Question about Fisher and Paykel GWL11 Top Load Washer
GWL15 Model musty odor
The washer has a musty odor even when the door is left open between washes. It's definitely not the drain line. It's in the washer.
  • Fisher and P... Master
  • 12,061 Answers
You need to clean your filters and pump out, after which, you need to flush the system with white vinegar and water 50:50 make up a bucket of solution, and after cleaning all the lines pump, and filters, put the solution in the bowl, and run the short cycle to push the water through, this should help. You need to wash all parts in same type solution or bleach.
Posted on Jul 14, 2010
Why does My washer have a moldy musty smell?
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Apr 30, 2011 | Asko W6021 Front Load Washer
Do you need to keep the door open when not being used. i know some models require that.
There's no special requirement that you need to keep the door open. But, If you keep it closed after your done washing, some water is usually left behind and if you don't wash for a few days it could make the first few loads have a certain musty odor. I always leave the door open for a few days to dry out the insides then close the door and I haven't noticed the musty smell. Good luck.
Apr 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Cleaning the washing machine
It is recommended by the manufacturer that you leave the washer door open on all front loaders when not in use or the washer can develop odors, or begin to mold and mildew. Leaving the door open allows the tub air out. Because this is the lowest point of the drain cycle, gravity will always cause residual water to reside in the drain pump and drain lines. The water will NOT evaporate, but it will keep it from becoming sour. The following link explains what some of the common causes of odors in a front loader are and how to prevent them:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Newer model Kenmore Elite, Whirlpool Duet and Maytag Epic have a "Cleaning Cycle" button on the front panel. The owner's manual will explain how to use this feature.
If you do not have a cleaning cycle, use the hottest setting you have about once a month with a small amount of bleach to keep the spin basket and wash tub sanitized. I recommend the "Whitest Whites" cycle set on the "Light". This cycle is only 48 minutes.
Read through the link provided and make sure you periodicallt check the drain pump for debris that can cause odors and make sure you are using the correct detergent. If you have any questions, please post back and let me know. I hope this helps you.
May 02, 2010 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Odor in washer tub
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%
Apr 05, 2010 | Speed Queen AWS45NW Top Load Washer
Samsung front loading washer has a 'musty' smelling interior. I've tried leaving the door open, but it seems to stem from a small amount of water left in the bottom after the load finishes. What can I do...
Jan 23, 2010 | Samsung WF337AA Front Load Washer
My washing machine has a musty smell. How do I clean it?
Dec 04, 2009 | LG Washing Machines
My Elite washer has a musty odor. I have run an
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
Jun 16, 2009 | Kenmore Elite 45986 Front Load Washer
Foul odor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%4
Aug 26, 2008 | Kenmore Elite 45986 Front Load Washer
Musty odor in laundry
I would say that you are getting a build up of soap and oil from our bodies, on the inside of your wash bowl.
The Tubs pull out of the washing machine really easy and then you can water blast the two tubs.Solves this problem?
Once you learn how to pull the tub out you can also clear a blocked pump.
I have a after market lint filter fitted to my F&P washing machine,works wonders .
ask your local whiteware Man for some hints on a Bowl removal.
A five minute job???
Jul 27, 2008 | Fisher Paykel EcoSmart GWL15
Bad Musty Moldy Odor in Washer
Run a wash on the highest temperature, and add some vinegar into it. May do this more than one time. Be strict to wash on the higest temp some times in the month.
Good Luck
Jan 24, 2008 | Siemens WFXD8400UC Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
139 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
