Question about GE Kitchen Ranges
Oven ignitor won't ignite GE RANGE : JGBP28DED1CT
Removed from the unit the igintor works well when connected to 120v.
the gas control valve has continuity with an ohmeter.
the thermostat works when isolated.
the broiler works well.
  • GE Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Jul 16, 2010
Our MAGIC CHEF gas range has a pilot light that comes on, the ignitor comes on, but the oven does not work heat. Any ideas would be appreciated.
First off, decide which you have, a pilot lite or an igniter coil. In electronic controlled units, when the oven won't light, as long as there's gas available, 98% of the time the igniter is bad, even though the old one may glow and seem to be very bright, it could have a small hairline crack in the ceramic, which would not allow the proper amount of electrical current to travel to the gas oven safety valve, which would then make it open and release the gas. A new igniter works almost every time.
Jul 03, 2011 | Magic Chef 31000 Gas Kitchen Range
My GE xl44 gas range broiler won't work,
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
JGB900 oven won't work. Range top works, broiler works. No glow in oven. Regulator is on.
Your problem is with the oven ignitor. Remove the racks from the oven, remove bottom shelf. Remove the metal plate covering flame spreader. The igniter should now be visible. Turn oven on and watch the glow from the igniter. It will come on but it wouldnt get too bright, so it wouldnt open the gas valve. After changing the ignitor, oven should light.
Feb 17, 2011 | GE Profile JGB900 Gas Kitchen Range
Me GE Gas oven is not working, but broiler and range do ?
I am working with model JGBP26WEH1WW GE Gas range: You do not need to remove the back or even turn over, just remove the storage pan at the base of the unit and disconect the two plugs (unique plugs). You will need to splice your old conectors to your new igniter. Yes you have the correct igniter for that model.
Apr 06, 2010 | GE Profile JGBP79 Gas Kitchen Range
Have a GE gas range. Broiler doesn't work while
First clean the terminals at the control and check for tight wires at the incoming terminal block. Check the neutral wire for a good conection. If the ignitor reads less than 3 amps it does not have enough resistance to open the gas valve. Turn the gas off. Put a clamp on amp meter on the broil ignitor wire. Turn the broiler on. If less than 3 amps.replace the ignitor.
Sep 30, 2009 | GE JGBP28 Gas Kitchen Range
Broiler works, oven settings - no flame, no heat.
Hi, it sounds like the oven ignitor might be bad. Remove the floor panel inside the oven and you will see the ignitor attached to the burner assembly. Turn the oven on and see if it glows. You can test the connection for the ignitor and see if it gets 120V to it. The most common problem with the gas oven is the ignitor. Most of the time, the ignitor glows but is not strong enough to open the gas valve.
Please let me know if this was helpfull or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | GE JGBP33 Gas Kitchen Range
GE Spectra gas stove
Hi, There is a glow igniter that has to glow and open the gas valve to ignite the flame.
Are you seeing any glow below the floor of the oven? Remove the floor on=f the oven and you will see the igniter. If you have a voltage meter, You can remove the ignitor from the manifold ans test it. Put your meter leads into the connection and turn the oven on, (ONLY long enough to see if you have 120V.
If there is voltage, replace the igniter. They can still glow but be bad. The igniter gets weak and will not open the gas valve. Please let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Replacing control valve...
Be careful many ranges break the neutral... the ignitor always has power...I got almost electrocuted finding that out...
heatman101
Jul 02, 2008 | GE JGRP17 Gas Single Oven
Oven won't heat
Eliminate the gas valve first--Use a meter and connect the 2 wires off the valve to it.turn the oven on and you should either read 120v or 24v depending on the unit.If you have the voltage but no ignition the valve may be bad.However if you dont have the voltage i would suspect the heat board or thermostat as an issue.I would also check the pilot/burner for a clog from soot,even more so if the units propane.Let me know
Feb 20, 2008 | Maytag CWG3100A Gas Single Oven
Oven will not light. Ignition element will not even turn on
I have a magic chef gas range and the top of the stove burners work , the broiler works but not the oven..I think it is the glo bar. How the heck do I change this? It is a magic chef proven cooking performance from model # 8114p627-60 from about 1999
Jul 15, 2007 | GE EGR3000 Gas Kitchen Range
Kitchen Ranges Logo
220 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
