Question about JVC RM-C18G-1H Remote Control
My jvc telivision wen i plug in the tv it comes on and then cuts off i have no remote for it the remote is not working but there is ah light that comes on the tv next to the power button it says timer and it only blinks
  • 4 Answers
The television is lock in timer mode. are there any buttons on the front panel where you can get into the menu. If, so go where it says timer and turn it off and see if that helps you.
Posted on Jul 14, 2010
I have Onida TV Model 21 inch , I accidentally enable the features of volume lock, hotel mode and channel lock and I cannot reset the same. Due to this, I cannot increase volume of telivision
MIGHT WORK IF YOU:
Turn off tv with remote, that is standby, then turn off tv with switch or unplug from wall. Wait a few minutes until led lights go off on tv. plug tv back in. try pushing vt on remote and power button on tv at same time.
If this doesn't work try contacting a local retailer, they always have a list of codes for their salesmen.
Jan 07, 2012 | Televison & Video
Telivision not projecting a picture.
if you already use any other electrical set in the same place where the tv is and is the power plug ok. Then the tv has the power supply damaged. post your question if you need more detail about this problem.
Apr 22, 2009 | JVC HD-52G886 52" Rear Projection HDTV
New JVC flat screen cuts off 10 sec. after cutting on
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
Mar 26, 2009 | JVC LT42P789 42 in. LCD TV
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Turning on closed captioning
Some older telivisions don't have the option hoever caption with always be under the menu. Or if your playing a DVd then under the language set up.
Feb 12, 2009 | JVC AV-20220 TV
JVC 42 inch LCD HD TV has no picture or sound
utencilio posted this fix. It worked for my JVC LT-42X579.
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first
Jan 28, 2009 | JVC LT-42X579 42 in. LCD TV
Av-32d302 tv
The set is shutting down because a problem has been detected. Replacing the remote will not help. Count the flashes and call a JVC servicer to get an idea about what the specific problem may be.
Dan
Jul 29, 2008 | JVC AV-32D302 TV
TV, i plug it in, turn it on, no image, "on timer" light comes on.
In a large number of failures with these symptoms it's usually the HOT (horiz. output trans. Q522, which is a 2sd2499) and the regulator (Str30134), together with fuse F902 (Gma 1.25a). Not an expensive repair or that complicated if you're fairly good with electronics and know how to solder correctly. Otherwise take it in and have it repaired professionally - it's worth it...
Bill
Nov 29, 2007 | JVC AV-27230 27" TV
Radio shack 3-in-one remote
Need programming codes for Radio Shack 3-in-one Remote Control for JVC and Sylvania TV
May 02, 2007 | Radio Shack 15-2104 Remote Control
JVC RM-C18G-1H Remote Control Logo
61 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
