Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
My 5310 will turn over when starting but will not start. I have replace air filter, so why won't it run?
    President:
  • 1,627 Answers
The fuel filter may be plugged.Try bleeding the fuel system,open the bleeder on top of the filter housing and then pump the hand primer[above the bleeder].If you can't get fuel then you may need a strainer or a check valve,located in the fuel line before the fuel filter.If fuel is not the problem the you need to check and see if there is power to the fuel solenoid in the injection pump while the tractor is cranking,is so replace the fuel shut off solenoid,if not,replace the neutral bypass relay in the fuse panel.
Posted on Jul 14, 2010
    New Friend:
  • 4 Answers
5310 has an electric solenoid on the injection pump check fuses and relays sounds like the problem
Posted on Apr 17, 2013
    Problem Solver:
  • 6 Answers
Thank you for this question. Have you tried checking your fuel <a rel='nofollow' href="http://www.grahamequipmentmanufacturing.com"> injection pumps </a>? Or have you checked your fuel filter or flywheel?
Posted on Feb 14, 2011
  • shylohjacobs Feb 14, 2011
    Thank you for this question. Have you tried checking your fuel href="http://www.grahamequipmentmanufacturing.com"> injection pumps
Engine turns over about 3/4 of turn,won"t start,been running good,new batt,new plugs,new air filter
check and see if you have gas in the oil if you do rebuild carb if not replace starter is bad
Jul 12, 2014 | Garden
Yamaha yn 50 got a spark just won't start what
Check there is fuel getting to the spark plug-turn it over and then check the spark plug is wet. Also check the air filter is clean. Remove the filter and see if it will run. If it does then replace the air filter.
Jun 26, 2013 | Motorcycles
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Runs rough dies
change the fuel filter and check the fuel pressure
May 25, 2013 | Ford Expedition Cars & Trucks
Hi have citreon relay on a 05 plate, it won't
Replace the air filter and fuel filter.
Run a dose of Redex through the tank, the injectors may be clogging up.
Apr 14, 2013 | Cars & Trucks
Mower won't start spark plug turns black
Black carbon fouling on the plug is a sign of the engine running too rich, start by replacing the air filter and plug and try again.
Jun 16, 2012 | Toro Power Lawn Mower
John deere mower Won't start
Sounds like the carb is varnished up and needs to be rebuilt. They make rebuild kits depending on the carb number and you can rebuild it.
May 05, 2017 | Garden
Cub cadet 53bb5bbp750 zero turn won't start
check the safety switches
Apr 03, 2012 | Garden
Ran out of gas-truck won't start-replaced fuel
you probably have air in the lines, if you have a carb, spray some quick start into the carb and turn it over, if it starts and then dies when the starting fluid has run out, you probably need a fuel pump, since the running of the car should have blown out any air that was in the line, If your car is fuel injected, loosen the bolt cap at the end of the injector line that supplies the fuel,, and tap the key once,, ( don't start it,, ) just turn the key on and off 3 or 4 times, this should blow fuel out of that loose bolt head, if it does your getting fuel, if not, back to the fuel pump, also you can check this link, http://www.aa1car.com/library/us1296.htm
Jul 24, 2011 | Chevrolet Suburban 1500 Cars & Trucks
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
833 people viewed this question
Top John Deere Garden Experts
Wayne Fellows
Wayne Fellows
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Are you a John Deere Garden Expert? Answer questions, earn points and help others
