Question about ASUS SDRW-08D1S-U USB 2.0 Slim External DVDRW with Cyberlink Software - White Burner
Starting today my drive is being read as a cd-rom only, i cant burn a dvd. wont even read a disk (i have cleaned the lens).
  • 3,153 Answers
This in indicative of a dying drive.
I have no idea why but external drives do seem more prone to it.
Additionally if you have recently added any new burning software you may want to un-install it as I have seen that too fix similar issues.
May I suggest you connect it to a different computer first to eliminate your own computer as a suspect.
Make sure you use the leads that came with the drive and not one that just happens to fit as some leads are not always compatible even though they may look the same.
If it is still under warranty you may want to investigate that option.
Hope this gives you enough to get you sorted out as to what to do next.
Bob
Posted on Jul 14, 2010
  • The answers by Project Nomad / bob_computer are to be considered copyright 2011 and property of
    R. Humpleby
    Use without prior "written permission" is no longer allowed.
    This property is no longer shared with Fixya and its associates / affiliates
    Reason. account termination.
  • 3,866 Answers
I am wondering if you running windows 7 with this drive?
There is a known issue with windows 7 thinking this is a egular drive and truely its not. Upon investigation there has been users complining of the same issues but with windows 7. Some have tried using Legacy usb support in there bios and worked and some have tryed firmware and worked.
I do not know what is theissue in your case as you did not list the operating system.
1. Try legacy usb support.
2. Try checking firmware updates for windows 7 if that is what your using with this drive.
You never want to think this is bad until all your ducks ar ein one row. Putting the cart in front of the horse in this cause will end up sending a good drive back.
1. check your operating system
2. Check and see if your bois is on legacy usb support
3. Check firmware upgrades.
Burning software will not cause this because that is the application layer not the driver layer, First we want to make sure that the system is seeing it as a burner then we start the investigation process, Hope this is more of the information you where looking for?
Thanks for using fixya.com
Latitude C840 wont reconize optical drive in BIOS
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the the whole drive unit.
Apr 25, 2009 | Dell Latitude C840 24X CD-R W/ DVD Combo...
Sony DVD+/-RW |DW-Q30A will not record cd or dvd & only play dvds
Whe this problem is starting you may be able to read only CD, DVD , or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Mar 28, 2009 | Sony DVD+/-RW |DW-Q30A BG w/o SW %...
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Cd not reading
Try first using a CD/DVD lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD RW drive unit.
Feb 24, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
My super multi driver cannot play DVD moveis
1.if the dvd has some scrathes on it cant read as a result it cannot read
2. if the dvd is not written properly while writing using some dvd burning software it will not read that dvd properly .
3.if the dvd is pirated some dvd roms support only original dvds that might be a problem
4.if some dust accumulated on the lens of dvd rom the dvd will not get read properly for this u can use some lens cleaners and clean the lens of dvd rom it is available in the market everywhere try this it will definately work
4.after doin the above if still none of the dvd \s arent working means the life of your dvd roms lens is over now u have to get a new dvd rom
Jan 31, 2009 | LG Computers & Internet
Dvd-rw drive malfunctioning
Please Check :-
1) Whether U R using the Proper NERO. I want to mean, try installing the NERO which was provided with the DVD-RW+ Drive.
2) Check whether there is a Firmware Upgrade available for your DVD-RW+ Drive with the help of provided CD/DVD and a compatible Software.
Jul 27, 2008 | Lite On (SHW-1635S) DVD RW Dual Layer...
CD-RW/DVD-ROM wont write to 8x disks
My combo drive is unable to read any files in DVD. Please let me know what should be done.
Combo Drive SM-352F
May 12, 2008 | Samsung SM-352F CD-RW/DVD-ROM (Combo)...
Drive wont recognize any media
This is usually caused by dirty drive lens, too scratched CDs or CD burnt at faster speed than your ROM can read. (I am assuming that your pc detect the CD drive and has no hardware conflict with it).
Try reading an unscratched prerecorded (original CD), if it does not read this as well then your lens are dirty, try using a CD lens cleaner if these dont work then you need to open your ROM and use a highly volatile organic lens cleaner chemical.
Mar 23, 2008 | HP DVD 740VI 16X16 Dual Layer LightScribe...
My dvdrom drive wont let me access the drive
ITs a dvd rom drive. It will not burn blank dvds
in order to burn, it has to cd-r/cd-rw/dvd-r/dvd-rw. If a drive cannot write to a blank disc, it will eject it. Rom drives read only (Read Only Memory), Combo drives- burn cd's only read dvd's, and super drives both read and write to cds and dvds.
Oct 23, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Cd-rom dvd
CDROM CAN NOT READ CD'S Try cleaning the lens using a high grade CD Lens Cleaner.
Sep 21, 2007 | Computers & Internet
ASUS SDRW-08D1S-U USB 2.0 Slim External DVDRW with Cyberlink Software - White Burner Logo
283 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
