Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
I have a Kenmore Elite refrigerator/freezer model number 795.77563600. It's 4 years old. As of this morning it is displaying an error message of Er ff. Any idea what this is? Sears was no help and there is nothing in the manual. Please help! Thanks.
    Genius:
  • 1,075 Answers
Go to the kenmore web address and tell them your code and they will be happy to tell you.adrian,,,,,
Posted on Jul 14, 2010
jonniewalker
  • 1031 Answers
SOURCE: Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
Posted on Oct 18, 2008
rylee_smith
  • 8619 Answers
SOURCE: what does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jun 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore model 795 77563600 refrig side
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Model 795 77244601
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Posted on Sep 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: error code if err for kenmore elite model 795
Posted on Sep 27, 2010
I have frensh door kenmore elite fridge model number 795.72053.110 display error code if someone cane please help me ? ER F5 WHATS THE MEAN .... THANK YOU SO MUCH
faulty cercit board is what you have there sorry to say but it dose happen every so often get in touch with the poeple who you got it off and have the engineer look at it
Jan 22, 2015 | Kenmore Refrigerators
Error message Er 1F
Maybe this will help. i would check fan first and see if ice has built up in fan.
https://www.youtube.com/watch?v=a4MdwuoN3jc
May 26, 2017 | Kenmore Refrigerators
What er ff mean at Error message on display of Kenmore Elite Bottom Freezer Refrigerator
Hi.
Error ff (er ff) means defective fan detected. Before calling support or before replacing the fan try performing a complete defrost by leaving power disconnected for one day (remove food from inside the unit first). That will fix the problem if the fan was temporarily malfunctioning because of ice formation. If that does not work the fan must be tested before replacement.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 09, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite error message er ff
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio Error Message ER DH
This is a refrigerator manufactured by LG and is well known for this type of malfunction. There should be two 1/4 inch screws on the outside of the freezer drawer tracks near the front that will allow you to pull out the entire door assembly. Once this is done and the unit is fully defrosted and unplugged, there are a couple/few screws in the back freezer panel. Once the panel is removed, this part is located on the upper right side of the evaperator coils. It is sometimes wedged in tigtly but should pull out with a good tug. Unplug the white harness, remove defective part and reverse this process. Good luck and happy shopping for the shoes.
Aug 25, 2009 | Refrigerators
Error message (?) on display of Kenmore Elite Bottom Freezer Refrigerator
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Jul 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error Code Er FF
ER FF - found in another post = Error Freezer Fan. Removed freezer back panel (inside freezer), defrosted ice build up around fan. Error message gone for now. Easy fix at midnight - 20 minutes. Will be looking into ice-up cause.
Jul 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
552 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
