Question about LG 17" L172WT Monitor
What causes a herringbone pattern on L172WtProblem with the LG 17",ok on pc.problem entered 10 months ago.is there a fix now
  • 1,869 Answers
Do you have another electrical device too close to your tv?
those patterns are caused by AC power leakage. You can move other devices i.e.sat box etc. further away from your tv to fix this.
Posted on Jul 14, 2010
  • tvbob Jul 14, 2010
    reply no help have 2 tv's same fault in a business with 6 tv's.brought tv to home work shop faulty, This is the same as per 10 momth ago listing.(I have been to lg australia,no help ,suggested may be main board fault.) tv is OK componant ,faulty AV and tuner.Suspect an up coming comon fault.
  • Jim Goldsmith
    Jim Goldsmith Jul 14, 2010
    you can use aluminium foil to shield and, find where the interference is coming from i.e. the offending device or, if the AC interference is being caused internally you can glue foil inside the case of the offending device. is it your tv or, monitor or, both that has the problem?
My laptop wont connect to my wifi just started a few weeks agto
Acer Wireless Not Working? - Easy Fix by Drivers.com
www.drivers.com/update/drivers-news/acer-wireless-not-working/
Jun 17, 2014 - In some Acer models you can use a combination of keys on the keyboard to ..... My acer aspire wont connect with wifi, it say windows cant connect.... I've just had a similar problem with my Acer Aspire laptop (wireless .... It is startedto happen just a month ago before it was ok I am using this since 6 months.
Acer notebook won't access the internet [Solved] - CCM
ccm.net > Forum > Network
Sep 17, 2014 - My Acer Aspire one series notebook says it's connected to my wireless... I know for a fact that my wireless is working fine, as my normal laptop is accessing it and ... it a while ago, sometime in Autumn 2010) but now it just won't work. ... 1) First make sure that you have configured the WiFi settings correctly. Can't get Aspire One D255 to connect to wifi [Solved] - CCM
Jan 15, 2015
Can't Access Internet-Wireless Working! [Solved] - CCM.net
Dec 19, 2012
My laptop Browsers won't connect to the web [Solved] - CCM
Oct 10, 2012
More results from ccm.net
wifi wont connect all of a sudden - Aspire - Laptop Tech ...
Dec 14, 2015 | Acer Computers & Internet
A few months ago my LG Flatron L1900R monitor started flickering when I boot up my computer. It has become worse, to the point where it now flickers constantly.
From the information desribed, this means that your CRT monitor is going dead. Unfortuntly, there is no way to stop the flickering unless the monitor was replaced. I hope this has helped
Jul 05, 2011 | LG 700M 17" CRT Monitor
What causes a herringbone pattern on L172Wt television and composite input, but not PC input?
Your PC input is a secondary interfase, it does not go thru the IF and tuning sections.
It is possiable the if section has taken a surge and will need to be serviced.
Sep 04, 2009 | LG 17" L172WT Monitor
Dell E207WFP monitor
.Bad news.It cant be fixed.Try to take it back to the shop and get a replacement one.It might work for a few months or so but it is certainly a faulty screen.
Jul 21, 2009 | Dell D1028L 17" CRT Monitor
Print is clear and fuzzy
I'm sure you have fixed this by now... But solution is...
Check the hammer phasing. Adjust hammer phasing if
necessary.
6. On the control panel, press the = + > keys to unlock the ENTER key.
“ENTER SWITCH UNLOCKED” briefly displays. (If “LOCKED” displays,
simply press = and > again. This is the default key combination. The lock/
unlock key combination can be programmed by the user. If = + > does
not unlock ENTER, get the combination from the user.)
7. Press the ; key. “OFFLINE / DIAGNOSTICS” displays.
8. Press >. “DIAGNOSTICS / Printer Tests” displays.
9. Press >. “Printer Tests / Shift Recycle” displays.
10. Press ; until “Printer Tests / Phase Printer” displays.
11. Press ENTER. The display shows “Printer Tests / Phase Printer” and the
test begins. The current phasing value is printed on the left of the printed
pattern of all H’s. As the pattern prints, compare the H’s to the figure
below. If the phasing needs adjustment, go to step 12. If the phasing is
OK, go to step 15.
12. Press >: The current phase index displays. Press > again: An asterisk (*)
appears next to the phase value.
13. Press < to increase or ; to decrease the phasing index value, then press
ENTER to activate the value as it prints. Continue to increase or decrease
the phasing index until the pattern of H’s is acceptable.
14. Press = twice: “Printer Tests / Phase Printer” displays.
15. Press ENTER to stop the test.
16. Press CLEAR. “OFFLINE / CONFIG. CONTROL” displays.
17. Press = + > (or the key combination set by the user). “ENTER SWITCH
LineMatrix
Sinca Printers, Parts, & Repair
www.sinca.biz
Jun 11, 2008 | Printronix Line Matrix P5215 Printer
No picture and flashing green light
If u'r PC is OK, then this problem is showing when the main PCB of the monitor failed. This is 3 yr warranty monitor, contact the LG service provider in your area. They will change the PCB. Here is the link to get the service center info
http://www.lgservice.com/
Feb 25, 2008 | LG Flatron L1715S 17" LCD Monitor
Herringbone pattern
Herringbone (and other patterns) can be caused my many faults, the obvious one the tech was looking for was a tuner/interference fault.
Another common cause is a faulty power supply.
Difficult to say without having the TV on the bench.
I'm a bit suspect about the $400 - $500 repair cost though.
Perhaps try another tech?
I doubt it's a DIY repair though.
Let's know how you get on.
Jan 20, 2008 | Sony KP-61V85 61" Rear Projection...
No sound on analog inputs, digital sound is ok
1) IT02 Shorted, pins 92 and 93
Cause: Solder splash
2) IT05 pins 20 & 21 shorted.
Cause: Seems to have been cause by too much solder.
3) IT02 was found to be defective.
Cause: Defective component.
4) IS11 missing circuit trace.
Cause: Caused by some one that replaced/removed this IC previously.
5) IT02 solder, pins 42, 43 & 44
Cause: Two boards found with these same pins with cracked solder
6) IS13, pins 1 & 2 shorted
7) Audio Quits when board is tapped.
Cause: Soldered all IC's on bottom of board. Also soldered IT04, I516, I517, I510, I501.
8) Also, please resolder IT05 and IT06
9) Check for cracked patterns under IT05
Dec 10, 2007 | Hitachi 53SWX12B 53" Rear Projection...
LG 17" L172WT Monitor Logo
198 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
