Question about Toto Toilets ST784S 12 Sedona Beige Clayton Toilet with Traditional SoftClo
I have a toto toilet that doesn't start to refill until a couple of minutes after I flush. Any ideas. Thanks.
  • 760 Answers
Several ideas. Start to fill? Have you looked inside the tank to see what's going on? If it just filling very slowly, then you most likely have some calcuim build up inside your flush valve blocking some flow, if this is the case you will have to clean the flush valve. If your flush valve is staying up and the toilet is "running" unitil the float drops. The float (either the arm ballcock style, or newer fluidmaster) is rubbing on either the flush lever or side of the tank, and taking longer to drop to let the water start flowing. I
Posted on Jul 14, 2010
Toilet is taking an increasingly long time to refill after flushing
Make sure that the plug goes all of the way back down after flushing so no water is leaking out and then increase the water pressure. There should be a knob on the wall behind the toilet. Just turn it left until it is where you want it and it will fill up faster.
Apr 17, 2011 | Toto Home
After the toilet is flushed, the water coming out of the rubber tube to refill just barely trickles out. It takes about 10 minutes to refill. Thanks Don Cook
Most likely the toilet flush valve is plugged with sediment &/or needs to be replaced. Try turning off shutoff valve on bottom of toilet. Then turn valve back on. It may flush out the sediment. If not you will need to change the valve.
Jan 17, 2011 | Toto Home
Toto toilet
check the pipe connection from water tank
Mar 17, 2010 | Toto Washlet S400 for Power Gravity...
Toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
Jan 23, 2010 | Toto Aquia II Dual Flush Toilet
G-max flushing system is not filling to proper level
Is it not refilling the tank or the bowl? I've got a toto also that is not fully refilling the bowl after each flush. No leaks or other problems. Tank refills fine. Seems that the flapper doesn't float long enough to allow a sufficient amount of water to drain into the bowl before closing. Any ideas?
Jan 06, 2010 | Toto Drake ADA Compliant Toilet with...
When you flush, the bowl refills and then suddenly empties 90% of the refilled water. Why? This is a toto toilet and this happens almost all the time now.
it sounds like it is not flushing completely at first and then releases and the suction is pulling water out of the bowl. Could be a venting issue or a clog issue that is hindering the proper flushing of the toilet.
Nov 23, 2009 | Toto Home
Toto toilet - inadequate flushing
if this has been the case since the toilet was in stalled the problem is probably with the venting of the plumbing lines. try switching the toilets and seeing if it still happens with the "good" toilet.
May 27, 2009 | Toto Toilet Onepiece Ultramax ...
Toilet will not flush
You need to replace the fill valve with a oem replacment valve. You need to use toto parts.
Mar 07, 2009 | Toto Aquia II Dual Flush Toilet
Toilet tank will not refill with water after flushing
I fixed the problem. There was a clog in the pipes so i just flushe dthe pipes out.
thanks,
for your help
Jan 17, 2009 | Toto Carlyle 1-piece Elongated Bowl Toilet
Toto Toilets ST784S 12 Sedona Beige Clayton Toilet with Traditional SoftClo Logo
501 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
