Question about RCA HD50LPW164 50" Rear Projection HDTV
RCA 50" DLP, model # HD50LPW164 will not turn on and has no audio. Moved the TV from one upstairs to downstairs. Plugged TV in and the blue light on the front panel power button turns immediately on and will not shut off. Can not turn the TV off using th power button on the front or remote. No picture or audio. What do you suggest?
Did anyone ever answer this question? I am having the exact same issue.
Posted on Oct 28, 2008
  • richiehcks Mar 13, 2011
    i too have this problem whats the fix any help b nice
I have a 50" haier tv that won't come on tried numerous plugs in my house moved it from one room to another and it quit working
Sounds like it died a noble death. U might want to check out the Power supply first. Also check the cord to make sure that power is reaching the unit.
Nov 22, 2015 | Haier LE50F2280 50" LED TV 1920x1080, 60...
I have a 52" RCA
Make sure you are connected to correct cable IF connector,Go to Menu and see if you are on Cable or Air.Then Do AutoProgramming.
Feb 17, 2011 | RCA HD61W140 61 in. Rear Projection...
I have a 50'' RCA TV but the volume just stop working after been moved from upstairs do downstairs. what should i do. pls help
Look at the rear of the set by the antenna input for a small black slide switch. That is for internal or external speakers. I bet you bumped it to external. Slide it back to Internal.
Dec 04, 2010 | Televison & Video
No picture or sound
If your set is DLP CK to make sure Fans are running CK lamp Fan if it is not running set will not come on. Go to Encompass Parts Distrubtion on line they will list all the Parts for your TV or call them 1-800-638-3328
Dec 21, 2009 | RCA HD50LPW164 50" Rear Projection HDTV
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
NO SOUND
Use Extneral Audio Jacks to a stereo for sound or replace audio output ic.
Feb 11, 2009 | RCA HD50LPW164 50" Rear Projection HDTV
RCA HD50LPW164
It is very well possible for new lamp to be bad ?
Dec 09, 2008 | RCA HD50LPW164 50" Rear Projection HDTV
No video problem
Wha is the chassis number for your set? It should be located on the rear of your setnext to the model number it will be an ATC number.
Feb 23, 2008 | RCA HD50LPW164 50" Rear Projection HDTV
Televison & Video Logo
156 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
