Question about Comfort-Aire PAC-121 Air Conditioner
I have water leaking on my floor from the Comfort Aire portable air conditioner. Not sure why. Can you help ? Thx
    Genius:
  • Comfort-Aire Master
  • 1,363 Answers
Should have drain pan that has to drain or be emptied out.
Posted on Sep 14, 2015
SOURCE: Comfort Aire PAC-121 problem
E4 shows up on the screen on my PAC-121 when the water reservoir on the right-hand-side is not pushed in all the way. If it is in all the way the switch that it engages may be bad or out of place.
Posted on Mar 23, 2009
  • 86 Answers
SOURCE: water leaking all over
The water leaks all over the floor instead of running into the water containner. if that is right then your condenser drain pan tubing is blocked or the pan is rusted out that cause the water leaks all over instead of running down the tubing into the water containner . You've to dismantle the panels to get into this condenser drain pan to have a good clean out . Hope this will help . God Bless.
Posted on Jul 25, 2009
james3751
  • 614 Answers
SOURCE: My air-conditioner is leaking a lot of water onto the floor.
You may jst have a stopped up draon or drain pan. If you can get to thesmall whole that it drain out of. **** it out with a shop vac. If you have one. Russ
Posted on Jul 26, 2009
madman775
  • 5 Answers
SOURCE: leaking unit
check to ensure that the drain hose is not touching the side if the water storage bin. if still no luck then watch unit when running to assess the leak point............maybe a hairline crack in water container
Posted on Nov 02, 2009
bobicehouse
  • 1524 Answers
SOURCE: comfort-aire wpc30 air conditioner: water control
Dirt most likely.
Posted on Jun 02, 2010
What brand is comfort air
It is Comfort-Aire (trade marked), that is the name of the brand.
Jan 21, 2012 | Comfort-Aire QEQ1024C Air Conditioner
Humidifier gets ice on top of cabinate. It still produces water.
Most dehumidifiers have a defrost cycle that they run through, as needed. But, apparently, your is not functioning. Eventually, yours will stop collecting moisture, if this continues. In the interim, I would suggest turning the Master OnN/OFF Switch to OFF and unplug the unit until it thaws. While it's unplugged, remove and clean the air intake filter on the front of the unit. If it's clogged it causes the unit to strain and may cause it to ice up. Once the filter is clean and the unit is un-thawed. Plug the unit back in and turn the Master ON/OFF Switch to ON and set the controls as you normally do. Hopefully, that period of being unplugged will have allowed the unit to reset itself and work properly.
I have included a link to your Owners Manual that you can download and print for future reference.
aire.com/index.php?option=com_rubberdoc&view=doc&id=436&format=raw">http://www.comfort-
If the above link fails go to the following link below and click on Owner Manual, near the top of the page.
aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-g">http://www.comfort-aire.com/room-air-conditioners/149-portable-dehumidifiers/122-bhd-301-g
Hope this helps you solve the problem.
Apr 27, 2011 | Comfort-Aire BHD-301 Dehumidifier
B zone is only cooling to 49 degrees and leds at L3 and L4 are blinking at 1 second intervals at circuit card on outdoor condensing unit. Is there a service manual available for download?
Hi
The L3 and L4 lights are blinking means that the filter is dirty and obstructed. You’ll need to clean the filter. Also Inspect whether the evaporator air is blocked, remove the blockage. Check the air intake and outlet ducts of the condenser side are obstructed. Check both of the ducts. Check whether the unit is set on dehumidifying mode. Set at cooling mode, Set at low fan speed Re-set the fan speed at high speed and check.
However, if this doesn't help then it might have happened that the compressor is not runing and the connection to the compressor is cut. Please check the wiring diagram on Pg 22 in this manual---
Comfort-Aire Air Conditioner Manual & wiring diagram
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Aug 02, 2010 | Comfort-Aire HMC18AD-1 Air Conditioner
Comes on and runs then cycles off, and may not come back on. fans run every thing seems to work compressor dose not come back on.
if a portable air conditioner, is the water tank full of water ? if so empty it.
Other option for any a/c unit (not just portable unit) is that it has a gas leak.
Apr 21, 2010 | Genie Aire PACR12 Air Conditioner
Broken wheel roller on a PAC-121 portable air conditioner
Yes, you can. The caster part number is 2040-0142 and can be found at some online retailers.
PartsGuy.com
Appliancefactoryparts.com
Feb 18, 2009 | Comfort-Aire PAC-121 Air Conditioner
Jan 25, 2009 | Comfort-Aire PAC-121 Air Conditioner
Need a manual
looking 4 manual 4 comfort aire a.c. model#pe-121a serial# 070301060
Dec 29, 2008 | Comfort-Aire PAC-121 Air Conditioner
Ac odor
clean the ac with coil cleaner make sure to wash it off with water very good .
Jun 24, 2008 | Comfort-Aire RAD-81 Air Conditioner
Comfort-Aire PAC-121 Air Conditioner Logo
500 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Ottoniel
Tim Whalen
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
