Question about Toshiba 65HX81 65" Rear Projection Television
Toshiba 50HX81 Power LED Flashing
T,erry,
Been reading yur posts. Last night, I changed all 10uF caps on hyperboard? Plugged TV in (it seemed to power on when I plugged it in?). I noticed the remote would not work? Menu did work. Picture and all inputs appeared fine? After trying to figure out why remote wasn't working and repeatably unplugging, I now have flashing LED when plugging it in?
I don't know if I now have three problems after replacing caps on HB.
1) Remote doesn't appear to work?
2) I get flashing LED when plugged in?
Can you send me step by step for the flashing LED problem?
Thanks,
Jeff
jandkturner@sbcglobal.net
  • jtcool1 Apr 28, 2008
    Replaced F850, F851, F852 and both STK392-110's. Performed convergence. TV like new!!!
    Thanks everybody!!!
    Genius:
  • 1,694 Answers
Check any/all soldered-in micro fuses....F850,F851 etc.
Re-check your work......
solder jumper wires on signal board or fuse (s) may blow......T.
Posted on Apr 21, 2008
Toshiba 57hx81, has a slight squikgly line near the top of screen, colors seemed faded, not bright. i did the convergence adjustment and adjust the colors/focus with front lower right screws..Is there a...
jhinsincity: you dont need to be here, do you? the problem are the caps on the hyperboard, 10 -16v@ 10uf, rear access right hand green board, model 57hx81, the hyperboard must desoldered from main board. read the post on wavy lines,,
Dec 30, 2009 | Toshiba 57HX81 57" Rear Projection...
Toshiba 50HX81 projection 'tv- blinking red light
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jan 27, 2009 | Toshiba 50HX81 50" Rear Projection...
Tosh 57h82 flashing led and bad hyper board.
For a service manual, contact Toshiba directly.
Jun 17, 2017 | Toshiba 57H82 57" Rear Projection...
Toshiba 50H82 with wavy lines at the top when in HD mode
Found this person on eBay who repairs the hyperboard for $75 quickly with very positive feedback.
http://myworld.ebay.com/kcarrigan/
I have the same problem and will probably send mine after the holidays.
Dec 03, 2008 | Toshiba 50H82 50" Rear Projection...
Thanks for the reply
look at this thread.A lot of info there. I have ordered the caps at digi-key.com, part # 493-2105-1-ND
http://espnhd.com/voice/showthread.php?s=372087d540bc5c4b9b4d68631c67b610&t=10984&page=2&pp=20
Jul 27, 2008 | Toshiba 50HX81 50" Rear Projection...
Repairman for your TV yet?
Actually I found quite a bit of info regarding the problem and confirming that it has to be the caps on the hyperboard as hdtvman was mentionning.
I've bought the caps for less then $3, and will give a try at replacing them probably next weekend. I have nothing to loose as it's getting worse day by day now. If I screw up I can alway order the hyperboard from PTS...
Toshiba TV 50HX81
Check fuses on Power Supply board (F850, F851, F852) and all other fuses. Replace blown fuses (will need an ohm meter to check fuses). I would also replace the two convergence amps (STK392-110's on the signal board, the big black ICs on the two heat sinks). This worked for me.
Mar 30, 2008 | Toshiba 50HX81 50" Rear Projection...
Hyperboard repair Toshiba TSB
Best way is to check in circuit with ESR meter........
EDS-88 CapAnalyzer..... www.eds-inc.com .........................
Mar 27, 2008 | Toshiba 50HX81 50" Rear Projection...
Toshiba 50hd82 Hyperboard
By your question alone the best place to start would be a good repair shop. The hyper module needs to be removed from the main chassis. After removing the two outer covers locate Cx261, Cx230, Cx270, Cz52, Cx178, Cx221, C514, Cx250, Cx670, Cx241 and Cx541. These are all 16v/10uf caps SMT but most techs simply replace them with the sub mini radial caps.
Bill
Mar 13, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 65HX81 65" Rear Projection Television Logo
154 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
