Question about Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V
Jets wont work i can hear the motor runing but like no water sirculating
  • 8,404 Answers
I think you have spun the center out of the impeller. Get a replacement impeller at your pull supply place.
Posted on Jul 24, 2010
Samsung front load washer doesn't go...no codes...just hear the motor trying to run?
Hi,just food for thought,if you can hear the motor runing it could be that the belt has come off,it the belt attaches to the motor to the drum,so if its come off the motor will spin and the drum wont,there should be a entree on the back of the machine with some screws undo them and and you will see the back of the where the belt is.
good luck.
Mar 05, 2016 | Samsung Washing Machines
Why has pump stopped working?
could be a start/run capacitor for the motor or a leaking pump[ seal has rusted the bearing of the motor causing it to jam
Nov 12, 2015 | Pool & Spa
Hi wont start. just making a loud whiring noise.
According to your description of the fault, something was blocking drain turbine of main motor. Dishwashers always first start drain water because calibration of water level inside dishwasher (empty). In your case, the main motor is same motor for washing and draining. Runing in one direction means washing, runing to oposite side means draining.
The solution is to open a turbine pump and remove all obstacles and visual check turbine impeller,ceramic seal and plastic sleeve on the motor shaft.
Dado
Mar 26, 2015 | Electrolux Dishwashers
How do I fix my windshield washer?
First do you have water in the resovor? First do you have water in the reservoir?
Can you hear the washer motor working?
If not check for power and ground if ok manually power motor if still not working fit new motor
If motor works check for blocked jets or a hose that has come off.
To clean washer jet find a suitable needle like tool to go inside the jets to clean them.
Aug 05, 2014 | 2006 Dodge Durango SLT
Washer fluid does not dispense on rear window of 2003 c240 mercedes
check the small housing that comes from washer bottle make sure that thats all attached if thats ok stick a pin in the jet as a build up of muck can get stuck in it blocking the jet up
Jan 25, 2014 | Mercedes C-Class Exterior Pillar Posts...
Washer jets not working
Step 1:
Hi Nicola
First thing to check will be making sure you hear the washer bottle motor working, when you operate the washer jets inside your car.If you can hear it, then you know that works, if it does not work, then you need to check the fuse has not blown, if it has replace the fuse with the same color fuse. Then check to see if it works. If it does not work then you need a new pump.
Step 2:
Pull of the main pipe to your jets, Then operate your washers again, There should be water coming out of the pipe.
Step 3:
If no water comes out, Pull the pipe of the washer pump on the washer bottle & operate your washers, if no water comes out, then you will need to take out the motor & check it is not blocked.
Step 4:
If the water does come out, then you need to check that pipe witch runs down to the washer motor for any kinks in the pipe, or just disconnect the pipe, try blowing through it, U should be able to blow through it easily, If not there will be a kink in the pipe, or the pipe will be blocked, so then the pipe needs to be kink free, unblocked, or a new piece of pipe installed.
Step 5:
If step 2 works, Then your jets are blocked.
Step 6:
To unblock them, Get a needle & push the needle through the whole in the jet to unblock it.
Step 7:
Do the same for all the jets, Put the pipes back on, Then operate the washers. They will work.
Step 8:
If you have any problems let me know. :)
Dec 19, 2012 | Cars & Trucks
How to unblock rear window wiper water pipe on I10
Firstly have someone operate the rear washer while you listen for motor operation at the front wheel well of the car (same side as the washer fluid reservoir).
If you can't hear the motor, then the motor is likely faulty and requires replacement.
You can operate the front washers to locate where both motors are. (under the car, beside the wheel well.)
If the motor is working but no water is coming out, then remove the rear washer jet and disconnect, then using a high pressure airline, blow backwards into the jet to clear out any blockage. If you don't have a high pressure airline with nozzle, then use something like the nylon filament from a yard brush to poke into the jet, to try and clear the blockage.
Nov 05, 2012 | Cars & Trucks
It lets a little "soaking"
your belt went bad in dish washer replace belt. dont keep runing that like that you will burn the moter up in dish washer
Feb 15, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Motor work but jets do not operate
You can hear the pump come on but get no water through the jets?Is the motor running or is it just humming
Feb 10, 2011 | Jacuzzi 9235-959 Nova 6 Whirlpool Bath 6'-...
Wont print power is on can hear jets runing
What you hear is the carriage going back and forth as well as the paper being transported through the path. The actual printheads are silent. More than likely, you have a bad or empty cartridge. Try using the printer's utility to clean the printheads - you may have to this a few times. If that doesn't work, replace the printhead.
May 10, 2008 | Lexmark Z600 InkJet Printer
Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V Logo
184 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
