Question about RCA L26W11 26 in. HD-Ready LCD Television
Has sound no picture. screen is black - RCA L26W11 26 in. HD-Ready LCD Television
  • RCA Master
  • 5,124 Answers
It's a backlight or backlight inverter issue. (The backlight itself usually fades or makes the on-screen image change to pink/red.) For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.)
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. (http://www.lcdparts.net/howto/default.aspx for laptops) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight. With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing
I hope this helps.
(some videos are on You-tube for the inverter swap)
Posted on Jul 14, 2010
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
We have sound but no picture
? 4:52
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 467,264 views. 2:30. LCD & LED TV Repair - No Image ...
How to fix sony bravia has black screen - Digital TV - Streaming ...
www.tomsguide.com/forum/56867-4-sony-bravia-black-screen
Aug 19, 2014 - 12 posts - ‎11 authors
Hello, My Sony Bravia TV screen has gone all black. The green on/off light comes on,but no picture appears. The model ... Your solution solved the non picture for live tvbut still no picture (just sound) fir OnDemand. Score. 0. No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
Tv problems picture ok but no sound - HDTV
Sep 8, 2011
More results from www.tomsguide.com
Dec 14, 2015 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
Dec 09, 2015 | LG 47LS4500
My 5 year old plasma tv has sound but no picture what could this be?
No picture as in a black screen? or a picture with snow (noise)? If there is no picture at all (black screen) with no menu display when menu button is pressed, then it sounds like the y-sus and the z-sus boards are faulty..These are the boards located usually on the left and right edges of the screen. They are fused and these can blow, severing the supplt to the boards. These boards are used to deflect the electrical charge across the screen. If you have no picture then it sounds like both boards are down
Jul 31, 2009 | LG 42LC2D 42 in. LCD HDTV
No picture Screen black
Hi, you need to get your TV kit replaced... Please reply with the model number of your TV if you repairing it by your own.
Jul 20, 2009 | Protron Televison & Video
Picture comes on for 2 seconds then tuns to black screen Sound ok
Hi!
This more then likely a back light inverter board issue! It can be intermittent or just black an non responsive.
Feb 18, 2009 | Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
RCA L26W11 26 in. HD-Ready LCD Television Logo
332 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
