Question about KitchenAid Superba 21.6 cu. ft. Top Freezer Refrigerator w/Factory Installed Icemaker
Water dispenser starts running when freezer door closed
When I close the freezer door, the water dispenser starts running spilling water on the floor. It is unpredictable and happens about half the time I close the freezer door. To get it to stop I push the water dispenser lever several times.
I don't use the water dispenser anyway - is there a way I can shut off the water supply? I'm afraid one of these days its going to just start running on its own.
Thanks
  • umbata Apr 21, 2008
    Is the electrical connector on the water value at the back of the fridge?
  • umbata Apr 22, 2008
    Seems to work. Thanks.
    Was probably a matter of time before it started spilling on my hardwood floor!!
    Genius:
  • 1,073 Answers
If you wich to disable the despenser for water in the door just unplug the electrial connector on the water valve it has 2 selenoids on it one is for water in the door it has the largest plastic line under the selenoid
just unplug the connector to that selenoid
you will still have ice and it will despense through the door
Posted on Apr 20, 2008
Ice maker WR30x0315 for a GE side by side TPX2BRYE BB Model Gs308336. Ice maker is spilling water out on the right rear interior corner of freezer box
If you wish to get some details about refrigerator common fault and troubleshooting ; visit the site linked here. Pull up older posts. search with the word "Refrigerator"..
http://electro-medical.blogspot.com/
Jan 22, 2017 | GE Refrigerators
My wife noticed our side-by-side GE Turbo Cool water dispenser was dripping water so a quick look in freezer showed a huge ice buildup in the drip tray that had frozen back into the spout. We emptied both...
let see if I understood correct me if i'm wrong! When you close the freezer door water star running from the dispenser? If so you water valve solenoid is staying in the open position just replace it.
Dec 21, 2014 | Refrigerators
Why would my Maytag MFX2570AE 4 door french door fridge motor/fan run constantly?
if the compressor goes off and only the fan keeps working thats broken fridg but fan is not a big energy drainer on bill if the compressor works allways it might be to hot in the room or door is not seald or totaly closed give it a strog push when closing or maybe you have under floor heating so you have to insulate bottom from heat or maybe its not insulatdd well from heat of compressor
May 20, 2014 | Maytag Ice2O MFX2570AE 25.0 cu. ft. French...
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
Water comes out of the soap dispenser its a brand new samsung model # is WF9854RWE i put soap into the dispenser closed the door and when it started to fill with water out of the soap dispenser door water...
Hey im having exactly the same problem with my samsung WF9854RWE and after the load of washing is done when you open the draw water spills out everywhere.
Jul 11, 2010 | Samsung Washing Machines
GSH25KGRWW dispenses ice/water all by itself! Heard noise last night, and refrigerator was dispensing ice all over the floor!! Attempted to stop by tapping the lever, but this had no effect; pushed water...
as you explained that by opening the freezer door the problem stopped the problem is: that you have a pinched dispenser wire or, two in the area between the door and, the door opening
these wires are low voltage so they are not going to cause a fire
but, if they touch the cabinet due to a bare wire they will ground and, start running the dispenser.
the door cover needs to be removed and, the problem (usually at the door hinge must be found and, corrected i.e. wire taped, shielded etc.
Sep 14, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Water dispenser won't stop. It started automatically and water keeps being dispensed even though we tried pushing the ice button and the lock button. It stopped when I opened the freezer door but would...
I take it this is a G E refrig ? Model number would have helped . If you still hear a hum with door closed , the microswitch behind the dispensor board is bad . Not a computer problem but a simple fix .
Aug 12, 2009 | GE Profile¿ Arctica® Energy...
AMANA refridgerator water dispenser not working. Freezer door not closed properly last night.
Hello schlucks
welcome to fixya.
You said, Your AMANA refridgerator water dispenser not working. Freezer door not closed properly last night.
When the door to the freezer was left open all night,the moisture from outside caused the water line to the water dispenser to freeze!
What you need to do is to move all the articles from your freezer to a spare or second freezer
temporarily.
Then turn off the freezer compartment of the first unit where the water is not depensing .
you will need 12 to 24 hours untill the line defrosts.
If the dispenser works sooner then don't wait any longer to restart the freezer.
In some models, the fact that the freezer is turned off may affect the power in the dispenser untill the freezer is turned back on.
After you finish defrosting and turn the freezer back on. give it 24 hours to get back to running temperture.
Then reload the articles agin.
BUT DO NOT TAKE 20 TRIPS TO BRING THE PACK AGES AND LOAD IT, LEAVING THE DOOR OPEN AGAIN!
Bring the articles to the freezer and load it straight awy quickly and close the door.
This will solve your problembarring any damage to the dispenser!t
Thank You for having me advice you.
Huuum
Please remember to leave a rating!
I'm sure you are solved!
Some info!!!!!!!!!!
cold air to the bin and make it colder.
Water and Ice Dispensers
(on some models)
Depending on your model, you may have one or more of the
following options: the ability to select either crushed or cubed
ice, a special light that turns on when you use the dispenser, or a
lock option to avoid unintentional dispensing.
NOTES:
■ The dispensing system will not operate when the freezer door
is open.
■ After connecting the refrigerator to a water source, flush the
water system. Use a sturdy container to depress and hold the
water dispenser lever for 5 seconds, then release it for
5 seconds. Repeat until water begins to flow. Once water
begins to flow, continue depressing and releasing the
dispenser lever (5 seconds on, 5 seconds off) for an
additional 2 minutes. This will flush air from the filter and
water dispensing system. Additional flushing may be required
in some households. As air is cleared from the system, water
may spurt out of the dispenser.
■ Allow 24 hours for the refrigerator to cool down and chill
water.
■ Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
Oct 03, 2008 | Amana Refrigerators
GE frig just starting leaking water at the bottom of the freezer side door
more than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Jan 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser not working
2 possible problems.
#1 water valve for the water side is stuck in the closed position.  Only way to tell is to pull the bottom kick panel out and look for the water line disconnect.  Separate the line, close the door and try to draw water through the dispenser.  If the water comes out of the disconnected line, then the water valve is good.
#2  if water is coming out of disconnected line, then the problem is in the freezer door.  There is a heater that keeps the water line from freezing inside the freezer door.  It is not repairable!!  The freezer door has to be replaced.
Nov 21, 2007 | LG LRSPC2031 Side by Side Refrigerator
Refrigerators Logo
158 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
