Question about Oster 76076-010 Hair Trimmer
Oster Stewart # 510A The part that holds the blades is broken _ it looks like an upside down U. Can I get a replacement part from Oster?
3 Suggested Answers
SOURCE: oster clippers
Found another web site where some one had posted the information I needed. I just used Google search and found the information.
Posted on Jul 15, 2008
VtToolMan
  • 704 Answers
SOURCE: Plastic retainer for the shaving blades is broken
You can buy a replacement shaver head and screens from an Oklahoma shaver business, electric shaver company.
Here's a link to their site and the page for the Norelco shaver you're looking to get parts for. The 3rd item down is the shaver head and screens, blades, etc.
I don't think you can get just the plastic retainer all by itself, as the manufacturer makes a complete head and blade as a replacement set, however, you can call them to see if they have just the retainer part you need. But frankly, it's likely a good idea to change shaver heads every so often to get the best shave, etc., so you might just want to spring for the complete replacement assembly part #HQ9 on this site for under $40.00.
http://www.electricshaverstore.com/get_list_143.htm
Hope you find this Very Helpful and best regards!
Posted on Sep 22, 2009
Oster clippers
it could be metal fatigue from the blade. Try a different blade and see if it does the same. If it is still rattling it could be your blade drive needs to be replaced. Sometimes the screws that hold the blade drive in place come lose or striped so you may need to check them.
Apr 23, 2013 | Oster Turbo A5 Two Speed Clipper - Blue
Oster A-5 Golden clipper blade is not flush against the clipper so wont clip you have to hold the blade down tight so it will clip.
see if the blade and hinge have moved away from the body of the clipper, the two screws either side of the hinge assembly may need tightening, or the main body may need replacing,
If its just one blade then there must be a problem with that blade.
Oct 19, 2010 | Oster Golden A5 2-Speed Universal Motor...
Oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Jul 01, 2010 | Oster Golden A5 2-Speed Universal Motor...
Had my #10 blade sharpened and now have several probs w blade and
You may know the first part of this, but...
Ordinarily, the blades are removed and replaced as follows:
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
In your case the retaining clip may have broken off. With the blade removed, push that same gun metal colored bar in. You should see the other end of it move in unison just behind the nylon cog that moves the blades when they are installed. Check the tip of that other end to see that the "turned back on itself" rounded portion is there. That's what holds the blade on. If it is missing, you will have to replace the part (the tongue part has to be removed to do so since the retaining clip part is under it, with a small spring holding it in place). A new one can be obtained, I think, at:
http://www.clipperrepair.com/parts.htm?brand=8
You say that you had the blade sharpened. By someone who knew what he or she was doing, I hope. It is possible that whoever sharpened it, reassembled it improperly so that the area where the retaining clip connects is too far toward the rear of the blade (opposite the teeth) and the clip is unable to click over it into place. If you look at the back of the blade, you will see the small slot just about in the center where the nylon drive cog fits to move the blade back and forth when it is mounted. Just below that there is a plate with two tabs extending toward the teeth. The part of that plate (toward the teeth) that has a slight indentation is where the retaining clip clicks into place. If it is not doing so, then either the clip is broken or the blades are not assembled properly. You can try (careful blade assembly is tricky in regard to getting them straight) to loosen the two screws and very carefully move that plate enough (very little should be required) toward the teeth so that the clip will hold. I would make very sure that the clip is not broken before doing that.
Hope this is helpful to you.
Apr 11, 2010 | Oster Golden A5 2-Speed Universal Motor...
The blades are not clipping in place properly. Somehow they are slipping out and not driving on an oster Golden A5 animal clipper
Apr 05, 2010 | Oster Golden A5 2-Speed Universal Motor...
Black spring clip will not engage and hold the blade for an oster a5 clipper
Mar 20, 2010 | Oster Golden A5 1-Speed Universal Motor...
The blades seem loose and chatter. Two blade sets have gotten broken tabs. It seems as though the metal blade release isn't holding the blades down properly. If I seat a blade and then hold the release...
your blade need to be adjusted and also we need to check the hinge for spring tension, also your sockets on your blades may be worn out. e-mail askmannyssharpening@yahoo.com they can help you with this problem.
Mar 06, 2010 | Oster Golden A5 2-Speed Universal Motor...
The head of the trimmer vibrates like it is loosening
check the 2 screw that hold the blade and see if they are tight. if this is not the problem take the blade off and see if the lever in the middle where the blade sit is not broken.
Feb 15, 2010 | Oster 76997-010 Hair Trimmer
Broken clippers
www.oster.com/ServiceCenters.aspx lista many service centers accross the country.
I suggest one like Shaver Service Center 5320 Cameron Road
Austin , Texas
78723
Phone: 512-454-5848
Fax: 512-454-9432
info@shaverservicecenter.com
http://www.shaverservicecenter.com
Email them, or one like them with your special situation and I suspect they will help you with RUSH SERVICE.
Keep up the great work you are doing over there, and stay safe!
Sep 08, 2009 | Oster 76076-040 Hair Trimmer
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
Oster 76076-010 Hair Trimmer Logo
197 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
