Question about Kenmore Elite 45986 Front Load Washer
Washer making slapping sound, like a belt is split and hitting ho
When washer is running its making a slapping sound like the belt has split and is hitting the housing.
this is an elite kenmore HE 3t
  • Kenmore Master
  • 12,061 Answers
Kenmore Elite HE 3t motor runs but does't spin or drain
SOUNDS LIKE BAD CLUTCH OR MOTOR COUPLER IF ITS BELT DRIVEN MAY HAVE BAD BELT OR LOOSE BELT. i DOUBT ITS IN UR DRAIN PUMP AS UR NOT GETTING A SPIN WHICH IS WHY NO DRAIN.
Oct 17, 2014 | Kenmore Washing Machines
How do i fix the FH error code on a kenmore elite he 3t washer?
This indicates a water problem. Make sure you have both hot and cold water turned on and running to the machine. If pressure is to low on either hot or cold you will also get this reading
Jun 23, 2014 | Kenmore 24032\24036 Top Load Washer
Makes chirping noise and a loud slapping noise
check the drive belt under the machine as the chirping noise may be a slipping belt and the slapping could be the broken bit hitting as it goes around.
Aug 17, 2013 | Kenmore 24032\24036 Top Load Washer
Washer makes knocking noise while in spin cycle. Shock absorbers have been replaced and are good and machine is level. Kenmore Elite H E 3T Model #44932
Check your front and rear counter-weights. They are made of concrete and start to chip away. More so the rear than the front. When you open it up look on the base and see if you have chips or chunks of concrete. I had that problem as well - also make sure you spray lube inside,check your "Spider" wheel, and belt.
Jul 12, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Water running out the botton
sounds like you have lost your sump
take off the back of the machine
watch the bottom of the tub and turn on the water
you will get a much beeter idea of where its comming from
Oct 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite 3t the front light to select wash blinks but when s
Press 'drain' & 'spin' together for 3 seconds to see if it clears. This is your control panel lock.
If not cleared unplug the washer & wait for 30 minutes for the CCU (computer) to reset.
If helped you can rate.
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Fan belt hitting housing when running.
the belt has streched out, a common problem, it just need a new one
Oct 31, 2008 | Garden
Kenmore Elite 3t washer
unplug machine, go down to the pump motor and squeeze the tab and connector and pull it away from the pump.
Oct 24, 2008 | Kenmore Elite 45986 Front Load Washer
KENMORE Elite HE 3T
no but there is a control bd it is probably gone
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
152 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
