Question about Furuno FCV-582L GPS Receiver
LCD coating needs to be replace or LCD REPLACED
Furuno 582L lcd has become blurred and appears burned/foggy. The unit has been discontinued for years and Furuno wants $1000 for a replacement LCD however the working units value is only $450 at best. Removed the LCD and determined the LCD has a smoke color vinyl coating glued to the LCD screen which is the damaged item. Where/what could I use to replace this coating? Polarized window tint maybe??
    New Friend:
  • 65 Answers
Since you have little to loose you can attempt to remove the protective coating and not attempt to replace it with a substitute material. It's not required to operate but is intended to enhance viewing in certain light conditions. Might try a window cleaner with ammonia and a little "elbow grease". Remember though, your end result could be worse than what you have now if you're unable to completely remove the film or damage the JCD panel in the process.
Posted on Jul 15, 2010
Screen problem
The sun screen coating is damaged. This usually happens when salt water is allowed to dry on the display face or cleaning chemicals are used. The bezel will need to be replaced. 001-036-750 $115
Apr 23, 2013 | Furuno FCV 295 104" Fish Finder
Suspected moisture in Furuno GPS/Plotter display
You need to determine if it's moisture or damage to the protective coating on the LCD glass. If the screen coating is damaged it will have patches or discoloration that resemble water spots like you see on windows and glasses exposed to hard water. If it's moisture between the glass and LCD you should be able to make out the tiny water droplets that are evenly spread throughout the screen. The only proper fix for a glass with damage to the protective coating is replacement of the bezel assembly. If it's moisture you can try inserting a few silica gel packs inside the unit. Don't try to disassemble the bezel (LCD/Screen) assembly. Just but the gel packs inside the 1650 chassis and give it a day or two. Otherwise, you're looking at factory repaire.
Jun 24, 2010 | GPS
I have a furuno fcv 582l. The unit has just come back from the factory and works well until I power up any other electronic equipment on the boat. Then it flickers and the screen goes dark. Any ideas?
You likely have inadequate supply to your helm. Otherwise, there is interference being generated. Try turning things on slowly one at a time, check your batteries and ground connections.
May 15, 2010 | Furuno FCV-582L GPS Receiver
Picture gets blurred and then disappears.
christian204, Your unit may be 5 -6 years old, and may have developed a problem with it's internal "switch-mode-power-supply" and will need good CCFL backlit lcd monitor tech to repair it. When strange and wierd things start to occur on lcd screens the first place to look would be the SMPS. 12fixlouie
May 11, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
A furuno 1715 lcd radar was wired to battery backwords
internal damage to the display, fixable by Furuno, and probably economically feasible (guess $250 with round trip to Furuno)
Nov 17, 2009 | Furuno 1715 LCD Radar System GPS Receiver
I was told that the backlight on my monitor was burned out. Can this be replaced without having to send it off somewhere? Where can the replacement light be purchased
First off it could be the backlight bulb or the LCD inverter. I would try the LCD inverter first it will cost about $25 and is easy to get to Take the face plate off around the monitor and the LCD inverter is at the bottom. It looks like a strip of circut board with plastic coating over it. Most of the time it is the LCD inverter.
But if its the Backlight bulb you might be able to take it to a local tv repair shop. you can order the backlight bulbs online but they are gragile and tricky to replace. you have to seperate the layers of glass on the screen abd the backlight will be at the top inbetween the layers of glass. If you do decide to do make sure to wear rubber gloves because the oiles from your fingers will get inbetween the glass layers and cause foggy spots when you put it back together.
Hope this helps
What kind of computer is it?
May 02, 2009 | Gateway FPD2275W LCD Monitor
LLOKING TO BUY A REPLACEMNET TRANSDUCER FOR A FURUNO FCV-582L
Yes, the current model of this is the FCV 585 and it is great. The transducer will need to be changed.
Apr 07, 2009 | Furuno FCV-582L GPS Receiver
Picture blur display
If the picture shrinks and expands you can get a repair kit from www.tvrepairkits.com.
If the screen is just foggy looking my guess is the CRT fluid needs to be replaced.
Oct 19, 2008 | Philips 9P5034C 50" Rear Projection...
I have a furuno fcv 585 echo sounder with a FURUNO CA50/200-12M -c13298 BRONZE THRU HULL HIGH PERFORMANCE TRANSDUCER. The transducer has 4 wires and it looks from the schematic that it attaches via a...
you need an MB1100 matching box has the 10 pin pigtail for your sounder and accepts bare wire input from your ducer
this will also ensure that all power from sonar get to ducer, but it from me if you like 847-746-0100
Jul 09, 2008 | Furuno FCV-582L GPS Receiver
Furuno 582L
those jacks are on a circuit board available from Furuno call me if you like 847-746-0100
Mar 23, 2008 | Furuno FCV-582L GPS Receiver
Furuno FCV-582L GPS Receiver Logo
470 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
