Question about Whirlpool WED6200S Electric Dryer
Mywhirlpool cabrio WED6200Sw0 dryer doesn't turn
My whirlpool cabrio WED6200SW0 dryer doesn't turn on no power at all ,the breaker isn't tripped. I don't know what to look for.
  • amcjn5 Apr 08, 2013
    Hi...noticed that this post is kinda old....Did you get it going yet? What was the problem? Mine doing the same thing..well actually doing nothing.
  • manuela Nov 04, 2016
    I got my used. And I'm unable to turn on the power , no noise, lights no nothing. Can someone help please
  • 1,998 Answers
Whirlpool cabrio infamous for blowing out control boards check with a multimeter to see if you have power going into the machine and trace the lead power wire to the control board most likely it is your main control board hope this helps
Posted on Jul 14, 2010
Whirpool cabrio does not run or fill
check the power supply to the unit. if no voltage is found on the unit . check the wall outlet.no power at the wall socket ?? check the breaker box for tripped breakers if breaker to the wall outlet is off but good ,leave as is . check for grounds at the unit . if no grounds are present , turn on breaker . if it breaks with the dryer still not plugged in , search for any appliances connected on that line and unplug all. plug in the dryer then start it .if breaker opens , something is wrong with the dryer. call a qualified technician . thanks .
Sep 07, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have a whirlpool electric dryer.. when I turn it on its been having a problem with staying on or not heating at all. It will spin and stay on but no heat.we have changed the element and it seemed fi
Sounds like a tripped circuit breaker in the power panel for the house. The breaker for the dryer is actually 2 breakers connected together so if one trips so will the other. Sometimes this does not happen and only one breaker trips. This condition removes power to the heating element but still supplies power to the rest of the dryer. Check to see if the breaker will reset by turning off and back on several times. Then check the power receptacle that the dryer plugs into with a voltmeter set to read 240 volts AC. If no 240 but 115 is present then replace the circuit breaker.
Nov 19, 2014 | Whirlpool Dryers
Cabrio Dryer WED5500XWO not heating up
Is dryer conrtolled by 2 breakers ,if so one is for heat the other for power.
Jan 29, 2013 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
Whirlpool Duet Dryer Tripping Breaker on Heat Cycle
It caused the problem. Appliance repair person
May 13, 2017 | Whirlpool Dryers
My Whirlpool Cabrio Dryer is not drying. When I turn it on a code of L2 apperas on the timer spot. How do I fix?
You should check your breakers; the dryer uses two breakers side by side, I think one of them has tripped.
Feb 10, 2011 | Whirlpool Cabrio WTW6600SBK
Whirlpool cabrio wed6200sw0 dryer runs, won't heat up. blows air, lint line is clear and hi limit thermostat and thermal cutoff okay (have continuity) at room temp
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | Whirlpool WED6200S Electric Dryer
Whirlpool Cabrio - How do I tell if my heating
If you are comfortable useing a volt meter and a ohm meter I can walk you throught the steps otherwise you need to call a repairman, If you are not getting any heat and the tumbler is turning it is possible the element is bad again only a test meter can tell for sure or you can take the dryer apart and look at the element to see if it is broken make sure the power is turned off at the breaker first also unplug the dryer.
Apr 16, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Model WED6200SW0 cabrio dryer does not have
84d6194.jpgThis is the area that needs your attention. The heater is on bottom and held by 2 screws, remove it to look for breaks or check it for continuity. If the heater is good then one of those limits(probably the small one on top) has failed due to a blocked vent pipe. The bottom limit is 250f and the op is 300f. If the top is bad the bottom is bad too because it did not shut down. Now go impress someone Tiger. Oh and be sure to unplug the dryer before removing the rear cover. Rate the answer so in case I am wrong, someone else can have a shot. But i am never wrong.
Mar 03, 2010 | Whirlpool Dryers
Whirlpool WED6200S Electric Dryer Logo
1,602 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
