Question about ASUS P5GZ-MX Motherboard
I'm looking for asus p5gz-mx driver. - ASUS P5GZ-MX Motherboard
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 105 Answers
Http://www.bioticaindia.com/download.php?file=p5gz-mx
http://drivers.softpedia.com/get/BIOS/Asus/ASUS-P5GZ-MX-BIOS-0304.shtml
http://drivers.softpedia.com/get/SOUND-CARD/REALTEK/Asus-P5GZ-MX-Realtek-HD-Audio-Driver-6-0-1-5350.shtml
http://www.nodevice.com/driver/P5GZ-MX/get55057.html
RATE THIS
Posted on Jul 14, 2010
revskank
  • 203 Answers
SOURCE: lan driver , ethernet for asus motherboard p5gz-mx
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5GZ-MX
Posted on Mar 02, 2009
prnt master
  • 110 Answers
SOURCE: need driver for asus p5gz mx
please go to http://pk.asus.com/search.aspx?searchitem=1&searchkey=p5gz and download the driver.
Posted on Aug 16, 2009
iqbal_del
  • 655 Answers
SOURCE: boot failure
samuel,
if you don't here ok beep or any error beep:
  1. First check out speaker is connected properly to motherboard.
  2. Remove all component from motherboard like HDD,FDD, RAM etc..
  3. Just put only processor to your board and power-up
  4. There must be a long beep for missing RAM, if not means you have problem in Motherboard or CPU. Try out another board and another CPU to find out which one is faulty.
  5. If you got missing RAM beep, then power-off and add RAM. Then power-up there must be ok beep (only one beep) or missing RAM beep. If missing RAM beep, then your RAM might be faulty try to clean the connection point with pencil earaser and try out again. If no success then try with another RAM.
I think this will help you.
Please post your feed-back. Or ask me if any question.....
Gud luck
Iqbal
Posted on Apr 21, 2008
joecoolvette
  • 5660 Answers
SOURCE: i have asus mother board P5GZ-MX and the problem
Did you install the graphics card first, then try to install the drivers from the graphics card's CD? This
method is doomed to fail.
Why?
Because Windows 'sees' a new hardware device, and tries to match up one of it's generic drivers. There
wasn't any drivers installed from the CD, so Windows just found the next best thing.
The drivers CD should have been installed first, then the computer turned off, unplugged from power, and
the graphics card installed.
Now the monitor is installed to the graphics card, and you're on your way.
This bypasses the default setting of using the on-board VGA.
What to do now? Delete the software you have installed in your computer, and start over. (Start>Control
Panel>Add/Remove Programs>Graphics software>Remove)
Also you may want to see if an IRQ has been set for PCI VGA. (It's Plug n' Play or otherwise known as PnP)
Go into BIOS Setup, and set an IRQ for the PCI VGA (The term you'll see is -> Allocate IRQ to PCI VGA)
How?
Don't know if you've entered your BIOS Setup before. If so, disregard Number 1 below. (I'm not trying to insult your intelligence)
1.After you press the Power On button, the computer manufacturer logo screen will come up, (or instead
of a pre-built computer manufacturer name, it will be Asus. Computer manufacturer logo? Examples: Dell, Gateway, HP, and so on) Watch your monitor screen closely. As SOON as you see the logo splash screen,
start tapping the Delete key. Tap in 2 second intervals. You will now be in the BIOS Setup utility.
2.You're in the Main Menu. Look across at the headings. Second one over -> Advanced.
Press the Right Arrow key on your keyboard. Advanced will now be highlighted. Press the Enter key.
Now you're in the Advanced sub-menu.
3.See the ->Onboard Devices Configuration heading? 6th heading down. Use the Down Arrow key, and
highlight ->Onboard Devices Configuration Now press the Enter key.
4.See the ->Advanced PCI PnP Settings heading? Use the Down Arrow key to highlight it. Press the Enter
key. Now use the Down Arrow key and highlight -> Allocate IRQ to PCI VGA. Use the Right Arrow key to
highlight Yes, or No. Either Yes, or No, will be to the right. You want it to state Yes. Use the Minus key,
( - ), and Change Value. Change it to -> Yes
Now press the Enter key. Then press F10, and the y key. (It will look like a capital Y for clarity. You'll
be tempted to hold the shift key down, and press the y key. This = NO. Just press the y key. The y key is
for Yes. ->Yes you want to save changes)
Your computer will restart.
Posted on Jul 17, 2009
SOURCE: Asus P5GZ-mx compatible graphics cards
Basically, any graphics card is capable of being compatible with this motherboard. I had some difficulties for a while until I figured out you have to MANUALLY set it to use your PCIE 2.0 GPU output.
How to do this is to set your jumpers to external output only. First thing you'll want to do is update the BIOS on the motherboard (Which you can do by getting "Asus-Update". Find it on google, easy to use, just make sure your computer doesn't crash during the BIOS flashing.
Afterwards, set the jumpers to use your PCIE-2.0 slot. Took me a little while to figure this out, and it's a little hard to explain.
Above your PCIE-2.0 slot there are 5 little blue 'plastic-like' things. Those are your jumpers. Take them out and insert them HORIZONTALLY as such:
Basically, make sure the jumper things are connecting the little drawing there. They HAVE to be horizontally inserted, otherwise this WILL NOT WORK. Just plug in your monitor to the graphics card's output, and you're good to go. Hopefully it works for you.
Posted on Sep 05, 2009
I lost my Asus P5GZ-MX Motherboard Driver, after formatting my machine I am unable to load the driver. Give me the website address url from which I am download my Motherboard Driver.
go to www.asus.com
when you get there put in country i.e. united states
click on services support
move mouse to downloads
click on asus downloads
in the blanks put in your motherboard model number p5gz-mx and category = all
next it will prompt you for your operating system
then it will display a list of drivers available
good luck and let me know how it goes.
Jan 24, 2011 | ASUS P5GZ-MX Motherboard
Get a mother boad driver asus p5gz-mx
Go to the follwong site and follow these steps: -
1. Select Product - Motherboard
2. Select Series - Socket775
3. Select Model -
P5VGZ-MX and click search, it would ask you for operating system
4. Select operating system and download drivers
Hope it helps!
CreativeTECH
Nov 23, 2010 | ASUS P5GZ-MX Motherboard
I don't have graphic driver for motherboard P5GZ-MX
Hello ccccc0000nnn!
Asus has the graphic driver for your P5GZ-MX motherboard available for download on their website. The link for your motherboard is P5GZ-MX
Just pick your operating system from the pull down menu and then scroll down to VGA and click the "+" sign.
Nov 22, 2010 | ASUS P5GZ-MX Motherboard
P5gz-mx VGA driver
Access the manufacturer's web-site:
http://usa.asus.com/Search.aspx?SearchKey=P5GZ-MX
and then click "download".
Oct 15, 2010 | ASUS P5GZ-MX Motherboard
I WANT TO DOWNLOAD DISPLAY DRIVER FOR P5GZ-MX
You can download the drivers from ASUS WEB site. Select your model motherboard, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Click on this link: -
http://usa.asus.com/index.aspx
Dec 21, 2009 | ASUS P5GZ-MX Motherboard
Iwant all drivers with ASUS P5GZ-MX Motherboard
Start here :http://www.asus.com/Search.aspx?SearchKey=P5GZ-MX
It will lead you to the driver download area and all the specs on the MB
Sep 11, 2009 | ASUS P5GZ-MX Motherboard
Hello, I would like you to give me the lastest drivers for all Asus P5GZ-mx from Vga ob to lan I hope to get your newest product as soon as possible. send to my E-mail : truongmtc2002@yahoo.com
Visit this link :
http://support.asus.com/download/download.aspx?modelname=P5GZ-MX&SLanguage=en-us
select your OS and download the required driver......sodeep
Apr 07, 2009 | ASUS P5GZ-MX Motherboard
Lan driver , ethernet for asus motherboard p5gz-mx
Mar 02, 2009 | ASUS P5GZ-MX Motherboard
ASUS P5GZ-MX Motherboard Logo
532 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
