Question about Hayward SAND FILTER, PRO SERIES
I have a brand new hayward e series and it will not hold prime
  • 760 Answers
When you say it won't hold prime I assume you mean when you turn it off either manually or on a time clock? If this is the case you must have an air leak somewhere in your piping system or in your pump. Could the pump seal be leaking. Gasket on pump strainer ("O" ring) Is the strainer basked crecked. I've found several pump strainer assemblies with small cracks that won't even prime at all if there is much lift. Check for cracks on all threaded fittings, IF the fittings were overtightned then it can crack the fitting, like in pump inlet and outlet. Listen for a hissing, sucking sound when you turn the pump off.
Posted on Jul 14, 2010
Why does Pump lose its prime and won't prime again after shutting down
you have a leak in one of the intake unions make sure to use pool lube if those ok check pump top seal or chlorinator top keep checking youll find it if not need more info
Aug 17, 2014 | Hayward SAND FILTER, PRO SERIES
Hayward H400FDN will not stay lit - Brand New install - NO Fault codes.
make sure wiring is correct especially if wired 120 volt read instructions inside panel
Jan 28, 2014 | Hayward Industrial Products H400FDN...
I have a hayward s166t filter, guage reads 0 and sight glass water does not swirl when backwashed
Does it show pressure when in "Filter" mode?
If not, then your pump is either not primed, Impeller is plugged, or there is not enough water in the pool, you are sucking air.
Jul 18, 2013 | Hayward S166T Pool Filter System w1 HP...
HOW TO START MY HAYWARD PRO SERIES SP0714T1
prime pump by filling pump basket then make sure in filter position then turn on
Mar 04, 2013 | Hayward SAND FILTER, PRO SERIES
Pool won't hold prime. I cleaned the filter & basket. Prime is slow to come up but then surges up and immediately drops back down.
check top seal make sure its not damaged if ok check to see if intake union is tight if still bad check impeller for debris
Sep 06, 2012 | Pentair 1.0 Hp Whisperflo Pump
Sand filter losing prime
You will see NO leak if the pump is on.
But once the pump is off, then you may see a leak.
Jul 23, 2012 | Hayward Pool & Spa
No water flow,, think its needs to be primed
What brand of pool pump do you have? The pump is separate from this pool filter so I would have to know the brand and model to tell you how to prime it.
Jul 03, 2011 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
129 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
