Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Error code A0
How do i fix the A0 error code, blower vacuum switch open? Where is the blower vacuum switch?
  • 990 Answers
Just left of center inside the top of the front cabnit.(where the hayward label is) It's about 2 1/2" around and has two small hoses coming from it.
Posted on Jul 14, 2010
What is Error Code:59.A0 for Hp laser jet 400 M401d?
59 error indicates a main motor failure. This if often caused by a jammed cartridge, so trying a new toner cartridge would be your first step to trouble shoot this.
Jul 20, 2016 | HP LaserJet Office Equipment & Supplies
Hp laser jet pro 400 m401 printer 59.A0 error
i have nOt used this site before but i believe they do have a description of the error code you describe. it said problem is defuser or main motor error, heres the link
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP LaserJet Error Codes 50 59
Apr 20, 2016 | HP Office Equipment & Supplies
AO error code on 250k btu hayward pool heater
Dear ,
Please try the below solutions,
Solution 1:
If the blower prover switch does not close after the blower starts the control will stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes
Solution 2:
If the blower prover switch opens unexpectedly during operation the control will shut down and attempt to re-light. If the switch does not close after the blower starts the control will go into lockout with the blower running. Automatic reset is immediate after error is corrected
Solution 3:
If the blower prover switch opens during the postpurge cycle (heater is not fir- ing) the control will display the error code. The post-purge cycle will be com- pleted once the blower prover switch close
Regards,
Samy
Aug 10, 2014 | Hayward Pool & Spa
I have a Hayward H250 that wont ignite. When I set mode to to pool the blower comes on but nothing kicks in. then i get an error code of AO.
ErrorAO means BlowerVacuum Switch Open. If the blower prover switch does notclose after the blower starts the control will stop the ignition trial go intolockout. The blower will continue to run. Automatic reset is immediate afterthe switch closes. So you need to check this.
Jun 14, 2011 | Hayward H Series Electronic Ignition...
Our dell powervault 122t shows error code A0
Error Code A0 - Error occurred during carousel movement (Position Not Found). Could be caused by a missing or misaligned cartridge carrier, or an obstruction, or unexpected cartridge in either the carousel path or Import/Export slot.
Remove the power cable and SCSI cables then try open the top cover. Check and see if there are any tape blocking or obstructing the movement. Sometimes it works sometimes it doesnt. I have 5 of these devices, few of them were replaced as its not working anymore due to these codes and as they are pretty obsolete, its not worth to repair them anymore.
Feb 03, 2011 | Dell PowerVault 122T LTO (pv122tlto)...
Ao error message in Hayward heaters
You didn't indicate exatctly which model you have. But on most the AO error code is :Blower vacuum switch
open error If the blower prover switch does not close after the blower starts the control will
stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes.Check to be sure combustion blower starts
If you don't have your manual you can download one for your exact model at : www.haywardnet.com
Jul 29, 2010 | Hayward H Series Pool & Spa Heater 400k...
Pool heater will not ignite
My heater worked ok , btu made a clicking sound, now it shows a AO error? What can I do I dont have enough money to call a pool man again.
Jul 03, 2009 | Hayward H Series Pool & Spa Heater 400k...
Error code 90
NO PC stated, it has a HP name, like DV6-12345,
no OS stated, XP , w7 , w8 or w10. we can not guess OS, ever.
start a post by telling the helper what is in your hands.
we cant look for you, you must tell it.
tapes, sounds , RELIC for sure...
May 08, 2017 | HP Computers & Internet
Hitachi Aircon
According to the error codes for hitachi, there is no AO code. The codes on the code list are all numeral.
Jan 09, 2008 | Heating & Cooling
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
750 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
