bunches to.. alas
Posted on May 24, 2010
I just had a Haus slimline dishwasher delivered and have tried to set it up. I have followed the instructions to the letter but the water inlet hose keeps leaking out water when you move the dishwasher...
It is possible the dishwasher inlet is set for low water pressure.
Check the water pressure setting matches your inlet water pressure.
It might help if you provide the model number of the dishwasher.
May 31, 2011 | Dishwashers
Hi, My whirlpool dish washer does not clean the dishes. Robin
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Daniel
Aug 07, 2010 | Whirlpool Dishwashers
New Whirlpool Dishwasher filler overflows.
New Whirlpool Dishwashers will NOT accept the same "volume" of water that was desired by the same products of 25 years ago. Therefore the old 3/8" ID copper supply is too large and will overflow the tub filler/aireator (out the air vent holes). I just installed a new dishwasher supply kit consisting of a new 3/8" OD stainless braded hose with an ID of about 1/4". This delivers less volume than that recommended (in the installation manual) and therfore does restrict the flow a bit. However, the flowrate is adequate and the new dishwasher now works perfectly with no water overflow on the floor . . .
Dec 26, 2009 | Dishwashers
I have a GU1200XTLQ1 dishwasher that is 3 years old. It will not clean the dishes. Working perfectly until one week ago. The water temp has not changed and none of the holes in the arms are plugged up. The...
you may not be getting a full tub of water. water valve could be bad or float could be stuck check water level after you here it stop filling and motor runs it should be toutching the float at the least.could have somthing in the intake of the pump or the impeller drive could be stripped
Dec 08, 2009 | Whirlpool Dishwashers
Dishes in top rack don't clean
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 05, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Whirlpool disher
Run diagnostic by pressing Normal, heated dry, normal, heated dry, normal heated dry. a total of 3 times in 15 seconds.
The dishwasher will reboot and run a test load.
Nov 15, 2009 | Dishwashers
Whirlpool dishwasher doesn't clean very well
Hi
Thanks
Rylee
Oct 22, 2009 | Whirlpool Dishwashers
Low hot water pressure in old whirlpool washer forever to fill
If you have verified that it takes longer than 120 seconds to fill with water then you need to replace your inlet valve. You might be able to get away with just cleaning the screen but you should probably replace it. pn 8531670.
However it more likely you have a defective heater and the dishwasher is trying to obtain its optimum operating water temperature unsuccessfuly and thus stalling to heat water longer than it used to.
Mar 31, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Slow water in whirlpool dishwasher
take the hose off the dishwasher and see if the pressure is good,if so the valve is faulty,most of the valves on whirlpool are at the back but you can get to them by taking the base pan off,but check first.hope this helps.
Mar 12, 2008 | Dishwashers
Low water pressure at sink following reinstallation
if low pressure is only on the dishwasher and not sink.check both hoses going to dishwasher for clogs,rubber washer out of line or debris .if low pressure is only at sink ..you could also remove faucet filter ring at tip for sediment or debris .or lastly check valve under sink cabinet that feeds both sink and dishwasher
Dec 15, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
110 people viewed this question
Top Dishwashers Experts
