Question about Kenmore Washing Machines
Kenmore washer I recently moved into a house with a kenmore 70 series serial number 110 92272800. It has been working so far but today it stops after washing and won't drain the water. I took the outside drain to see if it's clogged and it isn't what do I do.
  • Kenmore Master
  • 2,005 Answers
Most likely you have a sock or, some cloth obstructing the pump.
you will have to bail out the water then: remove the Sears 700 series 4screws holding the washer's control panel and, remove the washer side clips under the panel to remove the washer's sides then remove the 8 pump screws to remove the pump face and, remove the obstruction. the
exploded drawings can be found at: http://beta.searspartsdirect.com/partsdirect/index.action
Posted on Jul 14, 2010
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
Dec 28, 2015 | Kenmore series 70 80 90 Washer timer...
My Kenmore 70 series washer sounds like it has something stuck in it and makes a grinding and buzzing noise the agitator will barely move but the washer will drain but not spin
That could be the motor coupler. It could also be the transmission. It is pretty easy to fix. I recently worked on my brother's washer:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 04, 2012 | Kenmore 20722
Kenmore 70 Series Washer won't spin or drain
DO NOT by pass a lid switch. It is installed as a designed safety feature to prevent bodily when opening the lid from moving parts. The CORRECT solution is to replace the switch. The following link explains step-by-step how to replace a lid switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
Replacements can be purchased at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. All these sites offer great service with competitive pricing, so shop all of them for the best deals. The first two web sites have excellent exploded view diagrams of your appliance to aid in parts location and assembly.
If you have any questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
PS This is not a difficult repair and it doesn't cost much ($25 to $35) on average for a replacement switch. Begin, fisrt by making sure the switch isn't loose or the lid strike (if equipped) isn't broken off. You may not need parts.
Jul 24, 2009 | Kenmore 22422 Top Load Washer
Our Kenmore Model 110 70 Series washer is overfilling the tub on all load sizes. Can you please suggest what the problem might be? We moved recently and the washer was working fine before the move, but...
If you just recently moved, you may have a simple problem of a disconnected air hose on the pressure switch. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
The washer water level is controlled by a pressure switch behind the load level selector knob inside the operator console. Often what appears to a major problem turns out to be something minor. Since you moved recently, the vibration from moving the washer may have caused the small plastic air hose on the pressure switch to fall off. Read through the link provided and let me know if you have any questions. I hope this helps you.
Jun 29, 2009 | Kenmore 24032\24036 Top Load Washer
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
May 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Kemore 70 series
Its possible that your trans. is going to need replaced. Maybe have some bad seals on the trans. As far as the water leak goes. Could be a tub seal, maybe some worn inlet hoses, maybe a leaky inlet valve.
We hope this gives you a start on your appliance repair. Anymore questions please feel free to reply back.
Mar 26, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
488 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
