Question about Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
What is the weight of oil in the gear box - Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
Is there only 1 oil used for both engine and gear box on Suzuki DR 125 1987
You can do it that way but most gear boxes use a DTL or UGL and it is a straight weight oil.
Mar 26, 2018 | Suzuki DR-Z 125 Motorcycles
What oil do I use in the Botton Gear Box
90 weight gear oil GS-90 same as motor cycle is what I use.
Jan 03, 2016 | Garden
I just bought a 1998 yamaha blaster atv. How much and what kind of oil goes in the gearbox? (the guy i got it from said use plain old 10w-30 oil) Does it use heavy weight gear oil? Transmission fluid?...
Use heavy duty SAE 80W-90 gear oil
Engine oil does work but the oil will not last as long nor will it protect the bearing's/gear's as well as gear oil. Thick dif oil can work to.
Also the gear box is should be sealed.
Oct 23, 2017 | Yamaha 2004 Blaster Base
What weight oil goes into the gear box? whats the proper weight oil for the motor?
30 weigh oiltdetergent (if available,if not regular 30 weight oil will perform also), as for the gearbox.transaxle for the tines use 80-90 weight gear lube
Apr 16, 2011 | Troy-Bilt Pony Garden Tiller
Is the gear box on an old Woods Bush Hog packed in grease or a heavy weight gear oil and what type is best. How do you prevent leaking
90 weight only. Fill through top until level with side opening. If it is leaking, it has likely blown it's seals. If leak is slow, just keep checking and filling it. If it's just flowing out, it's best to replace the box. No too fun. I've had to do it twice in about 15 years. Hope this helps a little:)
Aug 19, 2010 | RTO 1:1.2 Mower Gearbox Brush Hog Rotary...
What gear box oil do i need for a 19990 mitsubishi galant glx 1800 cc manual gear box
usually it is 80 weight but call the dealer as some mfg are specific to what oil or it voids the warenty
Jan 23, 2010 | 1990 Mitsubishi Galant
WHAT KIND OF OIL AND WHAT WEIGHT SHOULD I USE?
Use 10w40 motor oil in the gear box. Don't use any synthetic oils, oil marked "EC", or oil with "special" additives. Stick with the major brands; Pennzoil, Quaker State, Mobil or Shell.
A “very helpful” rating for this answer? Thanks!
Jun 22, 2009 | 1999 Honda VT 750 CD Shadow A.C.E. Deluxe
I have a 1998 sonata v6 5 speed gear box. In the morning when I first start off the gears seem dry/ and don't flow easily. Once the vehicle is warm all seems well. My son-in-law changed the gearbox oil as...
Try some Lucas transmission medic. Also make sure that you have the correct weight oil. The warm tells me that as the oil lube thins down it circulates fine. Adjust to a lighter weight oil.
Feb 12, 2018 | Hyundai Motor 1998 Sonata
Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766 Logo
27 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
