Question about Canon SELPHY DS810 InkJet Photo Printer
Paper jam It keeps saying theres a paper jam...but there isnt any paper jammed!
    President:
  • 1,382 Answers
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Posted on Jul 14, 2010
Message in the screen add paper
The best thing you can do is read the manual first, it explains all these things. Just in case: That is telling you to put more paper in or it will quit printing. Try these links:
Canon printer says its out of paper when there is paper
The printer keeps saying its out of paper and its not not sure if paper is... My printer says paper is jammed when it isnt HP Printer keeps saying to add paper but it in
May 30, 2016 | Office Equipment & Supplies
Jam in tray 2 bt there is not paper jams
There may be paper remnants left over from a prior feed jam. Please click the link below and select printers - jams and feed issues to find more info.
HP Color LaserJet 1600 Printer
Aug 21, 2014 | HP Color LaserJet 1600
Why does it keep stopping and saying paper jam when there isnt one when I send anything to print or copy
Hi
This can happen if the sensor is dirty or not working. If it has started giving you the error after 1 or 2 paper jam earlier then when you have pulled the paper the Sensor flag (Black in Color) has got dislocated from its housing hence you need to put it back so it can wiggle better and freely. This will solve the problem.
Aug 01, 2011 | HP Officejet 4215v All-in-One Printer
The printer is now saying paper jam and there isnt one
Open the back door pf the printer and look for a black plastic lever.That the paper sensor wich may be damaged and it is saying to the printer there is a paper jam.
Nov 01, 2010 | HP Officejet 6500 Wireless All-in-One...
Says paper jam but there isnt one
off your printer and manually feed paper by turning roller as guide, observe if sensor key freely move when paper pass, some sensor key stock when forcefully remove the jam paper inside.
Apr 05, 2010 | HP LaserJet 1020 Printer
KEEPS SAYING PAPER JAM AND THERE ISNT ONE. DOESNT SEEM TO WANT OT PICK UP PAPER
ok im going to guess here that you are getting a 201 paper jam error with no paper in the printer. this would indicate a bad main motor drive replace it.
if its a 202 error check the 2 sensors on the fuser for stuck flags
if its a 241 error clean the pick wheels with aresol elctronic contact cleaner to remove the glue build up from them. or replace them
Dec 04, 2009 | Lexmark T640 Laser Printer
Canon PC735 copier, paper jam light keeps coming on but there isnt any paper or anything blocking the machine. Tried resetting but nothing has worked. What can I do?
My canon copier pc735 says we have a paper jam- but it does not. We just replaced the cartridge and it wont work. I had them send me a new cartridge, but its the same thing- paper jam. Help!
Oct 10, 2009 | Office Equipment & Supplies
Problem with paper jam, but no paper..
1) there should be problem of interference of another signals.
Apr 12, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper jam indicator keeps appearing and there is no jam.
SOMETIMES THE PRINTER WILL READ THAT IT HAS A JAM IF SOMETHING LIKE THE INK ISNT CLICKED IN TIGHT OR SUCH. IM SURE YOU MIGHT HAVE TRIED UN PLUGGING IT FROM ITS ACTUAL POWER SUPPLY BUT IF YOU HAVENT I WOULD TRY THAT, IT COULD RESET THE WHOLE THING. IF THAT DOESNT WORK I WOULD JUST GET THE PRINTER IN GOOD LIGHT AND OPEN ALL COMPARTMENTS, THERE COULD BE THE SMALLEST PIECE OF PAPER JAMMED SOMEWHERE YOU CANT SEE OR WOULDNT EXPECT THERE TO BE ONE
Jan 09, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Canon pixma mp150 saying paper jam but cant see one
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Dec 11, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon SELPHY DS810 InkJet Photo Printer Logo
1,026 people viewed this question
old marine
old marine
