Question about Kitchen Ranges
We have a southbend gas range and the Pilot is not working . What needs to be done ? Is there any service center in Pittsburgh ?
  • 494 Answers
Hi. Here is the nearest service center for your Southbend range.
PENNSYLVANIA
PITTSBURGH, STATE COLLEGE, ALTOONA (WESTERN AREA)
AIS Commercial Parts & Service of Pittsburgh
740 Vista Park Drive
Pittsburgh, PA 15205-1214
412-809-0244
800-726-6020
FAX 412-809-0246
Posted on Jul 14, 2010
What should the ohms value be for the heat probe in my Southbend gas convection oven model X-20A, part # 1172731?
I would expect 15- 50 ohms. usually the elements are good or open infinity would be the range. inspect heating element for cracks. many times it will heat and stop as the element expands opening the circuit. good luck
Aug 16, 2018 | Southbend Kitchen Ranges
Would like service on my Southbend gas top.
Sorry we do not service products here.
Jan 31, 2017 | Southbend Kitchen Ranges
Pilot will not light after repeated attemps. Shut main gas line off as book suggested. Re-lit burners and then oven pilot. Pilot only stays lit if holding red pilot button
90% chance your thermocouple is bad.
This should work: http://www.partstown.com/southbend_range/sou1196078
10% chance your red push button safety valve is bad. If it is really hard to push in I would recommend changing that as well.
Jan 27, 2014 | Southbend 4603AA-2TR LP - 60-in Range w/...
After oven reaches desired temperature, it has late ignition that turns off the pilot AND OVEN WILL NOT STAY ON.
Sounds like the pilot is mounted to far away from the burner. I have seen it happen before where the pilot has detached and the main burner will just keep pumping gas in until it hits the pilot flame and just flash flames and everything goes out.
Or it just could be a bad thermocouple that is going out all the time.
Mar 01, 2013 | Southbend S36D 36" 6 Burner Gas Range,...
My oven pilot light will not stay on
you may need to replace thermocouple and re-try it....good luck.
Nov 06, 2012 | Southbend S560DD (Gas) Oven
Southbend 460DD-2TR no pilot after replacing safety valve/thermo couple
Sounds like if you are not getting any kind of flame your pilot assembly will have to be taken out and cleaned. Your pilot orifice is clogged up with build up. Will need a screwdriver, 7/16 wrech and or a 1/2''.
Jun 30, 2012 | Southbend 460DD-2TR Gas Kitchen Range
Southbend model : x436d need to connect to lpg bullet does not have a regulator on the range do i need 1 before connecting
off the bottle you will need a regulator and at the back of the stove you will need a yellow gas tap as an isolator remember bottle pressure can reach as high as 1200kpa on a hot day and you only need 2.75kpa for the range and your line size is 1/2'' and use gas tape on all fittings and leak test with soapy water
Apr 25, 2010 | Southbend 436D-2GR Gas Kitchen Range
The southbend 436d range gives a yellow flame at the burners
Hello. Please advise if your unit is supposed to run on propane, at the bottom of the oven door is a smaller panel, depending on age, it either lifts slightly, and then folds down, or clearly has screws on the front. Your Model/rating plate is behind this, either on the back of the panel, a tag screwed to the frame, or on the bottom ledge of this area. It should state what gas the unit is meant for, propane or natural. If it was not converted to run on propane, or made to run on propane, this is your problem. If it was built/converted for propane I would suggest you contact your propane supplier, or a restaurant service company to look at it, it would require a few specialized tools, pressure testing, orifice size req., and burner BTU. to go much further than cleaning the dust out of the burner, and cleaning the orifice.
Hope that helps, and thank you.
Feb 12, 2009 | Southbend 436D-2GR Gas Kitchen Range
Want a manual for my oven
google your model # youl see lots of links
Dec 31, 2008 | Southbend 436D-2GR Gas Kitchen Range
GE Spectra XL 44 Gas Oven Bottom Heating
you will need a new heating element at the bottom. to find the part, go to ge's website and get the model #- you should be able to find it either online or a service center.
Apr 28, 2008 | Kitchen Ranges
Kitchen Ranges Logo
190 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
